I downloaded OpenFASTv4.0.1 today.
I believe that with an onshore wind turbine, the seismic forces are input and the output is the load on the tower, etc.
Could you please tell me how to perform an analysis by inputting seismic forces?
Dear @Kazuya.Nishiyama,
Similar questions have been asked and answered in other forum topics, e.g.:
Question about Seismic.
Seismic Motions in OpenFAST
FYI: I have now forwarded you the Seismic archive of FAST v7 via WeTransfer as you requested via e-mail.
Thank you for sending.
Dear Jason
Do you have a file of an seismic analysis example with WP1.5MW?
The Seismic archive of FAST v7 uses examples based on the NREL 5-MW baseline wind turbine. I don’t have similar Seismic examples using the WindPACT 1.5-MW baseline wind turbine. That said, you can find FAST v7 models of the WindPACT 1.5-MW baseline wind turbine in the CertTest directory of the archive of FAST v7: https://www.nrel.gov/wind/nwtc/assets/downloads/FAST/FASTv7.02/FAST_v7.02.00d-bjj.exe. I would recommend starting with Test13 from the FAST v7 CertTest and enable Seismic functionality from that by setting PtfmModel = 1 and using the platform and seismic files from the NREL 5-MW baseline wind turbine examples from the Seismic archive.
Dear Jason.
Thank you for your response.
I was able to analyze it.
However, we are planning to do seismic analysis with openfast as we are told that visualization is not available.
Do you have any examples of seismic analysis with openfast?
I don’t have an example OpenFAST model with seismic functionality demonstrated, but the forum posts linked above explain how to set up OpenFAST with seismic excitation.
Dear Jason
I will refer to it.
Dear Jason.
I learned that there are two ways to do seismic load analysis: using the external platform or using the SoilDyn module.
Can you please tell me which one is better to use for analysis?
Also, could you please tell me how to install the SoilDyn module?
(Is there a file like SoilDyn.dat?)
Supplement to my question.
The analysis model is an onshore wind turbine of WP 1.5MW.
I would like to input the time history (time and acceleration) of seismic and perform an seismic load analysis.
I would suggest using the method based on external platform (ExtPtfm, CompSub = 2). SoilDyn has not yet been publicly released, but will be included in OpenFAST v5 later this year.
You can use your desired acceleration time history to compute the external force needed in ExtPtfm based on the method described in the forum posts linked above.
Dear Jason
I checked the other answer.
I have three question.
(I use 5MW_OCJckt_ExtPtfm as an example)
(1) The answer is as follows: am I correct in understanding that the time history of earthquake acceleration cannot be used and that the time history of forces and moments is required?
Answer↓
Yes, you can enable aerodynamics, etc. in an OpenFAST model with CompSub = 2.
The r-test example with CompSub = 2 that you are referencing has 6 Guyan modes + 25 Craig-Bampton modes, for a total of 31 DOFs, which is why the matrices are size 31. To model seismic loading following the approach in the old Seismic functionality of OpenFAST, you can disable all Craig-Bampton modes. In this case, CombSub = 2 should provide the 6x6 mass, damping, and stiffness matrices and 6x1 load vector for the Guyan modes. I would following the documentation from the Seismic functionality (https://www.nrel.gov/wind/nwtc/assets/pdfs/sr-5000-53872.pdf) to derive these matrices and load vector.
(2) What exactly does ExtPtfm indicate?
(Tower? Soil?).
(3) OpenFast-v5 going to add seismic function as well?
Here are my responses:
ExtPtfm can be thought of as a super-element representing the portion of the support structure not directly modeled in other parts of OpenFAST like ElastoDyn. For seismic excitation, ExtPtfm can be used to represent the mass, stiffness, damping, and force needed to impose an acceleration time history of the platform as explained in (1).
NREL is not currently funded to add seismic functionality to OpenFAST. NREL is certainly capable of adding such functionality, but would need funding to do it.
Dear Jason
Dear Jason
I have an additional question.
We would like to make a comparison with and without seismic input.
If I want to do this without seismic input, could you please tell me if I should set PtfmLdMod=0 in the Ptfm.dat file or PtfmModel=0 in the .fst file?
Is your question related to the seismic functionality of FAST v7 or OpenFAST with CompSub = 2?
Dear Jason
It is FAST v7.
To disable seismic excitation in the seismic version of FAST v7, you can set PtfmModel = 0 in the .fst file, or keep PtfmModel = 1 and in the platform input file, set PtfmLdMod = 0 while disabling all platform DOFs (PtfmSgDOF…PtfmYDOF = FALSE). Both approaches should have the same effect.
Dear Jason.
Little by little, I am beginning to understand it better.
Dear Jason
I am working on a seismic analysis with FAST.
I have a question about the El Centro earthquake input file that was originally included in the seisimic file.
I think this file has much smaller values than the actual acceleration of the El Centro seismic, why is this?
FAST El Centro seismic:MAX=about 0.2m/s^2
actual El Centro seismic MAX=about3.4m/s^2
