I try to reach the simulation of OC4 phase1 case study with FAST 8.16, since the stream function is required for the wave condition of load case 5.6 (please find the pic. below),i generated an external wave profile by SACS for this case and set the Wavemod = 5 in hydrodyn.
when i tried to start the FAST in cmd, it indicated the error msg like :
[i] Running HydroDyn (v2.05.01, 27-Jul-2016).
FAST_InitializeAll:HydroDyn_Init:HydroDynInput_ProcessInitData:WaveTp must be greater than zero.
Simulation error level: FATAL ERROR[/i]
I am confused with the error msg because the instruction in the Hydondyn only shows “Wavetp only used when Wavemod =1 or 2”
If Wavetp is compulsory for Wavemod = 5 as well, should i set WaveTp = 8 as the wave condition in load case 5.6?
Many Thanks.
