Turning off Unsteady aerodynamics and no valid value of phi.
Sir,
When I tried to run openfast on command prompt window openfast didn’t run and showed an error message that reinstalling the code may solve the problem. Then I changed my work file directory and tried to run it. And I again got this error.
C:\Users\Bhargav>E:\softwares\Project\openfast\offshore\openfast_x64.exe E:\softwares\Project\openfast\offshore\5MW_OC3Mnpl_DLL_WTurb_WavesIrr.fst
OpenFAST
Copyright (C) National Renewable Energy Laboratory
See the “LICENSE” file distributed with this software for details.
OpenFAST-v1.0.0-dirty
Compile Info:
  • Architecture: 64 bit
  • Precision: single
    Execution Info:
  • Date: 04/13/2020
  • Time: 20:24:35+0530
OpenFAST input file heading:
FAST Certification Test #19: NREL 5.0 MW Baseline Wind Turbine with OC3 Monopile RF
Configuration, for use in offshore analysis
Running ElastoDyn.
Running AeroDyn.
FAST_InitializeAll:AD_Init:ReadInputFiles:ReadPrimaryFile:Invalid logical input for file
"E:/softwares/Project/openfast/offshore/5MW_Baseline/NRELOffshrBsline5MW_OC3Monopile_AeroDyn15.dat
" occurred while trying to read TipLoss.
ReadPrimaryFile:Invalid numerical input for file
" occurred while trying to read IndToler.
" occurred while trying to read MaxIter.
Aborting OpenFAST.
And the Aerodyn input file I used was
------- AERODYN v15 for OpenFAST INPUT FILE -----------------------------------------------
NREL 5.0 MW offshore baseline aerodynamic input properties, with OC3 Monopile tower
True Echo - Echo the input to “.AD.ech”? (flag)
“default” DTAero - Time interval for aerodynamic calculations {or “default”} (s)
1 WakeMod - Type of wake/induction model (switch) {0=none, 1=BEMT, 2=DBEMT} [WakeMod cannot be 2 when linearizing]
2 AFAeroMod - Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model} [AFAeroMod must be 1 when linearizing]
1 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
False TwrShadow - Calculate tower influence on wind based on downstream tower shadow? (flag)
True TwrAero - Calculate tower aerodynamic loads? (flag)
False CavitCheck - Perform cavitation check? (flag) [AFAeroMod must be 1 when CavitCheck=true]
103500 Patm - Atmospheric pressure ¶ [used only when CavitCheck=True]
1700 Pvap - Vapour pressure of fluid ¶ [used only when CavitCheck=True]
0.5 FluidDepth - Water depth above mid-hub height (m) [used only when CavitCheck=True]
====== Blade-Element/Momentum Theory Options ====================================================== [unused when WakeMod=0]
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [unused when WakeMod=0]
“default” SkewModFactor - Constant used in Pitt/Peters skewed wake model {or “default” is 15/32*pi} (-) [used only when SkewMod=2; unused when WakeMod=0]
True TipLoss - Use the Prandtl tip-loss model? (flag) [unused when WakeMod=0]
True HubLoss - Use the Prandtl hub-loss model? (flag) [unused when WakeMod=0]
true TanInd - Include tangential induction in BEMT calculations? (flag) [unused when WakeMod=0]
False AIDrag - Include the drag term in the axial-induction calculation? (flag) [unused when WakeMod=0]
False TIDrag - Include the drag term in the tangential-induction calculation? (flag) [unused when WakeMod=0 or TanInd=FALSE]
“Default” IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or “default”} (-) [unused when WakeMod=0]
100 MaxIter - Maximum number of iteration steps (-) [unused when WakeMod=0]
====== Dynamic Blade-Element/Momentum Theory Options ============================================== [used only when WakeMod=2]
2 DBEMT_Mod - Type of dynamic BEMT (DBEMT) model {1=constant tau1, 2=time-dependent tau1} (-) [used only when WakeMod=2]
4 tau1_const - Time constant for DBEMT (s) [used only when WakeMod=2 and DBEMT_Mod=1]
3 UAMod - Unsteady Aero Model Switch (switch) {1=Baseline model (Original), 2=Gonzalez’s variant (changes in Cn,Cc,Cm), 3=Minemma/Pierce variant (changes in Cc and Cm)} [used only when AFAeroMod=2]
True FLookup - Flag to indicate whether a lookup for f’ will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
1 AFTabMod - Interpolation method for multiple airfoil tables {1=1D interpolation on AoA (first table only); 2=2D interpolation on AoA and Re; 3=2D interpolation on AoA and UserProp} (-)
