Hi @Jason.Jonkman,
I am getting an error in a TurbSim model that I am trying to simulate.
I am using a user-defined wnd shear profile. I would like to create a wind-field for the 5MW DeepCwind turbine. The hub-height is 90 m and so I have set GridHeight to be 175 m and GirdWidth to be 300 m. I have set NumGrid_Z and NumGirid_Y to be 15 x 15. I use the general coherence model with CohExp of 0.85. I have shown the TurbSim file and the Shear Profile below.
I am getting the following error:
Reading the input file “90m_wind_shearJCS1-12.inp”.
- Calculating the spectral and transfer function matrices:*
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
ntdll.dll 00007FFD15895BB6 Unknown Unknown Unknown
ntdll.dll 00007FFD158947B1 Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FFE580C0 Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FFE580FA Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FF2D2679 Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FF2D1BBE Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FF2D0F32 Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FF92D2E6 Unknown Unknown Unknown
TurbSim_x64.exe 00007FF6FFE57E9C Unknown Unknown Unknown
KERNEL32.DLL 00007FFD15257614 Unknown Unknown Unknown
ntdll.dll 00007FFD158C26A1 Unknown Unknown Unknown
Can you help me to fix this please ?
Thank you.
AOAW
TurbSim File:
---------TurbSim v2.00.* Input File------------------------
1 RandSeed1 - First random seed (-2147483648 to 2147483647)
“RANLUX” RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
True WrFHHTP - Output hub-height turbulence parameters in formatted form? (Generates RootName.dat)
15 NumGrid_Z - Vertical grid-point matrix dimension
15 NumGrid_Y - Horizontal grid-point matrix dimension
3600 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
3600 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds unless UsableTime is “ALL”)
90.0 HubHt - Hub height [m] (should be > 0.5GridHeight)
175 GridHeight - Grid height [m]
300 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
“IECKAI” TurbModel - Turbulence model (“IECKAI”,“IECVKM”,“GP_LLJ”,“NWTCUP”,“SMOOTH”,“WF_UPW”,“WF_07D”,“WF_14D”,“TIDAL”,“API”,“USRINP”,“TIMESR”, or “NONE”)
“unused” UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for “USRINP” and “TIMESR” models)
“1-ED3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
7.38 IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP model, not used for other models)
“default” ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
“USR” WindProfileType - Velocity profile type (“LOG”;“PL”=power law;“JET”;“H2L”=Log law for TIDAL model;“API”;“USR”;“TS”;“IEC”=PL on rotor disk, LOG elsewhere; or “default”)
“windshear12km.dat” ProfileFile - Name of the file that contains input profiles for WindProfileType=“USR” and/or TurbModel=“USRVKM” [-]
90.0 RefHt - Height of the reference velocity (URef) [m]
“default” URef - Mean (total) velocity at the reference height [m/s] (or “default” for JET velocity profile) [must be 1-hr mean for API model; otherwise is the mean over AnalysisTime seconds]
“default” ZJetMax - Jet height [m] (used only for JET velocity profile, valid 70-490 m)
“default” PLExp - Power law exponent [-] (or “default”)
“default” Z0 - Surface roughness length [m] (or “default”)
“default” Latitude - Site latitude [degrees] (or “default”)
0.05 RICH_NO - Gradient Richardson number [-]
“default” UStar - Friction or shear velocity [m/s] (or “default”)
“default” ZI - Mixing layer depth [m] (or “default”)
“default” PC_UW - Hub mean u’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” PC_UV - Hub mean u’v’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” PC_VW - Hub mean v’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“General” SCMod1 - u-component coherence model (“GENERAL”, “IEC”, “API”, “NONE”, or “default”)
“General” SCMod2 - v-component coherence model (“GENERAL”, “IEC”, “NONE”, or “default”)
“General” SCMod3 - w-component coherence model (“GENERAL”, “IEC”, “NONE”, or “default”)
“default” InCDec1 - u-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” InCDec2 - v-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” InCDec3 - w-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
0.85 CohExp - Coherence exponent for general model [-] (or “default”)
“/home/lkilcher/work/nwtc/turbsim/trunk/Test/EventData/” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1 DistScl - Disturbance scale [-] (ratio of event dataset height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right [-] (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. [-] (Ignored when Randomize = true.)
30 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
! NOTE: Do not add or remove any lines in this file!
Wind shear profile:
| ---------TurbSim v2.00.* Profile Input File------------------------ | |||
| Example file using completely made up profiles | |||
| -------- User-Defined Profiles (Used only with USR wind profile or USRVKM | spectral | model) | ------------- |
| 38 | |||
| 1.092 StdScale1 - u-component scaling factor for the input | standard | deviat | ion |
| 1.0 StdScale2 - v-component scaling factor for the input | standard | deviat | ion |
| 0.534 StdScale3 - w-component scaling factor for the input | standard | deviat | ion |
| Height Wind Speed Wind Direction Standard Deviation | Length Sc | ale | |
| (m) (m/s) (deg, cntr-clockwise ) (m/s) | (m) | ||
| 9.477484385 | 68.96623387 | 0 | |
| 14.62264151 | 72.40591398 | 0 | |
| 17.02928068 | 73.67001496 | 0 | |
| 20.53387105 | 75.51082109 | 0 | |
| 28.1133688 | 78.50395199 | 0 | |
| 31.76020612 | 79.94408192 | 0 | |
| 38.34483475 | 81.52138174 | 0 | |
| 42.86451582 | 82.60403841 | 0 | |
| 45.40941838 | 83.00115007 | 0 | |
| 50.55211484 | 83.80362664 | 0 | |
| 55.9819332 | 84.4805294 | 0 | |
| 62.26655144 | 85.26399491 | 0 | |
| 65.40949825 | 85.53955518 | 0 | |
| 71.78453118 | 86.09849107 | 0 | |
| 74.37421127 | 86.30573511 | 0 | |
| 82.0754717 | 86.92204301 | 0 | |
| 86.90775706 | 87.15757248 | 0 | |
| 98.485148 | 87.72186382 | 0 | |
| 100 | 87.79569892 | 0 | |
| 110.2817846 | 88.17935743 | 0 | |
| 119.8113208 | 88.53494624 | 0 | |
| 128.9663903 | 88.71554873 | 0 | |
| 144.6028718 | 89.02401033 | 0 | |
| 150.4716981 | 89.13978495 | 0 | |
| 153.9116787 | 89.16031547 | 0 | |
| 161.3660325 | 89.20480463 | 0 | |
| 168.8203863 | 89.24929378 | 0 | |
| 174.8861839 | 89.28549573 | 0 | |
| 178.6620821 | 89.30803109 | 0 | |
| 182.7056028 | 89.33216367 | 0 | |
| 184.7522404 | 89.34074077 | 0 | |
| 188.2845322 | 89.35554399 | 0 | |
| 192.7181674 | 89.37412459 | 0 | |
| 196.5671475 | 89.39025499 | 0 | |
| 201.1225859 | 89.40934604 | 0 | |
| 206.128696 | 89.43032578 | 0 | |
| 209.9654958 | 89.44640514 | 0 | |
| 216.9811321 | 89.47580645 | 0 | |
