Dear @Jason.Jonkman,
Hope you are doing well.
I want to ask you whether there is a MATLAB (or Python) function that writes a .bts file ?
Thank you in advance.
Riad
Riad
Dear @Riad.Elhamoud
Dear Abhay,
Python script turbsim_file.py in the openFAST-Toolbox reads and writes binary formatted TurbSim (.bts) files: openfast_toolbox/openfast_toolbox/io/turbsim_file.py at main Ā· OpenFAST/openfast_toolbox Ā· GitHub.
From the matlab-toolbox, there is a script readfile_BTS.m that will read a TurbSim binary file into the MATLAB workspace: matlab-toolbox/Utilities at main Ā· OpenFAST/matlab-toolbox Ā· GitHub. Iām not aware that an equivalent MATLAB-based script to write a TurbSim binary file has been developed, but Iām sure that would be possible using readfile_BTS.m as a starting point.
Python codes are also available, see here WEIS/weis/aeroelasticse/turbsim_util.py at develop Ā· WISDEM/WEIS Ā· GitHub
Iām attempting to generate a BTS file using a user-defined time series file. However, Iāve noticed that in the resulting wind file, both the v and w components are zero. Iām unsure how to proceed.
When I try to use the āIECKAIā TurbModel, it appears that I canāt utilize the time series file. This seems to contradict the comments in the INP file. However, upon reviewing the user manual, I found that time series can only be used with the TIMESR turbulence model.
Iāve attached the relevant files for reference. Here is key information:
This summary file was generated by TurbSim on 13-Aug-2024 at 17:35:04.
Runtime Options:
123456 Random seed #1
RANLUX Type of random number generator
F Output binary HH turbulence parameters?
F Output formatted turbulence parameters?
F Output AeroDyn HH files?
T Output AeroDyn FF files?
F Output BLADED FF files?
F Output tower data?
F Output formatted FF files?
F Output coherent turbulence time step file?
T Clockwise rotation when looking downwind?
0 - NONE IEC turbulence models scaled to exact specified standard deviation
Turbine/Model Specifications:
45 Vertical grid-point matrix dimension
61 Horizontal grid-point matrix dimension
0.500 Time step [seconds]
5000.000 Analysis time [seconds]
5000.000 Usable output time [seconds]
115.000 Hub height [m]
220.000 Grid height [m]
300.000 Grid width [m]
0.000 Vertical flow angle [degrees]
0.000 Horizontal flow angle [degrees]
Meteorological Boundary Conditions:
TIMESR User-input time series spectral model
N/A IEC standard
N/A IEC turbulence characteristic
N/A IEC turbulence type
N/A IEC Extreme Turbulence Model (ETM) "c" parameter [m/s]
PL Wind profile type
90.000 Reference height [m]
10.000 Reference wind speed [m/s]
N/A Jet height [m]
0.130 Power law exponent
0.030 Surface roughness length [m]
Non-IEC Meteorological Boundary Conditions:
45.000 Site latitude [degrees]
0.050 Gradient Richardson number
0.480 Friction or shear velocity [m/s]
N/A Mixing layer depth [m]
N/A Mean hub u'w' Reynolds stress
N/A Mean hub u'v' Reynolds stress
N/A Mean hub v'w' Reynolds stress
Spatial Coherence Models:
IEC u-component coherence model
IEC v-component coherence model
IEC w-component coherence model
( 12.000, 0.659E-03) u-component coherence parameters
( 12.000, 0.659E-03) v-component coherence parameters
( 12.000, 0.659E-03) w-component coherence parameters
N/A Coherence exponent
Profiles from User-Defined Time-Series Input:
Height Wind Speed Horizontal Angle Vertical Angle
