Hello everyone,
I write a MATLAB code that permits to draw the full stochastic turbulent wind speed field magnitude generated by TURBSIM. This code makes use of the function readfile_BTS.m written by Bonnie JONKMAN (NREL).
%%%%%%% Start of the code%%%%%%%%%%%%%%%%%%%%%%%%
%%% draw the full stochastic turbulent wind speed field magnitude
[velocity, twrVelocity, y, z, zTwr, nz, ny, dz, dy, dt, zHub, z1,mffws] = readfile_BTS(bts file path);
velocity_magnitude=zeros(length(velocity(:,1,1,1)),ny,nz); % Definition of a 3D array
for i=1:nz
for j=1:ny
velocity_magnitude(:,j,i)=sqrt(velocity(:,1,j,i).^2 + velocity(:,2,j,i).^2 + velocity(:,3,j,i).^2);
end
end
time=linspace(0,(length(velocity_magnitude(:,1,1))-1)*dt,length(velocity_magnitude(:,1,1)));
[mesh_grid_y,mesh_grid_time,mesh_grid_z]=meshgrid(y,time,z);
x_slice=[ ];
y_slice=linspace(0,(length(velocity_magnitude(:,1,1))-1)*dt,1000);
z_slice=[ ];
slice(mesh_grid_y,mesh_grid_time,mesh_grid_z,velocity_magnitude,x_slice,y_slice,z_slice)
xlabel(“Lateral distance from the tower (m)”)
ylabel(“Time (s)”)
zlabel(“Height (m)”)
shading interp;
c=colorbar;
c.Label.String=“Magnitude of wind speed (m/s)”;
%%%%%%END of the code%%%%%%%%%%%%%%%%%%%%%%%%%%
The execution of my bts file leads to the following full stochastic turbulent wind speed field magnitude.
N.B: I am using MATLAB R2021a
Hope that code helps ![]()
Riad
