Hi all,
I’ve decided to write this little post just to make other life easier.
I’ve just started a week ago using FAST simulator, and I had a couple of problem that are not related to the understanding of the material. In fact I had some problems in founding the correct materials/files for a beginner in wind turbine studies, as I am. I’ll list the things that I have done:
1- Of course, download and install FAST.
2- Read the FAST User Guide, really well written. The guide explains how to interface FAST with Simulink, thing that can be done in a few minutes.
3- If you have no idea (like me) of how to control in simulink a wind turbine I suggest you the report
nrel.gov/docs/fy08osti/42437.pdf
It explains almost every single baseline controller for the wind turbine, and is really well written. The problem, in this case, is that the report refers to the CART turbine, that is a two bladed wind turbine, and it’s almost impossible to find some of the input file that are needed to run the simulation (some are reported at the end of the document, but some are not). Reading in the forums I’ve found that a standard is the “5MW NREL wind turbine”. For this turbine is possible to find every file about the structure. You can find all the needed files in:
National Wind Technology Center's Information Portal | Wind Research | NREL (ftp folder where you can find a lot of good stuff)
click on “jjonkman/”
click on "NRELOffshrBsline5MW/ "
Here there is the file “NRELOffshrBsline5MW_Onshore.zip” that contains all the file for the onshore version of the turbine.
4- After that you should read the document: nrel.gov/docs/fy09osti/38060.pdf that explains all the parameters about the 5MW NREL wind turbine, and has in the end the input file (the same of jjonkman’s folder) and the parameters for the control. For simulating you should use the *.wnd file in the pages A-5, A-6 of the report 42437.
5- Following the direction of these two report you will be able to make your first torque controller and pitch controller.
Important: one important resource for these kind of documents is the link nrelpubs.nrel.gov/Webtop/ws/nich … SearchForm where you can search all the documents that you need (just saying so because I had some problem in searching these reports).
Remark: with this post I surely don’t want to complain about anything in this site, forum or documentation. It is just a post for the students like me that for the first time are studying a wind turbine control, and can have some problem in finding the correct material and the right files.
Anyway I would like to thank all the people in this forum that have created this great community where is possible to share and understand a lot about wind turbine.
Hope that someone can save time with this post ![]()
Giuseppe
MsC student in Aalborg University
