Hello everyone.
I am using FAST.Farm to do research on wakes caused by wind turbines.
I performed simulations under the following conditions to investigate the direction of wake deflection and velocity deficit rate when nacelle yaw is varied.
・Wind speed →18m/s steady
・Wave length →still water
・Nac yaw →30deg
・Mod_Wake →1(Polar wake model)
・IEA15MW turbine and UMaine VolturnUS-S Reference Platform
As the wind passes through the turbine, the velocity vector in the direction of the axis of rotation decreases and the velocity vector in the direction perpendicular to the axis of rotation does not change, so the wake would be deflected in the sway negative direction.
Below the rated wind speed, the wake was deflected in the negative Sway direction as expected, but above the rated wind speed, the wake was deflected in the positive Sway direction as shown in the figure.
I would like to know about the following two questions.
・Does the direction of wake deflection change when the wind speed is above or below the rated wind speed?
・Are there any papers that summarize the behavior of wake flow above rated wind speeds?
Dear @Yuki.Ogura,
I would not expect the direction of the wake deflection to change between below and above-rated wind speeds. For positive nacelle-yaw (counterclockwise, when viewed from above), I would expect the wake deflect to the right when looking downwind.
I’m not sure why your results are not showing this. Can you clarify your simulation set-up (share your FAST.Farm input file)?
FYI: The curled wake model is known to generate a more accurate wake in skewed (yawed) inflow conditions. I’m not sure why your polar wake model solution is not giving you the results you expect, but we generally recommend using the curled wake model under skewed inflow conditions regardless.
Here are the fstf and ElastoDyn files I use.
Please let me know if there is any other information you need.
------- FAST.Farm for OpenFAST INPUT FILE -------------------------------------------------
FAST.Farm input file, using two turbines separated by 3D downstream and an offset of 30m, with a turbulent inflow given by one turbsim box
--- SIMULATION CONTROL ---
False Echo - Echo input data to <RootName>.ech? (flag)
FATAL AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
4500 TMax - Total run time (s) [>=0.0]
False UseSC - Use a super controller? (flag)
2 Mod_AmbWind - Ambient wind model (-) (switch) {1: high-fidelity precursor in VTK format, 2: one InflowWind module, 3: multiple instances of InflowWind module}
2 Mod_WaveField - Wave field handling (-) (switch) {1: use individual HydroDyn inputs without adjustment, 2: adjust wave phases based on turbine offsets from farm origin}
0 Mod_SharedMooring - Shared mooring system model (switch) {0: None, 3=MoorDyn}}
--- SUPER CONTROLLER --- [used only for UseSC=True]
"unused" SC_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} containing the Super Controller algorithms (quoated string)
--- SHARED MOORING SYSTEM --- [used only for Mod_SharedMoor>0]
"" SharedMoorFile - Name of file containing shared mooring system input parameters (quoted string) [used only when Mod_SharedMooring > 0]
0.04 DT_Mooring - Time step for farm-level mooring coupling with each turbine (s) [used only when Mod_SharedMooring > 0]
--- AMBIENT WIND: PRECURSOR IN VTK FORMAT --- [used only for Mod_AmbWind=1]
30.0 DT_Low-VTK - Time step for low -resolution wind data input files; will be used as the global FAST.Farm time step (s) [>0.0]
1.0 DT_High-VTK - Time step for high-resolution wind data input files (s) [>0.0]
"unused" WindFilePath - Path name to VTK wind data files from precursor (string)
False ChkWndFiles - Check all the ambient wind files for data consistency? (flag)
--- AMBIENT WIND: INFLOWWIND MODULE --- [used only for Mod_AmbWind=2 or 3]
3.0 DT_Low - Time step for low -resolution wind data interpolation; will be used as the global FAST.Farm time step (s) [>0.0]
0.1 DT_High - Time step for high-resolution wind data interpolation (s) [>0.0]
90 NX_Low - Number of low -resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
51 NY_Low - Number of low -resolution spatial nodes in Y direction for wind data interpolation (-) [>=2]
