I am currently verifying a wind turbine model in Bladed with a wind turbine model in OpenFAST. In order to use the same turbulent wind field for both models, I used the option to use the native Bladed input file in InflowWind.
After inserting all parameter values into the “intermediate Bladed wind scaling file” for InflowWind, I did the simulation with OpenFAST and compared the time series of the wind speed for alle thre directions with the results from Bladed. This is shown in the figure. For the x- and z-direction, the time series are almost exactly the same for both models as you can see in the figure. Only the y-direction is reversed in OpenFAST compared to Bladed. However, if I did noch get it wrong, the coordinate systems in OpenFAST and Bladed should be defined in the same way, which is why I can’t explain this difference. Do you have any idea what could be the reason for this result?
Thank you!
Franziska
