I am new to OpenFast & is still exploring. I tried to run the model from the location openfast-turbine-models/IEA-scaled/NREL-2.8-127/OpenFAST at master · NREL/openfast-turbine-models · GitHub
But got the following error.
Any help is highly appreciated.
OpenFAST input file heading:
Generated with AeroElasticSE FAST driver
Running ElastoDyn.
Running AeroDyn.
AD15 Nodal Outputs: Nodal output section of AeroDyn input file not found or improperly formatted.
Skipping nodal outputs.
Warning: Turning off Unsteady Aerodynamics because UA parameters are not included in airfoil
(airfoil has likely has constant polars). (node 1, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 2, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 3, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 4, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 5, blade 1)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 7, blade 1)
(airfoil has likely has constant polars). (node 1, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 2, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 3, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 4, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 5, blade 2)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 7, blade 2)
(airfoil has likely has constant polars). (node 1, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 2, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 3, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 4, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 5, blade 3)
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. (node 7, blade 3)
Running InflowWind.
FAST_InitializeAll:InflowWind_Init:Steady_ValidateInput: Horizontal wind speed (HWindSpeed) for
steady winds must be greater than zero.
OpenFAST encountered an error during module initialization.
Aborting OpenFAST.