51 NZ_Low - Number of low -resolution spatial nodes in Z direction for wind data interpolation (-) [>=2]
-408 X0_Low - Origin of low -resolution spatial nodes in X direction for wind data interpolation (m)
-500 Y0_Low - Origin of low -resolution spatial nodes in Y direction for wind data interpolation (m)
5.0 Z0_Low - Origin of low -resolution spatial nodes in Z direction for wind data interpolation (m)
54.0 dX_Low - Spacing of low -resolution spatial nodes in X direction for wind data interpolation (m) [>0.0]
20.0 dY_Low - Spacing of low -resolution spatial nodes in Y direction for wind data interpolation (m) [>0.0]
20.0 dZ_Low - Spacing of low -resolution spatial nodes in Z direction for wind data interpolation (m) [>0.0]
52 NX_High - Number of high-resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
52 NY_High - Number of high-resolution spatial nodes in Y direction for wind data interpolation (-) [>=2]
52 NZ_High - Number of high-resolution spatial nodes in Z direction for wind data interpolation (-) [>=2]
"InflowWind_01.dat" InflowFile - Name of file containing InflowWind module input parameters (quoted string)
--- WIND TURBINES ---
1 NumTurbines - Number of wind turbines (-) [>=1] [last 6 columns below used only for Mod_AmbWind=2 or 3]
WT_X WT_Y WT_Z WT_FASTInFile X0_High Y0_High Z0_High dX_High dY_High dZ_High
(m) (m) (m) (string) (m) (m) (m) (m) (m) (m)
0.0 0.0 0.0 "FFTest_WT1_01.fst" -255 -255 5.0 10.0 10.0 10.0
--- WAKE DYNAMICS ---
1 Mod_Wake - Switch between wake formulations {1:Polar, 2:Curl, 3:Cartesian} (-) (switch)
5.0 dr - Radial increment of radial finite-difference grid (m) [>0.0]
80 NumRadii - Number of radii in the radial finite-difference grid (-) [>=2]
136 NumPlanes - Number of wake planes (-) [>=2]
0.007 f_c - Cutoff (corner) frequency of the low-pass time-filter for the wake advection, deflection, and meandering model [recommended=1.28*U0/R] (Hz) [>0.0] or DEFAULT [DEFAULT=12.5/R, R estimated from dr and NumRadii, not recommended]
DEFAULT C_HWkDfl_O - Calibrated parameter in the correction for wake deflection defining the horizontal offset at the rotor (m ) or DEFAULT [DEFAULT= 0.0 ]
DEFAULT C_HWkDfl_OY - Calibrated parameter in the correction for wake deflection defining the horizontal offset at the rotor scaled with yaw error (m/deg) or DEFAULT [DEFAULT= 0.0 if Mod_Wake is 2, 0.3 otherwise]
DEFAULT C_HWkDfl_x - Calibrated parameter in the correction for wake deflection defining the horizontal offset scaled with downstream distance (- ) or DEFAULT [DEFAULT= 0.0 ]
DEFAULT C_HWkDfl_xY - Calibrated parameter in the correction for wake deflection defining the horizontal offset scaled with downstream distance and yaw error (1/deg) or DEFAULT [DEFAULT= 0.0 if Mod_Wake is 2, -0.004 otherwise]
DEFAULT C_NearWake - Calibrated parameter for the near-wake correction (-) [>1.0 and <2.5] or DEFAULT [DEFAULT=1.8]
DEFAULT k_vAmb - Calibrated parameter for the influence of ambient turbulence in the eddy viscosity (-) [>=0.0] or DEFAULT [DEFAULT=0.05 ]
DEFAULT k_vShr - Calibrated parameter for the influence of the shear layer in the eddy viscosity (-) [>=0.0] or DEFAULT [DEFAULT=0.016]
DEFAULT C_vAmb_DMin - Calibrated parameter in the eddy viscosity filter function for ambient turbulence defining the transitional diameter fraction between the minimum and exponential regions (-) [>=0.0 ] or DEFAULT [DEFAULT= 0.0 ]
DEFAULT C_vAmb_DMax - Calibrated parameter in the eddy viscosity filter function for ambient turbulence defining the transitional diameter fraction between the exponential and maximum regions (-) [> C_vAmb_DMin ] or DEFAULT [DEFAULT= 1.0 ]
DEFAULT C_vAmb_FMin - Calibrated parameter in the eddy viscosity filter function for ambient turbulence defining the value in the minimum region (-) [>=0.0 and <=1.0] or DEFAULT [DEFAULT= 1.0 ]
DEFAULT C_vAmb_Exp - Calibrated parameter in the eddy viscosity filter function for ambient turbulence defining the exponent in the exponential region (-) [> 0.0 ] or DEFAULT [DEFAULT= 0.01]
DEFAULT C_vShr_DMin - Calibrated parameter in the eddy viscosity filter function for the shear layer defining the transitional diameter fraction between the minimum and exponential regions (-) [>=0.0 ] or DEFAULT [DEFAULT= 3.0 ]
