ٰVestas 660 kw Wind Turbine input file
I need Vestas 660 Kw optislip input file to use in Fast.
Please, can any one send me this kind of Wind Turbine input file.
Thanks a lot,
Dear Vahid,
I doubt anyone can share a FAST model with you that contains a wind turbine manufacturer’s proprietary information.
I did the modeling of this type of turbine, but it is not complete. So i need a complete model of this type of turbine.
How can I get complete model of that. Because i need it to use in Fast to validate my modeling. Because of that my project is half finished.
Dear Vahid,
What data are you missing to complete the model?
I need Turbine control, Turbine configuration, Mass and Inertia, Drivetrain, Generator, Nacellle and yaw parameters.
Dear Vahid,
Again, I suspect it will be hard to obtain this data for a proprietary wind turbine, unless you have a direct collaboration with Vestas that would make this data available to you.
Your best option may be to use one of the publicly available FAST models (e.g. the WindPACT 1.5-MW turbine) and tune and/or scale the properties from this public model to those properties that are publicly available from your specific wind turbine of interest.
Thanks a lot for your help.
I will do that.
Best regards.
I need Fast.Farm in my project.
When this software released?
Dear Vahid,
We have now completed the calibration of FAST.Farm against SOWFA (with a paper presented at AIAA SciTech 2018: nrel.gov/docs/fy18osti/70533.pdf). We are currently working on the validation of FAST.Farm against SOWFA and an associated TORQUE 2018 paper. Our current plant is to publicly release FAST.Farm once this validation is complete…likely later this Spring.
Thanks a lot for your quick reply and your attention.
I need so much this software in my PhD thesis.
