Hi, everyone.
It’s the first time that I write on this forum. I’m a engineering student in Korea, and a beginner of using FAST.
I have a problem that I cannot solve by myself well.
I want to simulate some cases with the “NRELOffshrBsline5MW_OC3Hywind” type.
I made my own wind files by using TurbSim, (mean V = 10ms, IECKAI type) and i use other factors with the files from the public directory folders. When I set the platform model to 0, it runs well, but when I set the platform model to 1 or 3, error is occurred. (Below)
D:\NREL data\NRELOffshrBsline5MW_OC3Hywind>fast PLT_3.fst
Running FAST (v7.00.00a-bjj, 31-Mar-2010).
Linked with NWTC Subroutine Library (v1.02.00, 16-Mar-2010).
Heading of the FAST input file: NREL 5.0 MW Baseline Wind Turbine for Use in Of
fshore Analysis.
Aerodynamic loads calculated using AeroDyn (v13.00.00a-bjj, 31-Mar-2010).
Heading of the AeroDyn input file: NREL 5.0 MW offshore baseline aerodynamic in
put properties;
Compatible with AeroDyn v12.58.
No file extension found. Assuming Wind\10ms_IECKAI is a binary FF wind file wit
h a “.wnd”
extension.
Reading a 13x13 grid (180 m wide, 4.10004E-02 m to 177.34 m above ground) with
a characterstic
wind speed of 10 m/s.
Processed 13801 time steps of 100-Hz full-field data (138 seconds).
ADAMS dataset file ‘PLT_3_ADAMS.adm’ created.
ADAMS command file ‘PLT_3_ADAMS.acf’ created.
WARNING message from DISCON.dll:
Running with torque and pitch control of the NREL offshore 5MW baseline wind tur
bine from
DISCON.dll as written by J. Jonkman of NREL/NWTC for use in the IEA Annex XXIII
OC3 studies.
Includes modifications for the Hywind spar.
Timestep: 2 of 120 seconds. Estimated final completion at 14:20:10.
Error: FF wind array boundaries violated. Grid too small in Z direction (height
(Z=-0.32841 m)
is below the grid and no tower points are defined).
Error getting velocity in AeroDyn/AD_WindVelocityWithDisturbance().
Aborting FAST.
I change some input values to correct the grid area. but it doesn’t work well. How can I solve this problem?
Thanks to your help
S.J.Baik