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/Cylinder1.dat” AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/Cylinder2.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/DU40_A17.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/DU35_A17.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/DU30_A17.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/DU25_A17.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/DU21_A17.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/Airfoils/NACA64_A17.dat”
“E:/softwares/Project/openfast/offshore/5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
“E:/softwares/Project/openfast/offshore/5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
“E:/softwares/Project/openfast/offshore/5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
====== Tower Influence and Aerodynamics ============================================================= [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
11 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
TwrElev TwrDiam TwrCd
(m) (m) (-)
1.0000000E+01 6.0000000E+00 1.0000000E+00
1.7760000E+01 5.7870000E+00 1.0000000E+00
2.5520000E+01 5.5740000E+00 1.0000000E+00
3.3280000E+01 5.3610000E+00 1.0000000E+00
4.1040000E+01 5.1480000E+00 1.0000000E+00
4.8800000E+01 4.9350000E+00 1.0000000E+00
5.6560000E+01 4.7220000E+00 1.0000000E+00
6.4320000E+01 4.5090000E+00 1.0000000E+00
7.2080000E+01 4.2960000E+00 1.0000000E+00
7.9840000E+01 4.0830000E+00 1.0000000E+00
8.7600000E+01 3.8700000E+00 1.0000000E+00
True SumPrint - Generate a summary file listing input options and interpolated properties to “.AD.sum”? (flag)
0 NBlOuts - Number of blade node outputs [0 - 9] (-)
2, 9, 16, 4, 5, 7, 11, 13, 14 BlOutNd - Blade nodes whose values will be output (-)
1, 2, 3, 4, 5 TwOutNd - Tower nodes whose values will be output (-)
“RtAeroFxh, RtAeroFyh, RtAeroFzh”
“RtAeroMxh, RtAeroMyh, RtAeroMzh”
And Aerodyn echo file I got was
This file of echoed input was generated by AeroDyn on 13-Apr-2020 at 20:24:36.
Data from AeroDyn primary input file “E:/softwares/Project/openfast/offshore/5MW_Baseline/NRELOffshrBsline5MW_OC3Monopile_AeroDyn15.dat”:
           FTitle         - File Header: File Description (line 2)
“NREL 5.0 MW offshore baseline aerodynamic input properties, with OC3 Monopile tower”
        T  Echo           - Echo flag
           DTAero         - Time interval for aerodynamic calculations {or default} (s)
“default”
1 WakeMod - Type of wake/induction model {0=none, 1=BEMT} (-)
2 AFAeroMod - Type of airfoil aerodynamics model {1=steady model, 2=Beddoes-Leishman unsteady model} (-)
1 TwrPotent - Type tower influence on wind based on potential flow around the tower {0=none, 1=baseline potential flow, 2=potential flow with Bak correction} (-)
F TwrShadow - Calculate tower influence on wind based on downstream tower shadow? (flag)
T TwrAero - Calculate tower aerodynamic loads? (flag)
F FrozenWake - Assume frozen wake during linearization? (flag)
F CavitCheck - Perform cavitation check? (flag)
1.2250E+00 AirDens - Air density (kg/m^3)
1.4640E-05 KinVisc - Kinematic air viscosity (m^2/s)
3.3500E+02 SpdSound - Speed of sound (m/s)
1.0350E+05 Patm - Atmospheric pressure ¶
1.7000E+03 Pvap - Vapour pressure of fluid ¶
5.0000E-01 FluidDepth - Water depth above mid-hub height (MHK only, for cavitation check) (m)
        2  SkewMod        - Type of skewed-wake correction model {1=uncoupled, 2=Pitt/Peters, 3=coupled} [used only when WakeMod=1] (-)
        T  HubLoss        - Use the Prandtl hub-loss model? [used only when WakeMod=1] (flag)
        T  TanInd         - Include tangential induction in BEMT calculations? [used only when WakeMod=1] (flag)
        T  AIDrag         - Include the drag term in the axial-induction calculation? [used only when WakeMod=1] (flag)
        F  TIDrag         - Include the drag term in the tangential-induction calculation? [used only when WakeMod=1 and TanInd=TRUE] (flag)
           IndToler       - Convergence tolerance for BEM induction factors [used only when WakeMod=1] (-)
“False”
And in echo file tiploss was missing and IndToler was set as False. But in Aerodyn file it was set as default.
