Hello everyone,
I am working with the 15MW IEA RWT wind turbine model and I would like to obtain the torque coefficient for each section of the blade [Cq(r)] (I attach an example from the 5MW model [1]) as a function of pitch and TSR. I found thas this could be done using an app called WT_Perf, which also considered root and tip losses, but it is no longer available. I would like to know if it is possible to obtain these values through the AeroDyn driver or any other method.
Thank you very much!
Daniel.
[1] “Correlation between Rotating LIDAR Measurements and Blade Effective Wind Speed”, Simley E. and Pao L., 2013.