DEFAULT C_vShr_DMax - Calibrated parameter in the eddy viscosity filter function for the shear layer defining the transitional diameter fraction between the exponential and maximum regions (-) [> C_vShr_DMin ] or DEFAULT [DEFAULT=25.0 ]
DEFAULT C_vShr_FMin - Calibrated parameter in the eddy viscosity filter function for the shear layer defining the value in the minimum region (-) [>=0.0 and <=1.0] or DEFAULT [DEFAULT= 0.2 ]
DEFAULT C_vShr_Exp - Calibrated parameter in the eddy viscosity filter function for the shear layer defining the exponent in the exponential region (-) [> 0.0 ] or DEFAULT [DEFAULT= 0.1 ]
DEFAULT Mod_WakeDiam - Wake diameter calculation model (-) (switch) {1: rotor diameter, 2: velocity based, 3: mass-flux based, 4: momentum-flux based} or DEFAULT [DEFAULT=1]
DEFAULT C_WakeDiam - Calibrated parameter for wake diameter calculation (-) [>0.0 and <0.99] or DEFAULT [DEFAULT=0.95] [unused for Mod_WakeDiam=1]
DEFAULT Mod_Meander - Spatial filter model for wake meandering (-) (switch) {1: uniform, 2: truncated jinc, 3: windowed jinc} or DEFAULT [DEFAULT=3]
2.1 C_Meander - Calibrated parameter for wake meandering (-) [>=1.0] or DEFAULT [DEFAULT=1.9]
--- CURLED-WAKE PARAMETERS [only used if Mod_Wake=2 or 3] ---
DEFAULT Swirl - Switch to include swirl velocities in wake (-) (switch) [DEFAULT=TRUE]
DEFAULT k_VortexDecay - Vortex decay constant for curl (-) [DEFAULT=0]
DEFAULT NumVortices - The number of vortices in the curled wake model (-) [DEFAULT=100]
DEFAULT sigma_D - The width of the vortices in the curled wake model non-dimesionalized by rotor diameter (-) [DEFAULT=0.2]
DEFAULT FilterInit - Switch to filter the initial wake plane deficit and select the number of grid points for the filter {0: no filter, 1: filter of size 1} or DEFAULT [DEFAULT=1] (switch)
DEFAULT k_vCurl - Calibrated parameter for scaling the eddy viscosity in the curled-wake model (-) [>=0] or DEFAULT [DEFAULT=2.0 ]
DEFAULT Mod_Projection - Switch to select how the wake plane velocity is projected in AWAE {1: keep all components, 2: project against plane normal} or DEFAULT [DEFAULT=1: if Mod_Wake is 1 or 3, or DEFAULT=2: if Mod_Wake is 2] (switch)
False Echo - Echo input data to "<RootName>.ech" (flag)
"default" DT Integration time step (s)
False YawDOF - Yaw DOF (flag)
5.65 RotSpeed - Initial or fixed rotor speed (rpm)
30 NacYaw - Initial or fixed nacelle-yaw angle (degrees)
15.36 PtfmSurge - Initial or fixed horizontal surge translational displacement of platform (meters)
0.1 PtfmSway - Initial or fixed horizontal sway translational displacement of platform (meters)
-0.4 PtfmHeave - Initial or fixed vertical heave translational displacement of platform (meters)
0.3 PtfmRoll - Initial or fixed roll tilt rotational displacement of platform (degrees)
2.6 PtfmPitch - Initial or fixed pitch tilt rotational displacement of platform (degrees)
0.28 PtfmYaw - Initial or fixed yaw rotational displacement of platform (degrees)
120.97 TipRad - The distance from the rotor apex to the blade tip (meters)
3.97 HubRad - The distance from the rotor apex to the blade root (meters)
-4 PreCone(1) - Blade 1 cone angle (degrees)
-4 PreCone(2) - Blade 2 cone angle (degrees)
-4 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
-12.098 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0.0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
-6.0 ShftTilt - Rotor shaft tilt angle (degrees)
-5.125 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
4.315 NacCMzn - Vertical distance from the tower-top to the nacelle CM (meters)
0.0 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
0.0 NcIMUzn - Vertical distance from the tower-top to the nacelle IMU (meters)
4.3495 Twr2Shft - Vertical distance from the tower-top to the rotor shaft (meters)
144.386 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
15 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-14.400 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
69131 HubMass - Hub mass (kg)
969952 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
