Dear OpenFASTers,
I output the VTK in OpenFAST by configure the fst file as following:
2 WrVTK - VTK visualization data output: (switch) {0=none; 1=initialization data only; 2=animation; 3=mode shapes}
3 VTK_type - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
true VTK_fields - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
2 VTK_fps - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2 or WrVTK=3]
Then I get the HD_Morison.00.vtp and SD_LMesh_y2Mesh.00.vtp. These two vtp files only contain point data, but lack connectivity and offset for lines.
So I guess above two files only record the point mesh.
But if they can also record the connectivity for these points, we can animate the lines in paraview which can represent the members of substructure.
Is there a plan to postprocess the morison members and substructure members as lines in Paraview?
Ran Tu
