Dear @Jason.Jonkman,
I am trying to translate a 2.0MW model from Bladed to OpenFast. For this, I am currently running simulations with steady wind for both, Bladed and OpenFast models to ensure that are responding similarly.
I am comparing three curves:
1- Bladed model with generic controller, tipically used in Bladed.
2- Bladed model with OpenDiscon controller.
3- OpenFast model with OpenDiscon controller.
1&2 are giving the same values, so we discarded that the problem is in the controller differences. However, when using the OpenFast model, there is an approximate shift of 0.5 m/s, although the overall trend until rated wind speed seems to match:
And the rotor speed is also below the Bladed model
Here are some ideas considered to explain these differences:
-Could it be that I am not properly accounting for the free wind speed in OpenFast? The variable I am using for this is Wind1VelX.
-Is there an issue with the Kopt? I have made modifications here, but there hasn’t been any significant improvement.
-Am I incorrectly defining the so-called “Blade Set Angle” in Bladed when transferring to OpenFast? I understand there isn’t a direct variable for this in OpenFast, so I modified the Aerodynamic Twist distribution to incorporate the Blade Set Angle. However, this modification hasn’t released better results.
Am I overlooking something? Any insight you could provide would be greatly appreciated.
Thank you in advance.
Dear @Jason.Jonkman ,
As commented yesterday, the rotor speed we are finding with OpenFast is lower at wind speeds before rated:
So specially the aerodynamic torque we are obtaining with OpenFast is 16% lower approx.
Thank you in advance,
Dear @Ainhoa.Alberdi,
I would start by simplifying the model as much as possible–How much difference in aerodynamic torque between Bladed and OpenFAST do you see for the same rotor speed if you disable all structural degrees of freedom in both models?
Thank you very much for your indications.
I am currently following this approach, but something really odd is happening with the polar curves. I have obtained Cl, Cd and angle of attack for 10m/s at different blade sections. For example, at section 24m from the blade root, I am obtaining the next values:
AoA: 3.78deg
Cl: 0.711
Cd: 0.008
This section is linked to airfoil number 4. If I check this airfoils Cl and Cd coefficients for that Angle of Attack Range, I have this values:
Alpha Cl Cd
3.5 0.951 0.009
4 1.012 0.009
How is it possible to have such a low lift coefficient if is not happening between the angles of attack that is interpolating?
Thank you again, really appeciated.
It can happen that the lift and drag don’t match the static airfoil data at a given angle of attack if you have unsteady airfoil aerodynamics enabled (UA_Mod
> 0 in AeroDyn, i.e, the airfoil data follows a hysteresis loop around the static polar data). It could also be that you have multiple airfoil tables for a given airfoil and you are interpolating based on Reynolds number or control (AFTabMod
> 1 in AeroDyn).
The UA_Mod solved it. Really appreciated. We are now having very similar performance with laminar wind for both, Bladed and OpenFAST model:
The next issue I am facing now is how to compare the blade, tower and drive train frequencies. Can you indicate how to obtain Campbell diagram from the OpenFAST model?
The easiest way to compute a Campbell diagram with OpenFAST is to use the Automatic Campbell Diagram Code (ACDC): GitHub - OpenFAST/acdc: ACDC: Automated Campbell Diagram Code.
Thank you for your previous support, it was very helpful.
I am now working with MCrunch to obtain fatigue equivalent loads, and a few questions have come up:
- Is it possible to assign a specific number of hours to each simulation? I’ve seen that a Rayleigh distribution can be defined, but how are the total hours distributed among different DLCs, such as start-ups, shut-downs, or idling cases?
-Also, design fatigue equivalent loads are typically calculated for 10^7 cycles and 20 years. I understand that the 20 years can be defined in seconds, but how is the number of cycles accounted for or defined in MCrunch?
Thank you in advance for your support.
Ainhoa
In MLife, the Weibull (or user-defined) distribution, together with the Availability
and DesignLife
are used to extrapolate the provided data to determine the total number of hours in each bin for both the power production (Availability
) and parked/idling (1-Availability
) cases. The number of discrete (start-up and shutdown cases) is determined by the number of files (occurrences) provided (and is assumed to be small enough not be substracted from the power production and parked/idling cases).
The total lifetime number of cycles is determined based on the DesignLife
and EquivalentFrequency
This is also applicable to Mcrunch? I do not have a Matlab license.
Ainhoa.
No, to process lifetime fatigue for power production, idling, and discrete events combined requires that you use MLife in place of MCrunch.
Like MCrunch, MLife is provided as a Windows executable that can be run with provided run-time libraries.