1836784 GenIner - Generator inertia about HSS (kg m^2)
644857 NacMass - Nacelle mass (kg)
32929058 NacYIner - Nacelle inertia about yaw axis (kg m^2)
28249 YawBrMass - Yaw bearing mass (kg)
1.7838E+07 PtfmMass - Platform mass (kg)
1.2507E+10 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
1.2507E+10 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
2.3667E+10 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
50 BldNodes - Number of blade nodes (per blade) used for analysis (-)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile1 - Name of file containing properties for blade 1 (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile2 - Name of file containing properties for blade 2 (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile3 - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
1 GBRatio - Gearbox ratio (-)
69737644900 DTTorSpr - Drivetrain torsional spring (N-m/rad)
49418406 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
"unused" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
"IEA-15-240-RWT-UMaineSemi_ElastoDyn_tower.dat" TwrFile - Name of file containing tower properties (quoted string)
Thank you for your help,
Dear @Yuki.Ogura,
I believe the issue is that the DEFAULT wake-deflection correction parameters–especially the DEFAULT value of C_HWkDfl_xY = -0.004/deg is not appropriate for the wind turbine (IEA Wind 15-MW RWT) or case you are using. With a -30 deg yaw error, a value of C_HWkDfl_xY = -0.004/deg will yield a deflection of Y = +480 m at 4000-m downstream of the rotor. The DEFAULT wake-deflection correction parameters were derived for a different wind turbine (NREL 5-MW baseline wind turbine) and different cases (including different mean wind speed and turbulence conditions).
Dear @Jason.Jonkman ,
Thank you for your reply.
I tried C_HWkDfl_xY=0 and got the following figure.
The figure shows that the direction of deflection is changing as you said.
However, I don’t know how to determine if the set C_HWkDfl_xY is a reasonable value.
Is there an equation to determine C_HWkDfl_xY?
Dear @Yuki.Ogura,
The horizontal wake-deflection correct in FAST.Farm is meant to be used for calibration of the wake deflection of the polar model to known solutions, e.g., from large-eddy simulation or experimental data. There is no “equation” to determine it.
We were hopeful that our original calibration of the wake-related parameters of FAST.Farm for the NREL 5-MW turbine against LES data (from the following paper: https://www.nrel.gov/docs/fy18osti/70533.pdf), from which the DEFAULT settings in FAST were defined were generally valid, but apparently this is not the case for C_HWkDfl_xY.
Regardless, as I suggested before, we generally recommend applying the curled wake model in situations with skewed inflow anyway.
Thank you for your kind reply.
I am aware that the value of C_HWkDfl_xY can be obtained from LES simulations and actual experimental data.
As you suggested, I will use the curled wake model from now on.
I ran a simulation using the curled wake model as you suggested, and the velocity deficit disappeared midway, as shown in the photo below, and no wake deflection occurred even though the nacelle yaw was rotated.
The simulation conditions are as follows:
Turbine: IEA15MW monopile
Wind: 9 m/s steady
NacYaw: 20 deg
The fstf file used in the simulation are as follows:
101 NX_Low - Number of low -resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
-432 X0_Low - Origin of low -resolution spatial nodes in X direction for wind data interpolation (m)
48.0 dX_Low - Spacing of low -resolution spatial nodes in X direction for wind data interpolation (m) [>0.0]
"InflowWind.dat" InflowFile - Name of file containing InflowWind module input parameters (quoted string)
0.0 0.0 0.0 "FFTest_WT1.fst" -255 -255 5.0 10.0 10.0 10.0
2 Mod_Wake - Switch between wake formulations {1:Polar, 2:Curl, 3:Cartesian} (-) (switch)
13.0 dr - Radial increment of radial finite-difference grid (m) [>0.0]
DEFAULT C_Meander - Calibrated parameter for wake meandering (-) [>=1.0] or DEFAULT [DEFAULT=1.9]
Please tell me the reason why the defect disappears and why the deflection does not occur.
