I use OpenFast and run it however, unfortunately it is not run successfully.
The reason may be in the 5MW_Baseline/NRELOffshrBsline5MW_InflowWind_12mps.dat" file.
I cannot find out what is wrong in the line #8.
Could you advice me about it.
The version of OpenFast is 3.4.1.
Dear @Naoki.Ohba,
My guess is that the InflowWind input file you are using is formatted for a version different from OpenFAST v3.4. As with any input file processing issue, I would enable the Echo option to debug.
Dear Dr.Jason-san
Thank you so much for your quick support.
I guess so as you mentioned and found similar topics in NREL Forum.
My “NRELOffshrBsline5MW_InflowWind_12mps.dat” file is written as below.
Could you please let me know where and how to modify the file?
Or please share me correct “NRELOffshrBsline5MW_InflowWind_12mps.dat” file corresponds to Ver.3.4.1.
For reference ) “NRELOffshrBsline5MW_InflowWind_12mps.dat” file
------- InflowWind INPUT FILE -------------------------------------------------------------------------
12 m/s turbulent winds on 31x31 FF grid and tower for FAST CertTests #18, #19, #21, #22, #23, and #24
3 WindType - switch for wind file type (1=steady; 2=uniform; 3=binary TurbSim FF; 4=binary Bladed-style FF; 5=HAWC format; 6=User defined; 7=native Bladed FF)
0 PropagationDir - Direction of wind propagation (meteorological rotation from aligned with X (positive rotates towards -Y) – degrees) (not used for native Bladed format WindType=7)
0 VFlowAng - Upflow angle (degrees) (not used for native Bladed format WindType=7)
False VelInterpCubic - Use cubic interpolation for velocity in time (false=linear, true=cubic) [Used with WindType=2,3,4,5,7]
1 NWindVel - Number of points to output the wind velocity (0 to 9)
0 WindVxiList - List of coordinates in the inertial X direction (m)
0 WindVyiList - List of coordinates in the inertial Y direction (m)
90 WindVziList - List of coordinates in the inertial Z direction (m)
================== Parameters for Steady Wind Conditions [used only for WindType = 1] =========================
0 HWindSpeed - Horizontal wind speed (m/s)
90 RefHt - Reference height for horizontal wind speed (m)
0.2 PLExp - Power law exponent (-)
================== Parameters for Uniform wind file [used only for WindType = 2] ============================
“unused” Filename_Uni - Filename of time series data for uniform wind field. (-)
90 RefHt_Uni - Reference height for horizontal wind speed (m)
125.88 RefLength - Reference length for linear horizontal and vertical sheer (-)
================== Parameters for Binary TurbSim Full-Field files [used only for WindType = 3] ==============
“Wind/90m_12mps_twr.bts” FileName_BTS - Name of the Full field wind file to use (.bts)
================== Parameters for Binary Bladed-style Full-Field files [used only for WindType = 4 or WindType = 7] =========
“unused” FileNameRoot - WindType=4: Rootname of the full-field wind file to use (.wnd, .sum); WindType=7: name of the intermediate file with wind scaling values
False TowerFile - Have tower file (.twr) (flag) ignored when WindType = 7
================== Parameters for HAWC-format binary files [Only used with WindType = 5] =====================
“wasp\Output\basic_5u.bin” FileName_u - name of the file containing the u-component fluctuating wind (.bin)
“wasp\Output\basic_5v.bin” FileName_v - name of the file containing the v-component fluctuating wind (.bin)
“wasp\Output\basic_5w.bin” FileName_w - name of the file containing the w-component fluctuating wind (.bin)
64 nx - number of grids in the x direction (in the 3 files above) (-)
32 ny - number of grids in the y direction (in the 3 files above) (-)
32 nz - number of grids in the z direction (in the 3 files above) (-)
16 dx - distance (in meters) between points in the x direction (m)
3 dy - distance (in meters) between points in the y direction (m)
3 dz - distance (in meters) between points in the z direction (m)
90 RefHt_Hawc - reference height; the height (in meters) of the vertical center of the grid (m)
------------- Scaling parameters for turbulence ---------------------------------------------------------
2 ScaleMethod - Turbulence scaling method [0 = none, 1 = direct scaling, 2 = calculate scaling factor based on a desired standard deviation]
1 SFx - Turbulence scaling factor for the x direction (-) [ScaleMethod=1]
1 SFy - Turbulence scaling factor for the y direction (-) [ScaleMethod=1]
1 SFz - Turbulence scaling factor for the z direction (-) [ScaleMethod=1]
1.2 SigmaFx - Turbulence standard deviation to calculate scaling from in x direction (m/s) [ScaleMethod=2]
0.8 SigmaFy - Turbulence standard deviation to calculate scaling from in y direction (m/s) [ScaleMethod=2]
0.2 SigmaFz - Turbulence standard deviation to calculate scaling from in z direction (m/s) [ScaleMethod=2]
------------- Mean wind profile parameters (added to HAWC-format files) ---------------------------------
12 URef - Mean u-component wind speed at the reference height (m/s)
2 WindProfile - Wind profile type (0=constant;1=logarithmic,2=power law)
0.2 PLExp_Hawc - Power law exponent (-) (used for PL wind profile type only)
0.03 Z0 - Surface roughness length (m) (used for LG wind profile type only)
0 XOffset - Initial offset in +x direction (shift of wind box)
================== LIDAR Parameters ===========================================================================
0 SensorType - Switch for lidar configuration (0 = None, 1 = Single Point Beam(s), 2 = Continuous, 3 = Pulsed)
0 NumPulseGate - Number of lidar measurement gates (used when SensorType = 3)
30 PulseSpacing - Distance between range gates (m) (used when SensorType = 3)
0 NumBeam - Number of lidar measurement beams (0-5)(used when SensorType = 1)
-200 FocalDistanceX - Focal distance co-ordinates of the lidar beam in the x direction (relative to hub height) (only first coordinate used for SensorType 2 and 3) (m)
0 FocalDistanceY - Focal distance co-ordinates of the lidar beam in the y direction (relative to hub height) (only first coordinate used for SensorType 2 and 3) (m)
0 FocalDistanceZ - Focal distance co-ordinates of the lidar beam in the z direction (relative to hub height) (only first coordinate used for SensorType 2 and 3) (m)
0.0 0.0 0.0 RotorApexOffsetPos - Offset of the lidar from hub height (m)
17 URefLid - Reference average wind speed for the lidar[m/s]
0.25 MeasurementInterval - Time between each measurement [s]
False LidRadialVel - TRUE => return radial component, FALSE => return ‘x’ direction estimate
1 ConsiderHubMotion - Flag whether to consider the hub motion’s impact on Lidar measurements
====================== OUTPUT ==================================================
False SumPrint - Print summary data to .IfW.sum (flag)
“Wind1VelX” X-direction wind velocity at point WindList(1)
“Wind1VelY” Y-direction wind velocity at point WindList(1)
“Wind1VelZ” Z-direction wind velocity at point WindList(1)
Dear @Naoki.Ohba,
It looks like your InflowWind input file is compatible with OpenFAST v3.5. The input file changes with each release of OpenFAST are documented here: 4.1.2. API changes between versions — OpenFAST v3.5.0 documentation. In your case, you must delete the line with VelInterpCubic and the entire LIDAR Parameters section, which were added between OpenFAST 3.4 and v3.5.
Dear Dr. Jason.Jonkman-san
Thank you very much for your support.
Unfortunately, it did not work well to do you mentioned.
However it may be version matter you steted.
I re-installed OpenFast3.5, latest version, it successfully works.
I appreciate your kind hints.
Beat Regards,
N.OHBA
