Dear Jason
I want to generate a wind field from TurbSim and put it in FAST.Farm, but it keeps giving me this error: “Error: FF wind array was exhausted at 2 seconds (trying to access data at -0.22222 seconds)”.
The steps I followed are :
(1) I Create a .bts file of wind field 1700m wide, 160m high, without turbulence and 18m/s at hub-height (90m), using TurbSim as following:
(2) I Put the file (Sample5MWTurbSim.bts in my case) in a folder named “Wind” and refer to it in the InflowWind.dat file of FAST.Farm:
(3) I Put the same grid size and points in FAST.Farm input file (.fstf) as the ones generated by TurbSim, and refer to InflowWind.dat in “InflowFile”:
(4) Finally, I run FAST.Farm, and it gives me the following error:
[code]
FAST.Farm
Copyright (C) 2017 National Renewable Energy Laboratory
See the “LICENSE” file distributed with this software for details.
FAST.Farm-v1.0.0-144-g254fc1a0-dirty
Compile Info:
- Architecture: 64 bit
- Precision: single
Execution Info:
- Date: 01/21/2021
- Time: 13:35:33+0100
Heading of the FAST.Farm input file:
Sample FAST.Farm input file
Running AWAE.
Running InflowWind.
Reading a 171x17 grid (1700 m wide, 10 m to 170 m above ground) with a characteristic wind
speed of 18 m/s. This full-field file was generated by TurbSim (v1.50, 25-Sep-2009) on
21-Jan-2021 at 12:52:42.
Processed 1945 time steps of 10-Hz full-field data (194.4 seconds).
Farm_Initialize:Farm_ValidateInput:OutFmt produces a column width of 10 instead of 14 characters.
Farm_Initialize:For efficiency, NumPlanes has been reduced to the number of time steps (51).
Farm_Initialize:InflowWind_CalcOutput:CalcOutput:IfW_TSFFWind_CalcOutput [position=(890, 0, 10)
in wind-file coordinates]: Error: FF wind array was exhausted at 2 seconds (trying to access data
at -0.22222 seconds).
a
Aborting FAST.Farm.[/code]
Can you help me with the issue ? Is it the right way to include a TurbSim file in FAST.Farm?
Kindest regards
Younes