Dear @Yuki.Ogura,
The wake will end abruptly if NumPlanes is not set high enough. Depending on what time step you are showing the visualization, it could also be that the wake is still propagating downstream during the start-up transient.
In the curled wake model, the wake deflection is mostly the result of the “kidney shape” of the wake, which may be hard to visualize in the XY plane you are showing. Do you see the “kidney shape” if you visualize a cross-plane (YZ) in the wake?
I have increased NumPlanes from 136 to 250 as you suggested.
When this was done, the velocity deficit in the x direction was no longer interrupted.
The following photo shows the xy plane after 1800 seconds.
The yz-plane after 1800 seconds is shown in the following picture.
Does this figure show that the simulation is correct?
Dear @Yuki.Ogura,
At what distance downstream of the rotor is your YZ plane visualization?
Parameters for visualization are as follows.
--- VISUALIZATION ---
True WrDisWind - Write low- and high-resolution disturbed wind data to <RootName>.Low.Dis.t<n>.vtk etc.? (flag)
1 NOutDisWindXY - Number of XY planes for output of disturbed wind data across the low-resolution domain to <RootName>.Low.DisXY<n_out>.t<n>.vtk (-) [0 to 99]
150 OutDisWindZ - Z coordinates of XY planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindXY] [unused for NOutDisWindXY=0]
1 NOutDisWindYZ - Number of YZ planes for output of disturbed wind data across the low-resolution domain to <RootName>/Low.DisYZ<n_out>.t<n>.vtk (-) [0 to 99]
240 OutDisWindX - X coordinates of YZ planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindYZ] [unused for NOutDisWindYZ=0]
1 NOutDisWindXZ - Number of XZ planes for output of disturbed wind data across the low-resolution domain to <RootName>/Low.DisXZ<n_out>.t<n>.vtk (-) [0 to 99]
0.0 OutDisWindY - Y coordinates of XZ planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindXZ] [unused for NOutDisWindXZ=0]
3.0 WrDisDT - Time step for disturbed wind visualization output (s) [>0.0] or DEFAULT [DEFAULT=DT_Low or DT_Low-VTK] [unused for WrDisWind=False and NOutDisWindXY=NOutDisWindYZ=NOutDisWindXZ=0]
The other fstf file settings are as shown in the four previous posts, except for NumPlanes.
Dear @Yuki.Ogura,
It looks like you are outputting the YZ cross-plane about 1D downstream of the rotor. Do you see the curled wake shape more closely if you move this cross-plane closer to the rotor?
This is an image at x=120 (0.5D downstream of the rotor).
Please let me know if you need more information.
Dear Jonkman,
I’m having the same problem as above: the turbineis yaw but the wake is not deflected.
turbine:DTU10MW
inflow:10m/s
Mod_Wake:curl
fig.1 T=200S velocity profile under wake
fig.2 T=200S velocity filed
here is th fstf file
Summary
FAST.Farm input - file, using two turbines separated by 3D downstream and an offset of 30m, with a turbulent inflow given by one turbsim box
— SIMULATION CONTROL —
False Echo - Echo input data to .ech? (flag)
FATAL AbortLevel - Error level when simulation should abort (string) {“WARNING”, “SEVERE”, “FATAL”}
630 TMax - Total run time (s) [>=0.0]
— SUPER CONTROLLER — [used only for UseSC=True]
“unused” SC_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} containing the Super Controller algorithms (quoated string)
— SHARED MOORING SYSTEM — [used only for Mod_SharedMoor>0]
“” SharedMoorFile - Name of file containing shared mooring system input parameters (quoted string) [used only when Mod_SharedMooring > 0]
— AMBIENT WIND: PRECURSOR IN VTK FORMAT — [used only for Mod_AmbWind=1]
2 DT_Low-VTK - Time step for low -resolution wind data input files; will be used as the global FAST.Farm time step (s) [>0.0]
0.1 DT_High-VTK - Time step for high-resolution wind data input files (s) [>0.0]
“unused” WindFilePath - Path name to VTK wind data files from precursor (string)
— AMBIENT WIND: INFLOWWIND MODULE — [used only for Mod_AmbWind=2 or 3]
2 DT_Low - Time step for low -resolution wind data interpolation; will be used as the global FAST.Farm time step (s) [>0.0]
