Question #1 for turbulence fields (points outside of field)
Do you thing it�s OK to use tighter grids and instead of stopping the program if you have a point outside the wind field, just use the outermost value?
  • Yes
  • No
  • Don’t care
0 voters
Knowing that most of you won’t make your opinions known if you have to write up a response, I’m making it easy for you by creating a poll. Please select the appropriate choice.
Marshall
