Dear Readers,
I wish to get the angle of attack, lift and drag coefficients for each blade section node in the time domain. I believe this can be done using the aerodyn input file. I also wish to get the lift and drag forces on the sections. How can this be done in FAST ?
Subham
Dear @Kashyap.Subham,
If I understand correctly from other posts, you are using FAST v7, in which case, the local aerodynamic data that you want is available by setting the PrnElm column in the AeroDyn input file to PRINT at each element that you want these data for.
In AeroDyn v15 within OpenFAST, these aerodynamic data are available by adding the desired outputs to the OutList–see: 4.2.1.9. Appendix — OpenFAST v3.3.0 documentation.
Dear Sir,
I am using FAST v7 indeed. Where do i find the description of each column of the file generated when the print is enabled in Aerodyn input file. I get the following output channels in the file generated. Also, the generated file is really large which makes it difficult for post processing. Any suggestions in handling the same?
This file was generated by FAST(v7.02.00d-bjj, 20-Feb-2013) on 24-Jul-2022 at 01:54:08.
Time VX17 VY17 VZ17 Alpha01 DynPres01 CLift01 CDrag01 CNorm01 CTang01 CMomt01 Pitch01 AxInd01 TanInd01 ForcN01 ForcT01 Pmomt01 ReNum01 Alpha02 DynPres02 CLift02 CDrag02 CNorm02 CTang02 CMomt02 Pitch02 AxInd02 TanInd02 ForcN02 ForcT02 Pmomt02 ReNum02 Alpha03 DynPres03 CLift03 CDrag03 CNorm03 CTang03 CMomt03 Pitch03
Subham
The element output file generated with PrnElm set to PRINT is documented in the old AeroDyn User’s Guide: https://www.nrel.gov/wind/nwtc/assets/text/aerodyn.pdf.
I don’t believe anything can be done to the file size other than changing the time step or reducing the number of elements written to the file.
Dear Sir,
Thank you for the assistance. With every assistance of yours, I am discovering the immense effort you and the NREL team have put in to develop a tool like FAST.
Another query though:
VX(NELM) m/sec
ft/sec
The global X velocity of the wind at the most outboard element location.
This includes all shear and tower shadow effects, but no induced velocity
effects.
What is meant by the phrase “no induced velocity effects” ?
Subham
The induced velocity is the change in wind velocity caused by the interaction of the wind with the rotor (the impact of aerodynamic loads on the wind).
Dear Sir,
Thanks for the reply. I would also like to confirm if Fn and Ft obtained by aerodyn for each blade node represent the lift and drag force, respectively at the node under consideration.
Subham
Are you referring to old AeroDyn outputs ForcN and ForcT or AeroDyn v15 outputs Fn and Ft? ForcN and ForcT from the old AeroDyn are normal and tangential to the rotor plane. Fn and Ft from AeroDyn v15 are normal and tangential to the chord. Neither are lift and drag forces, which would normal and tangential to the local relative wind vector.
Dear Sir,
Is there a way I can derive the local lift and drag forces at the blade nodes? I am using the FAST v7 Seismic executable distributed in the Seismic archive zip file.
Subham
The PRINT option of AeroDyn v13 within FAST v7 can output the local aerodynamic quantities at each blade element. To calculate the local lift or drag forces, you can multiply Fl = CLift * DynPres * Chord and Fd = CDrag * DynPres * Chord.
Dear Jason Sir,
Throughout the literature, I have seen that the lift and drag coefficients are plotted with the angle of attack of the local airfoil sections. And similar data in a tabular format is given as input to the aerodyn code in the blade airfoil files.
At the same time, I wish to make similar plots between lift and angle of attack for an operational wind turbine using FAST. By printing the output file with results at various nodes, I get the time series for Cl, Cd, Alpha, etc. How do I get curves Cl vs. Alpha from these time series? I am trying to illustrate the dynamic stall condition.
Thank You
Subham
Once you output the angle of attach and lift coefficient time series, you can plot these series against each other to illustrate dynamic stall. Such a plot should match what you input when unsteady airfoil aerodynamics is disabled (AFAeroMod = 1).
Dear Sir,
The output file using the Aerodyn, gives data with 25 entries for each time step. Why do I get 25 data points for the time step? Is it some printing error in the source code, or is it a manifestation of the semi-empirical model utilized in Aerodyn? I am using the Aerodyn version in the seismic module package.
Subham
I’m not sure I understand your question. By “25 entries”, are you referring to the columns of tabular time-series output? For AeroDyn within the Seismic version of FAST v7, which uses AeroDyn v13, the AeroDyn outputs are dictated by the PRINT/NOPRINT flags specified at each aerodynamic analysis node in the AeroDyn v13 input file.
Dear @Jason.Jonkman
I am very interested in the dynamic stall condition and have also read your discussion on dynamic stall above. I am currently attempting to construct this operating condition in OPENFAST and calculate the blade response of the IEA 15MW wind turbine model under different aerodynamic load calculation methods (such as BEM method, OLAF method). Unfortunately, I did not observe an Alpha- Cl curve that could reveal dynamic stall conditions even though I have set AFAeroMod to 1. I simulated a series of velocity gradients between the cut in and cut out wind speeds, and recorded the Alpha and Cl at different nodes of the blades at each wind speed. My previous understanding was that as the wind speed increased, dynamic stall would occur. But in fact, except for the nodes near the blade root, most nodes have obtained small Alpha values (less than 10), which cannot meet the required Alpha for dynamic stall. Will there be no dynamic stall phenomenon below the cut-off wind speed? I think this is unreasonable. So could you please tell me how to simulate dynamic stall conditions and adjust which parameters can achieve the expected results? Here are my settings for some modules(This setting is applied to wind speeds of 16m/s)
Dear @Xiang.Wang,
Actually, AFAeroMod = 1 corresponds to quasi-steady blade airfoil aerodynamics. If you want to model unsteady airfoil aerodynamics, including dynamic stall, you’d have to set AFAeroMod = 2.
Can you clarify what wind condition(s) you are simulating? If the wind speed you are using is steady or only slowly varying, I would expect the torque and pitch controller to keep the blade in a region where dynamic stall would be minimal anyway. Dynamic stall would more common if you are considering full-field turbulence, or highly sheared or highly skewed flow.
Dear sir
Thank you for your reply. I used Turbsim to generate turbulent wind during the simulation. I should have found the problem by now. When drawing the Alpha -Cl curve, I first counted the mean of the two in the time domain and then plotted them against each other, which proved to be a very unwise behavior because it completely ignored the temporal characteristic of turbulent wind. Based on your guidance above, I successfully observed the dynamic stall by recording the values of Cl and Alpha at each time step during a short period of simulation time (such as 10s) and plotting them against each other. Thank you again for your guidance.
Wang
