Sir,
I was working on monopile supported offshore wind turbine using FASTv8. When I was trying to run it FAST was aborting.
Running FAST (v8.16.00a-bjj, 27-Jul-2016), compiled as a 32-bit application using single
precision
linked with NWTC Subroutine Library (v2.09.00, 23-Jul-2016)
Heading of the FAST input file:
FAST Certification Test #19: NREL 5.0 MW Baseline Wind Turbine with OC3 Monopile RF
Configuration, for use in offshore analysis
Running ElastoDyn (v1.04.00a-bjj, 26-Jul-2016).
Running BeamDyn (v1.01.04, 26-Jul-2016).
Running AeroDyn (v15.03.00, 27-Jul-2016).
Running AirfoilInfo (v1.01.00a-bjj, 5-Apr-2016).
Running BEM (v1.02.00, 29-Jun-2016).
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 1, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 2, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 3, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 4, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 1, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 2, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 3, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 4, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 1, Blade = 3
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 2, Blade = 3
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 3, Blade = 3
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 4, Blade = 3
Running InflowWind (v3.03.00, 26-Jul-2016).
Opening InflowWind input file:
E:/softwares/Project/FAST/folder/5MW_Baseline/NRELOffshrBsline5MW_InflowWind_12mps.dat
Reading a 31x31 grid (145 m wide, 17.5 m to 162.5 m above ground) with a characteristic wind
speed of 11.4 m/s. This full-field file was generated by TurbSim (v1.06.00, 21-Sep-2012) on
18-Mar-2020 at 11:57:37.
Processed 12855 time steps of 20-Hz full-field data (642.7 seconds).
Running ServoDyn (v1.06.00a-bjj, 26-Jul-2016).
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows,
14-Oct-2015).
Running HydroDyn (v2.05.01, 27-Jul-2016).
Calculating second order difference frequency wave kinematics.
Calculating second order sum frequency wave kinematics.
Running SubDyn (v1.03.00, 11-Apr-2016).
Calculating Internal Modal Eigenvectors
Timestep: 0 of 630 seconds.
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies.
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 5, Blade = 1
FAST_Solution:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateStates(node 5, blade
1):BEMT_UnCoupledSolve:DeterminePhiBounds:There is no valid value of phi for these operating
conditions! Vx = 6.6517, Vy = -37.919, rlocal = 11.743, theta = 0.22769
FAST encountered an error at simulation time 1.50000E-02 of 630 seconds.
Aborting FAST.
I am not able to understand what are all those warnings. I got these warnings and error even after I adjusted the blade pitch angle according to my mean wind speed ( 0 degree for 11.4 m/s). How can I rectify these warnings and error.
Thank you.