(m) (m/s) (deg) (deg)
105.00 12.20 15.00 7.25
105.00 12.14 15.00 7.25
75.00 10.97 15.00 7.25
75.00 10.77 15.00 7.25
You have requested that the following file(s) be generated:
leice.bts (AeroDyn/TurbSim full-field wind file)
Turbulence Simulation Scaling Parameter Summary:
Turbulence model used = User-input time series
Gradient Richardson number = 0.050
Monin-Obukhov (M-O) z/L parameter = 0.067
Monin-Obukhov (M-O) length scale = 1725.000 m
Mean wind speed at hub height = 10.324 m/s
Wind profile type = Power law
Power law exponent = 0.130
Mean shear across rotor disk = 0.020 (m/s)/m
Assumed rotor diameter = 220.000 m
Surface roughness length = 0.030 m
Nyquist frequency of turbulent wind field = 1.000 Hz
Number of time steps in the FFT = 10000
Number of time steps output = 10000
Number of points simulated = 2747
Mean Flow Angles:
Vertical = 0.0 degrees
Horizontal = 0.0 degrees
Mean Wind Speed Profile:
Height Wind Speed Horizontal Angle Vertical Angle U-comp (X) V-comp (Y) W-comp (Z)
(m) (m/s) (degrees) (degrees) (m/s) (m/s) (m/s)
225.0 11.27 0.00 0.00 11.27 0.00 0.00
220.0 11.23 0.00 0.00 11.23 0.00 0.00
215.0 11.20 0.00 0.00 11.20 0.00 0.00
210.0 11.16 0.00 0.00 11.16 0.00 0.00
205.0 11.13 0.00 0.00 11.13 0.00 0.00
200.0 11.09 0.00 0.00 11.09 0.00 0.00
195.0 11.06 0.00 0.00 11.06 0.00 0.00
190.0 11.02 0.00 0.00 11.02 0.00 0.00
185.0 10.98 0.00 0.00 10.98 0.00 0.00
180.0 10.94 0.00 0.00 10.94 0.00 0.00
175.0 10.90 0.00 0.00 10.90 0.00 0.00
170.0 10.86 0.00 0.00 10.86 0.00 0.00
165.0 10.82 0.00 0.00 10.82 0.00 0.00
160.0 10.78 0.00 0.00 10.78 0.00 0.00
155.0 10.73 0.00 0.00 10.73 0.00 0.00
150.0 10.69 0.00 0.00 10.69 0.00 0.00
145.0 10.64 0.00 0.00 10.64 0.00 0.00
140.0 10.59 0.00 0.00 10.59 0.00 0.00
135.0 10.54 0.00 0.00 10.54 0.00 0.00
130.0 10.49 0.00 0.00 10.49 0.00 0.00
125.0 10.44 0.00 0.00 10.44 0.00 0.00
120.0 10.38 0.00 0.00 10.38 0.00 0.00
115.0 10.32 0.00 0.00 10.32 0.00 0.00
110.0 10.26 0.00 0.00 10.26 0.00 0.00
105.0 10.20 0.00 0.00 10.20 0.00 0.00
100.0 10.14 0.00 0.00 10.14 0.00 0.00
95.0 10.07 0.00 0.00 10.07 0.00 0.00
90.0 10.00 0.00 0.00 10.00 0.00 0.00
85.0 9.93 0.00 0.00 9.93 0.00 0.00
80.0 9.85 0.00 0.00 9.85 0.00 0.00
75.0 9.77 0.00 0.00 9.77 0.00 0.00
70.0 9.68 0.00 0.00 9.68 0.00 0.00
65.0 9.59 0.00 0.00 9.59 0.00 0.00
60.0 9.49 0.00 0.00 9.49 0.00 0.00
55.0 9.38 0.00 0.00 9.38 0.00 0.00
50.0 9.26 0.00 0.00 9.26 0.00 0.00
45.0 9.14 0.00 0.00 9.14 0.00 0.00
40.0 9.00 0.00 0.00 9.00 0.00 0.00
35.0 8.84 0.00 0.00 8.84 0.00 0.00
30.0 8.67 0.00 0.00 8.67 0.00 0.00
25.0 8.47 0.00 0.00 8.47 0.00 0.00
20.0 8.22 0.00 0.00 8.22 0.00 0.00
15.0 7.92 0.00 0.00 7.92 0.00 0.00
10.0 7.52 0.00 0.00 7.52 0.00 0.00
5.0 6.87 0.00 0.00 6.87 0.00 0.00
Harvested Random Seeds after Generation of the Random Numbers:
382863125 K 1
0 K 2
Hub-Height Simulated Turbulence Statistical Summary:
Type of Wind Min (m/s) Mean (m/s) Max (m/s) Sigma (m/s) TI (%)
Longitudinal (u) 8.46 10.32 12.12 0.524 5.072
Lateral (v) -0.00 0.00 0.00 0.000 0.000
Vertical (w) -0.00 -0.00 0.00 0.000 0.000
U component 8.46 10.32 12.12 0.524 5.072
V component -0.00 0.00 0.00 0.000 0.000
W component -0.00 -0.00 0.00 0.000 0.000
Horizontal (U&V) 8.46 10.32 12.12 0.524 5.072
Total 8.46 10.32 12.12 0.524 5.072
Min Reynolds Mean Reynolds Max Reynolds Correlation
Product Stress (m/s)^2 Stress (m/s)^2 Stress (m/s)^2 Coefficient
u'w' -0.000 -0.000 0.000 -0.004