201 NX_Low - Number of low -resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
93 NY_Low - Number of low -resolution spatial nodes in Y direction for wind data interpolation (-) [>=2]
24 NZ_Low - Number of low -resolution spatial nodes in Z direction for wind data interpolation (-) [>=2]
-121.0 X0_Low - Origin of low -resolution spatial nodes in X direction for wind data interpolation (m)
-600.0 Y0_Low - Origin of low -resolution spatial nodes in Y direction for wind data interpolation (m)
13.945 dX_Low - Spacing of low -resolution spatial nodes in X direction for wind data interpolation (m) [>0.0]
12.903 dY_Low - Spacing of low -resolution spatial nodes in Y direction for wind data interpolation (m) [>0.0]
12.083 dZ_Low - Spacing of low -resolution spatial nodes in Z direction for wind data interpolation (m) [>0.0]
16 NX_High - Number of high-resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
17 NY_High - Number of high-resolution spatial nodes in Y direction for wind data interpolation (-) [>=2]
19 NZ_High - Number of high-resolution spatial nodes in Z direction for wind data interpolation (-) [>=2]
“IW.dat” InflowFile - Name of file containing InflowWind module input parameters (quoted string)
— WIND TURBINES —
0 0 0 “FFTest_WT1.fst” -1.07054700e+02 -1.10677400e+02 5 1.39453000e+01 1.29032000e+01 1.20833000e+01
— WAKE DYNAMICS —
8 dr - Radial increment of radial finite-difference grid (m) [>0.0]
40 NumRadii - Number of radii in the radial finite-difference grid (-) [>=2]
762 NumPlanes - Number of wake planes (-) [>=2]
DEFAULT f_c - Cutoff (corner) frequency of the low-pass time-filter for the wake advection, deflection, and meandering model [recommended=1.28*U0/R] (Hz) [>0.0] or DEFAULT [DEFAULT=12.5/R, R estimated from dr and NumRadii, not recommended]
— CURLED-WAKE PARAMETERS [only used if Mod_Wake=2 or 3] —
— VISUALIZATION —
False WrDisWind - Write low- and high-resolution disturbed wind data to .Low.Dis.t.vtk etc.? (flag)
1 NOutDisWindXY - Number of XY planes for output of disturbed wind data across the low-resolution domain to .Low.DisXY<n_out>.t.vtk (-) [0 to 99]
113 OutDisWindZ - Z coordinates of XY planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindXY] [unused for NOutDisWindXY=0]
1 NOutDisWindYZ - Number of YZ planes for output of disturbed wind data across the low-resolution domain to /Low.DisYZ<n_out>.t.vtk (-) [0 to 99]
63.0, 441.0 OutDisWindX - X coordinates of YZ planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindYZ] [unused for NOutDisWindYZ=0]
1 NOutDisWindXZ - Number of XZ planes for output of disturbed wind data across the low-resolution domain to /Low.DisXZ<n_out>.t.vtk (-) [0 to 99]
2 WrDisDT - Time step for disturbed wind visualization output (s) [>0.0] or DEFAULT [DEFAULT=DT_Low or DT_Low-VTK] [unused for WrDisWind=False and NOutDisWindXY=NOutDisWindYZ=NOutDisWindXZ=0]
— OUTPUT —
True SumPrint - Print summary data to .sum? (flag)
99999.9 ChkptTime - Amount of time between creating checkpoint files for potential restart (s) [>0.0]
0.0 TStart - Time to begin tabular output (s) [>=0.0]
1 OutFileFmt - Format for tabular (time-marching) output file (switch) {1: text file [.out], 2: binary file [.outb], 3: both}
True TabDelim - Use tab delimiters in text tabular output file? (flag) {uses spaces if False}
“ES10.3E2” OutFmt - Format used for text tabular output, excluding the time channel. Resulting field should be 10 characters. (quoted string)
DEFAULT OutAllPlanes - Output all wake planes at all time steps. [DEFAULT=False]
0 NOutRadii - Number of radial nodes for wake output for an individual rotor (-) [0 to 20]
0 OutRadii - List of radial nodes for wake output for an individual rotor (-) [1 to NOutRadii] [unused for NOutRadii=0]
1 NOutDist - Number of downstream distances for wake output for an individual rotor (-) [0 to 9 ]
63.0 OutDist - List of downstream distances for wake output for an individual rotor (m) [1 to NOutDist ] [unused for NOutDist =0]
0 NWindVel - Number of points for wind output (-) [0 to 9]
