Dear @Jason.Jonkman ,
In fact, the curve i remake is using “EL centro” ,But i encounter error.So the curve maybe wrong.
The error follows:
OpenFAST
Copyright (C) 2024 National Renewable Energy Laboratory
Copyright (C) 2024 Envision Energy USA LTD
See the “LICENSE” file distributed with this software for details.
OpenFAST-v3.5.3
Compile Info:
- Compiler: Intel(R) Fortran Compiler 2021
- Architecture: 64 bit
- Precision: single
- OpenMP: No
- Date: Apr 11 2024
- Time: 20:51:36
Execution Info:
- Date: 10/18/2024
- Time: 11:21:57+0800
OpenFAST input file heading:
FAST Certification Test #18: NREL 5.0 MW Baseline Wind Turbine (Onshore)
Running ElastoDyn.
Running AeroDyn.
AD15 Nodal Outputs: Nodal output section of AeroDyn input file not found or improperly formatted.
Skipping nodal outputs.
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 1, blade 1)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 2, blade 1)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 3, blade 1)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 4, blade 1)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 1, blade 2)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 2, blade 2)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 3, blade 2)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 4, blade 2)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 1, blade 3)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 2, blade 3)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 3, blade 3)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 4, blade 3)
Running InflowWind.
Reading a 31x31 grid (145 m wide, 17.5 m to 162.5 m above ground) with a characteristic wind
speed of 12 m/s. This full-field file was generated by TurbSim (from OpenFAST-v3.5.3) on
13-Oct-2024 at 10:45:28.
Processed 12000 time steps of 20-Hz grid-field data (period of 600 seconds).
Running ExtPtfm_MCKF.
Running ServoDyn.
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows).
Using legacy Bladed DLL interface.
Time: 80 of 600 seconds. Estimated final completion at 11:24:47.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD_CalcOutput:RotCalcOutput:BEMT_CalcOut
put(node 5, blade 1):UA_CalcOutput:UA_BlendSteady:Temporarily turning off UA due to high angle of
attack or low relative velocity. This warning will not be repeated though the condition may
persist.
put(node 18, blade 2):UA_CalcOutput:Mach number exceeds 0.3. Theory is invalid. This warning will
not be repeated though the condition may persist.
Warning: SkewedWakeCorrection encountered a large value of chi (94.461 deg), so the yaw
correction will be limited. This warning will not be repeated though the condition may persist.
See the AD15 chi output channels, and consider turning off the Pitt/Peters skew model (set
SkewMod=1) if this condition persists.
violated in SUBROUTINE SmllRotTrans() due to a large blade deflection (ElastoDyn SetCoordSy). The
be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 83.862 s
Total Real Time: 2.9171 minutes
Total CPU Time: 2.8328 minutes
Simulation CPU Time: 2.8307 minutes
Simulated Time: 10 minutes
Time Ratio (Sim/CPU): 3.5327
OpenFAST terminated normally.
I don’t know why?maybe the Extptfm input is to strong and cause the blade have large deg.
Best regards.
