Thank you very much for your help, its solved because i have used a 32 bit in 64 system
Tell me to share with you an other error, this time i thought related to the wind speed profile
In fact, i have searched on this kind of mistake and i found its response such as given in this link Error: FF wind array was exhausted - #2 by Jason.Jonkman
I have generated annoter wind profile with turbsim by modification the parameters( Gridheignt and Gridwidth and also Numgrid_Z and Numgrid_Y) in the wind file input, but without feasability, always an error occurs that you found attached. You found also the Turbsim file input of wind
If you would konw that i have use test18 of 5MW land wind turbine
Messages in MATLAB command window
Warning: block ‘PMSGWT/FAST Nonlinear Wind Turbine/S-Function’:
FAST_Solution:FAST_AdvanceStates:ED_ABM4:SetCoordSy:Small angle assumption violated in SUBROUTINE SmllRotTrans()
due to a large blade deflection (ElastoDyn SetCoordSy). The solution may be inaccurate. Simulation continuing, but
future warnings from SmllRotTrans() will be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 0.1375 s
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3
element #17 is supersonic! Other elements are likely supersonic as well. Supersonic mach nos. will be set to 0.7
to attempt continuation.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Supersonic
condition has subsided with Blade #1 element #4.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #1 element #17 is supersonic! Other elements are likely
supersonic as well. Supersonic mach nos. will be set to 0.7 to attempt continuation.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Supersonic condition has subsided with Blade #2 element #4.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #2 element #17 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Supersonic condition has subsided with Blade #3 element #4.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #17 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #1 element #16 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #2 element #16 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #16 is supersonic! Other elements are likely
WARNING: High VT velocity encountered during induction factor calculation.
Blade number 3, Element number 17
VNW = 3.0435, VT = -408.11
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #1 element #15 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #2 element #15 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #3 element #15 is supersonic! Other elements are likely
Blade number 1, Element number 17
VNW = 5.2892, VT = -411.69
Blade number 2, Element number 17
VNW = 5.6725, VT = -404.23
VNW = 2.8375, VT = -428.33
WARNING: High VNB velocity encountered during induction factor calculation.
Blade number 1, Element number 3
VNW = 5.4167, VNB = -113.44
WARNING: Induced velocity warning written 5 times. The message will not be repeated, though
the condition may persist.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #1 element #10 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Supersonic condition has subsided with Blade #1 element #13.
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #1 element #14 is supersonic! Other elements are likely
AD14_CalcOutput:ELEMFRC:BeddoesModel:ATTACH: Blade #2 element #13 is supersonic! Other elements are likely
FAST completed.
wind.txt (6.17 KB)