Dear Dhaneesh,
From these files, I would guess that you downloaded the r-test for the newest version of OpenFAST (v2.3), but you are using an older version of OpenFAST (1.0). You can either upgrade OpenFAST to v2.3 (github.com/OpenFAST/r-test/releases).
Sir,
I have upgraded openfast to v2.3 and tried to run it. Then openfast_Win32.exe was showing System Error like this.
The code execution cannot proceed because libifportMD.dll, libmmd.dll, libifcoremd.dll, svml_dispmd.dll were not found. Reinstalling the program
may fix this problem.
This was the system error message I got.
Dear Dhaneesh,
The question on how to resolve an error regarding libifcoremd.dll etc. has been answered on OpenFAST issues: github.com/OpenFAST/openfast/issues/352.
Sir,
Thank you for your suggestions and now I am able to run openfast. OPenfast has terminated normally but still I was getting warnings eventhough I was using aerodyn v15.04 version. So how can I overcome that warnings.
OpenFAST
Copyright (C) Envision Energy USA LTD
OpenFAST-v2.3.0
Compile Info:
  • Architecture: 32 bit
  • Precision: single
  • Date: Apr 03 2020
  • Time: 14:10:27
    Execution Info:
  • Date: 04/16/2020
  • Time: 21:25:31+0530
Running ElastoDyn.
Running AeroDyn.
Running BEM.
Running UnsteadyAero.
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 1, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 2, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 3, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 4, Blade = 1
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 1, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 2, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 3, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 4, Blade = 2
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 1, Blade = 3
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 2, Blade = 3
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 3, Blade = 3
Warning: Turning off Unsteady Aerodynamics because C_nalpha is 0. BladeNode = 4, Blade = 3
Running InflowWind.
Reading a 31x31 grid (145 m wide, 17.5 m to 162.5 m above ground) with a characteristic wind
speed of 12 m/s. This full-field file was generated by TurbSim (v1.06.00, 21-Sep-2012) on
28-Mar-2020 at 15:16:21.
Processed 12842 time steps of 20-Hz full-field data (642.05 seconds).
Running ServoDyn.
Running ServoDyn Interface for Bladed Controllers.
Running HydroDyn.
Calculating second order difference frequency wave kinematics.
Calculating second order sum frequency wave kinematics.
M2N3FDxi is not an available output channel.
M2N3FDyi is not an available output channel.
M2N3FDzi is not an available output channel.
M2N3FIxi is not an available output channel.
M2N3FIyi is not an available output channel.
M2N3FIzi is not an available output channel.
Running SubDyn.
Calculating Internal Modal Eigenvectors
Time: 0 of 630 seconds.
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies.
Total Real Time: 12.186 minutes
Total CPU Time: 11.299 minutes
Simulation CPU Time: 9.7563 minutes
Simulated Time: 10.5 minutes
Time Ratio (Sim/CPU): 1.0762
OpenFAST terminated normally.
Thank you.
Dear Dhaneesh,
The warnings about “turning off unsteady aerodynamics” applies to the unsteady airfoil aerodynamics (UA, dynamic stall) model for the first 4 nodes of each blade, which are the root / cylindrical sections of the airfoil where the UA model is not valid. The warnings are not indicating a problem with the simulation, but are expected in this case.
