Dear Dr. Jason,
I am looking for TurbSim Input File for NREL 5MW Baseline Turbine(Test 18).
For a land-based wind turbine, you would typically set the grid size to be about 10% more than the rotor diameter in the horizontal and vertical directions.In Test18,the value of rator diameter is 126m,so you would set the grid size to be about 138.6(126+126*0.1). Actually I found two turbsim input files.The differences are the value of RandSeed1 and NumGrid_Z, NumGrid_Y.Should I use the first one or the second one?
The first one is downloaded from your google drive.
The second file is found on the website:
[url]http://ramslandtechnology.com/Limited_Modeling/data/5MW_onshore%20_12mps_normal_turbulence/90m_12mps_twr.inp.txt[/url]
The difference has been bolded as follows
The first one:
TurbSim Input File. Valid for TurbSim v1.50; 17-May-2010; Example file that can be used with simulations for the NREL 5MW Baseline Turbine
511347 RandSeed1 - First random seed (-2147483648 to 2147483647)
RanLux RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
21 NumGrid_Z - Vertical grid-point matrix dimension
21 NumGrid_Y - Horizontal grid-point matrix dimension
630.0 AnalysisTime - Length of analysis time series [seconds]
630.0 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds)
90.0 HubHt - Hub height [m] (should be > 0.5GridHeight)
155.0 GridHeight - Grid height [m]
155.0 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
The second one:
TurbSim Input File. Valid for TurbSim v1.50; 17-May-2010; Example file that can be used with simulations for the NREL 5MW Baseline Turbine; note that UsableTime has been decreased in this file so that the file distributed with the FAST CertTest isn’t as large
13428 RandSeed1 - First random seed (-2147483648 to 2147483647)
True WrADTWR - Output tower time-series data? (Generates RootName.twr)
31 NumGrid_Z - Verti+cal grid-point matrix dimension
600.0 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds) [bjj: was 630]
145.0 GridHeight - Grid height [m]
145.0 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
