Hi Bonnie,
I’ve successfully implemented the following code for writing wnd files.
We use it to add EOGs to windfield data.
Maybe someone has similar needs.
Thanks again for your support!
Stefan
function writeBLgrid(FileName, velocity, dy, dz, dt, zOffset, z0, SummVars)
% writeBLgrid('testWind', velocity, dy, dz, dt, zOffset, z0, SummVars)
% writes wind velocity data to binary .wnd files
% inputs - FileName: Name of output .wnd-file (extension will be added)
% - velocity: 4D-array: (time, 3D-windcomp, y, z)
% - dz
% - dy
% - dt
% - SummVars: 6 variables from the summary file {zHub, Clockwise, UBAR, TI_u, TI_v, TI_w}
% 90 1 12 12 9.6 6
% - zOffset: (=90) Reference height (m) = Z(1) + GridHeight / 2.0
% - z0 = .03; Roughness length (m)
% INITIALIZE VARIABLES
fileFmt = 'int16';
fc = 4; % should be 4 to allow turbulence intensity to be stored in the header
lat = 0; % latitude (deg)
zHub = SummVars(1); % hub height [m]
MFFWS = SummVars(3); % mean full-field wind speed
TI_U = SummVars(4); % Turbulence Intensity of u component (%)
TI_V = SummVars(5); % Turbulence Intensity of v component (%)
TI_W = SummVars(6); % Turbulence Intensity of w component (%)
[nt, nffc, ny nz] = size(velocity); % determin dimensions of windfield, e.g. [1286,3,23,23]
z1 = zHub - dz*(nz-1)/2; %this is the bottom of the grid
dx = dt*MFFWS; % delta x in m
nt_header = floor(nt/2);% half the number of time steps
% OPEN FILE
len = length(FileName);
ending = FileName(len-3:len);
if strcmpi( ending, '.wnd' )
FileName = FileName(1:len-4);
end
fid_wnd = fopen( [ FileName '.wnd' ], 'w' ); % Open file, or create new file, for writing; discard existing contents, if any.
if ( fid_wnd <= 0 )
error( 'Wind file could not be opened.' );
return;
end
%WRITE THE HEADER OF THE BINARY FILE
% THE NEWER-STYLE AERODYN WIND FILE
fwrite( fid_wnd, -99, 'int16' ); % number of components
fwrite( fid_wnd, fc, 'int16' ); % should be 4 to allow turbulence intensity to be stored in the header
fwrite( fid_wnd, nffc, 'int32' ); % number of components (should be 3)
fwrite( fid_wnd, lat, 'float32' ); % latitude (deg)
fwrite( fid_wnd, z0, 'float32' ); % Roughness length (m)
fwrite( fid_wnd, zOffset, 'float32' ); % Reference height (m) = Z(1) + GridHeight / 2.0
fwrite( fid_wnd, TI_U, 'float32' ); % Turbulence Intensity of u component (%)
fwrite( fid_wnd, TI_V, 'float32' ); % Turbulence Intensity of v component (%)
fwrite( fid_wnd, TI_W, 'float32' ); % Turbulence Intensity of w component (%)
fwrite( fid_wnd, dz, 'float32' ); % delta z in m
fwrite( fid_wnd, dy, 'float32' ); % delta y in m
fwrite( fid_wnd, dx, 'float32' ); % delta x in m
fwrite( fid_wnd, nt_header, 'int32' ); % half the number of time steps
fwrite( fid_wnd, MFFWS, 'float32'); % mean full-field wind speed
fwrite( fid_wnd, [0 0 0], 'float32' ); % unused variables (for BLADED): write zeros
fwrite( fid_wnd, [0 0], 'int32' ); % unused variables (for BLADED): write zeros
fwrite( fid_wnd, nz, 'int32' ); % number of points in vertical direction
fwrite( fid_wnd, ny, 'int32' ); % number of points in horizontal direction
fwrite( fid_wnd, zeros(3*(nffc-1),1), 'int32' ); % unused variables (for BLADED): write zeros
% WRITE GRID DATA
Scale = 0.00001*SummVars(3)*SummVars(4:6);
Offset = [SummVars(3) 0 0];
if SummVars(2) > 0 %clockwise rotation
%flip the y direction....
%let's change the dimension of velocity so that it's 4-d instead of 3-d
y_ix = ny:-1:1;
else
y_ix = 1:ny;
end
v = zeros(nz*ny*nffc,1);
for it = 1:nt
cnt = 1;
for iz = 1:nz
for iy = y_ix
for k=1:nffc
v(cnt) = (velocity(it,k,iy,iz) - Offset(k))/Scale(k);
cnt = cnt + 1;
%velocity(it,k,iy,iz) = v(cnt2)*Scale(k) + Offset(k);
end %for k
end %iy
end % iz
fwrite( fid_wnd, v, fileFmt );
end %it
% CLOSE .WND FILE
fclose(fid_wnd);