u'v' -0.000 0.000 0.000 0.002
v'w' -0.000 0.000 0.000 0.028
Friction Velocity (Ustar) = 0.000 m/s
Maximum Instantaneous TKE = 1.740 (m/s)^2
Maximum Instantaneous CTKE = 0.000 (m/s)^2
Any insights or suggestions would be greatly appreciated.
Has anyone else experienced similar issues or know of a workaround? Thank you in advance for your help!
usr-turbsim
Best Regrads,
Junius
Dear @Jundong.Wang,
Iām not sure why the v and w components are showing up as zeros when you specified nonzero values, but I found a couple oddities in your inputs:
RefPtID) is outside the grid altogetherI would first suggest using one user-specified point, placing this point within the domain, and ensuring that the v and w components have zero mean.
Also, which version of TurbSim are you running?
Dear @Jason.Jonkman ,
Thank you for your reply. I misunderstood the definition of pointyi, thinking it referred to the global coordinate system, but Iāve made the necessary adjustments.
BTW, Turbsim version information:
TurbSim
Copyright (C) 2021 National Renewable Energy Laboratory
Copyright (C) 2021 Envision Energy USA LTD
TurbSim-v2.5.0-648-g2221ba53
Compile Info:
- Compiler: GCC version 9.3.0
- Architecture: 64 bit
- Precision: single
- Date: Apr 6 2021
- Time: 21:20:00
Execution Info:
- Date: 08/15/2024
- Time: 11:21:42+0800
Following your suggestions, I tested three scenarios: single-point data, data from two points at the same height, and data from two points at different heights on the same side. Unfortunately, the velocity components v and w both have zero results.
Iāve uploaded the relevant files to OneDrive for your review. Iām also examining the source code, and Iāll share any updates here.
Dear @Jundong.Wang,
I would first focus on the singe-point test (leice-test1.inp). I still see that the mean value of your user-specified v and w components have a sizeable nonzero mean. Do the results make more sense if you remove this mean?
Also, does upgrading to the newest version of TurbSim provided with OpenFAST resolve the issue: https://github.com/OpenFAST/openfast/releases/download/v3.5.3/TurbSim_x64.exe.
@Jason.Jonkman ,
Thank you so much for your suggestion. Iāve been using the latest version of TurbSim for the simulation. I apologize for only just noticing the issue you mentioned about the non-zero mean of the v and w velocity components. I suspect the reason the simulation results were zero is that the wind speed data I provided has significant values in both the horizontal and vertical directions, whereas I intended for the data to generate as zero. However, it seems there are also quite a bit of fluctuations in the reference documents provided by TurbSim. Iām unsure how the average inflow angle is set.
Once I removed the time average from the v and w components, the program ran properly. You can check it out from the following link:
3 items
Thanks to your kind reminder.
I may need to further confirm if I should adjust the average inflow angle at different height layers by modifying the source code to better match the data.
Junius
Dear @Jundong.Wang,
Iām glad that solved the problem. TurbSim generally works by superimposing turbulent fluctuations with zero mean with a mean wind profile. The mean wind profile can include a change of wind speed with height (shear) as well as a change in wind direction with height (veer), depending on what profile youāve selected.