0.0 WindVelX - List of coordinates in the X direction for wind output (m) [1 to NWindVel] [unused for NWindVel=0]
0.0 WindVelY - List of coordinates in the Y direction for wind output (m) [1 to NWindVel] [unused for NWindVel=0]
90.0 WindVelZ - List of coordinates in the Z direction for wind output (m) [1 to NWindVel] [unused for NWindVel=0]
OutList The next line(s) contains a list of output parameters. See OutListParameters.xlsx for a listing of available output channels (quoted string)
“RtVAmbT1”
END
Dear @Yuki.Ogura,
I do see some asymmetry in your wake at 0.5D downstream. Regardless, my guess is the value of k_VortexDecay is not set properly for your model. Presuming you are not using FAST.Farm within OpenFAST v4, the DEFAULT value of k_VortexDecay was set too high (0.01). According to our work calibrating the curled wake model in FAST.Farm against large-eddy simulation for the IEA Wind 15-MW RWT, we recommend setting k_VortexDecay to 0. The DEFAULT of k_VortexDecay was changed to 0 in FAST.Farm with the v4 release of OpenFAST. See the following OpenFAST issue on GitHub for more information: DEFAULT and Recommended Polar and Curled Wake Settings in FAST.Farm · Issue #1822 · OpenFAST/openfast · GitHub. Please also note that we recommend increasing the value of k_vCurl from 2 to 5 for the IEA Wind 15-MW RWT. See the following Wind Energy Science paper for more information: WESD - Load assessment of a wind farm considering negative and positive yaw misalignment for wake steering.
Dear @Zhiyan.Dong,
Perhaps you are suffering the same problem and changing k_VortexDecay to 0 will solve your problem?
Dear Jonkman,
While I change the
k_VortexDecay to 0.I think i get the right wake deflection.Thank you very much for your help!
Additionally, I would like to inquire about the value of
k_vCurl. Is the default value of 2 a correction made for the 5MW turbine? What would be your recommended value for the 10MW unit, 5 or an interpolation between 2 and 5?
Dear @Zhiyan.Dong,
Indeed your response looks much better.
I’m not aware of any calibration of k_vCurl against large-eddy simulation for the DTU 10-MW RWT. The best approach would be to do that. Otherwise, a value between 2 and 5 is likely correct, but it would be hard to know without benchmarking against large-eddy simulation.
Sorry for the late reply.
I followed your suggestion and changed k_VortexDecay and k_vCurl, and now the output vtk files contain Nan and cannot be visualized in Paraview.
Here is the fstf file I used in my simulation.
1800 TMax - Total run time (s) [>=0.0]
250 NumPlanes - Number of wake planes (-) [>=2]
0.003 C_HWkDfl_xY - Calibrated parameter in the correction for wake deflection defining the horizontal offset scaled with downstream distance and yaw error (1/deg) or DEFAULT [DEFAULT= 0.0 if Mod_Wake is 2, -0.004 otherwise]
0 k_VortexDecay - Vortex decay constant for curl (-) [DEFAULT=0]
5 k_vCurl - Calibrated parameter for scaling the eddy viscosity in the curled-wake model (-) [>=0] or DEFAULT [DEFAULT=2.0 ]
False WrDisWind - Write low- and high-resolution disturbed wind data to <RootName>.Low.Dis.t<n>.vtk etc.? (flag)
120 OutDisWindX - X coordinates of YZ planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindYZ] [unused for NOutDisWindYZ=0]
And here is one of the output vtk files.
# vtk DataFile Version 3.0
Low resolution, disturbed wind of XY Slice at time = 954 seconds.
ASCII
DATASET STRUCTURED_POINTS
DIMENSIONS 101 51 1
ORIGIN -432.00 -500.00 150.00
SPACING 48.00 20.00 20.00
POINT_DATA 5151
VECTORS Velocity float
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
NaN NaN NaN
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
9.00 0.00 0.00
How can I fix this error?
Dear @Yuki.Ogura,
Do you see other not a number (NaN) showing up in the results? I would guess the FAST.Farm calculation has gone numerically unstable because your a not following the modeling guidance, e.g., the DT_Low and dr relationship for the curled wake model is not kept: 4.18.6. Modeling Guidance — OpenFAST v4.0.0 documentation
