Turbsim - numerical error using Davenport coherence model
I am using the alpha version of Turbsim 2.0 to generate a wind field using the Kaimal spectral model as defined in IEC (3rd ed.) and the Davenport coherence model. I have specified the Davenport coherence model by using the general coherence model defined in Turbsim with CohExp=0 and b=0. With this setting (see example below), I get the following error message:
CalcFourierCoeffs: CalcFourierCoeffs_General:Error in Cholesky factorization: LAPACK_SPPTRF: Leading minor order 34 of A is not positive definite, so Cholesky factorization could not be completed.
It appears that b cannot be arbitrarily small, as the same error message appears if it is set sufficiently small, b<b_lim (where b_lim depends on the other specifications of the input file). However, using the IEC coherence model with b=0 is no problem.
Is there any way to get around this issue?
Here is an example file which will replicate the error message:
---------TurbSim v2.00.* Input File------------------------
Example input file for TurbSim.
2318573 RandSeed1 - First random seed (-2147483648 to 2147483647)
RANLUX RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False WrADFF - Output full-field time-series data in TurbSim/AeroDyn form? (Generates RootName.bts)
True WrBLFF - Output full-field time-series data in BLADED/AeroDyn form? (Generates RootName.wnd)
5 NumGrid_Z - Vertical grid-point matrix dimension
20 NumGrid_Y - Horizontal grid-point matrix dimension
1.0 TimeStep - Time step [seconds]
12000 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
11900 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds unless UsableTime is “ALL”)
41.00 HubHt - Hub height [m] (should be > 0.5GridHeight)
80.00 GridHeight - Grid height [m]
200.00 GridWidth - Grid width [m] (should be >= 2
(RotorRadius+ShaftLength))
“IECKAI” TurbModel - Turbulence model (“IECKAI”,“IECVKM”,“GP_LLJ”,“NWTCUP”,“SMOOTH”,“WF_UPW”,“WF_07D”,“WF_14D”,“TIDAL”,“API”,“USRINP”,“TIMESR”, or “NONE”)
“unused” UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for “USRINP” and “TIMESR” models)
“1-Ed3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
13.5 IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP model, not used for other models)
default ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
“LOG” WindProfileType - Velocity profile type (“LOG”;“PL”=power law;“JET”;“H2L”=Log law for TIDAL model;“API”;“USR”;“TS”;“IEC”=PL on rotor disk, LOG elsewhere; or “default”)
“unused” ProfileFile - Name of the file that contains input profiles for WindProfileType=“USR” and/or TurbModel=“USRVKM” [-]
10.0 RefHt - Height of the reference velocity (URef) [m]
30.0 URef - Mean (total) velocity at the reference height [m/s] (or “default” for JET velocity profile) [must be 1-hr mean for API model; otherwise is the mean over AnalysisTime seconds]
default ZJetMax - Jet height [m] (used only for JET velocity profile, valid 70-490 m)
0.01 Z0 - Surface roughness length [m] (or “default”)
0.05 RICH_NO - Gradient Richardson number [-]
default PC_UW - Hub mean u’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
default PC_UV - Hub mean u’v’ Reynolds stress [m^2/s^2] (or “default” or “none”)
default PC_VW - Hub mean v’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
Dear Erik,
The bottom part of your TurbSim input file seems to be cut-off. Can you attach the whole file?
I’m sorry - for some reason the most important part of the input file was omitted! Here is the whole file:
GENERAL SCMod1 - u-component coherence model (“GENERAL”, “IEC”, “API”, “NONE”, or “default”)
GENERAL SCMod2 - v-component coherence model (“GENERAL”, “IEC”, “NONE”, or “default”)
GENERAL SCMod3 - w-component coherence model (“GENERAL”, “IEC”, “NONE”, or “default”)
“10.0 0.0” InCDec1 - u-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“6.5 0.0” InCDec2 - v-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“6.5 0.0” InCDec3 - w-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default CohExp - Coherence exponent for general model [-] (or “default”)
“C:/Yiwork_NREL/OffshoreWind/Turbsim/Test/EventData” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1.0 DistScl - Disturbance scale [-] (ratio of event dataset height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right [-] (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. [-] (Ignored when Randomize = true.)
30.0 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
! NOTE: Do not add or remove any lines in this file!
Dear Erik,
I haven’t tried running your case, but I asked Bonnie Jonkman of Envision Energy – who developed TurbSim while working at NREL – and she informed me that there was a bug in earlier versions of TurbSim v2.00 that may have prevented it from functioning when there is an even number of grid points in the Y or Z directions. This was fixed in newer versions, so if you haven’t already, I suggest upgrading to TurbSim v2.00.07a-bjj. Alternatively, increase NumGrid_Y to 21.
Please let me know if that solves your problem.
Thank you for your rapid responses. As a matter of fact, it turns out I am running v2.00.07a-bjj. I also tested increasing NumGrid_Y to 21 just in case, but I keep getting the same error message.
PS. TurbSim runs perfectly when increasing the factor b.
Erik
Have you had the chance to look into this case? I am truly appreciating your support.
Are there anyone else at this forum who has experienced a similar error message?
All the best,
Erik
