I’m trying to run the DTU 10 MW RWT from the command prompt using the input below, but get the error below:
[code]
Input:
'D:\FAST1\bin\FAST_Win32.exe D:\FAST_Runs\OP_Test_16DT\test.fst ’
Error:
FAST_InitializeAll:SrvD_Init:BladedInterface_Init:The dynamic library
D:\FAST_Runs\OP_Test_16DT\10MWRWT\ServoData\dtu_we_controller_bladed.dll could not be loaded.
Check that the file exists in the specified location and that it is compiled for 32-bit
applications. [/code]
I can run the exact same file by simply dragging the .fst file onto the exact same FAST_Win32 executable without any issues.
To troubleshoot, I have also been able to run the files in the CertTest folder in the command prompt with any issue. So I believe that my input formatting is correct.
If anyone could suggest a reason why I get the error when running through the command prompt or any other avenues for troubleshooting, I’d greatly appreciate it!
Cheers
James
