Dear @Jason.Jonkman
Thank you very much for your reply; it has helped resolve many of my questions. However, I still have two issues I would like to consult with you about.
- Regarding the influence of the tower structure, it seems that I can use data from at most 9 nodes for my calculations. However, the 5MW OC4 floating wind turbine should use data from 11 nodes. I’m unsure if this will have any effect; can I ignore it?
- Secondly, I noticed that if I want to calculate the drag force of the nacelle, I should enter the relevant data in the Nacelle Properties section. However, after looking through several other 5MW models, I found that, just like in the 5MW_OC4Semi_WSt_WavesWN files, these values are all set to zero. Like this:
====== Nacelle Properties ========================================================================== [used only when Buoyancy=True or NacelleDrag=True]
0 VolNac - Nacelle volume (m^3)
0.0, 0.0, 0.0 NacCenB - Position of nacelle center of buoyancy from yaw bearing in nacelle coordinates (m)
0, 0, 0 NacArea - Projected area of the nacelle in X, Y, Z in the nacelle coordinate system (m^2)
0, 0, 0 NacCd - Drag coefficient for the nacelle areas defined above (-)
0, 0, 0 NacDragAC - Position of aerodynamic center of nacelle drag in nacelle coordinates (m)
While reviewing the technical manual for AeroDyn Driver, I noticed that in the Hub and nacelle inputs section, the example is given as follows:
====== Hub Properties ============================================================================== [used only when Buoyancy=True]
7.0 VolHub - Hub volume (m^3)
0.0 HubCenBx - Hub center of buoyancy x direction offset (m)
5.0 VolHub - Hub volume (m^3)
0.2 HubCenBx - Hub center of buoyancy x direction offset (m)
32.0 VolNac - Nacelle volume (m^3)
0.3, 0.0, 0.05 NacCenB - Position of nacelle center of buoyancy from yaw bearing in nacelle coordinates (m)
4.67, 20.15, 20.15 NacArea - Projected area of the nacelle in X, Y, Z in the nacelle coordinate system (m^2)
0.5, 0.5, 0.5 NacCd - Drag coefficient for the nacelle areas defined above (-)
0.43, 0, 0 NacDragAC - Position of aerodynamic center of nacelle drag in nacelle coordinates (m)
The following figure shows the output results. I suspect this is related to the cabin settings.
In addition, I have attached the complete AeroDyn input file.
------- AERODYN INPUT FILE --------------------------------------------------------------------------
True Echo - Echo the input to "<rootname>.AD.ech"? (flag)
"default" DTAero - Time interval for aerodynamic calculations {or "default"} (s)
0 Wake_Mod - Wake/induction model (switch) {0=none, 1=BEMT, 3=OLAF} [Wake_Mod cannot be 2 or 3 when linearizing]
1 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
1 TwrShadow - Calculate tower influence on wind based on downstream tower shadow (switch) {0=none, 1=Powles model, 2=Eames model}
True TwrAero - Calculate tower aerodynamic loads? (flag)
False CavitCheck - Perform cavitation check? (flag) [UA_Mod must be 0 when CavitCheck=true]
False Buoyancy - Include buoyancy effects? (flag)
True NacelleDrag - Include Nacelle Drag effects? (flag)
False CompAA - Flag to compute AeroAcoustics calculation [used only when Wake_Mod = 1 or 2]
"unused" AA_InputFile - AeroAcoustics input file [used only when CompAA=true]
"default" AirDens - Air density (kg/m^3)
"default" KinVisc - Kinematic viscosity of working fluid (m^2/s)
"default" SpdSound - Speed of sound in working fluid (m/s)
"default" Patm - Atmospheric pressure (Pa) [used only when CavitCheck=True]
"default" Pvap - Vapour pressure of working fluid (Pa) [used only when CavitCheck=True]
====== Blade-Element/Momentum Theory Options ====================================================== [unused when Wake_Mod=0 or 3, except for BEM_Mod]
1 BEM_Mod - BEM model {1=legacy NoSweepPitchTwist, 2=polar} (switch) [used for all Wake_Mod to determine output coordinate system]
--- Skew correction
1 Skew_Mod - Skew model {0=No skew model, -1=Remove non-normal component for linearization, 1=skew model active}
False SkewMomCorr - Turn the skew momentum correction on or off [used only when Skew_Mod=1]
default SkewRedistr_Mod - Type of skewed-wake correction model (switch) {0=no redistribution, 1=Glauert/Pitt/Peters, default=1} [used only when Skew_Mod=1]
"default" SkewRedistrFactor - Constant used in Pitt/Peters skewed wake model {or "default" is 15/32*pi} (-) [used only when Skew_Mod=1 and SkewRedistr_Mod=1]
--- BEM algorithm
True TipLoss - Use the Prandtl tip-loss model? (flag) [unused when Wake_Mod=0 or 3]
True HubLoss - Use the Prandtl hub-loss model? (flag) [unused when Wake_Mod=0 or 3]
True TanInd - Include tangential induction in BEMT calculations? (flag) [unused when Wake_Mod=0 or 3]
False AIDrag - Include the drag term in the axial-induction calculation? (flag) [unused when Wake_Mod=0 or 3]
False TIDrag - Include the drag term in the tangential-induction calculation? (flag) [unused when Wake_Mod=0,3 or TanInd=FALSE]
"Default" IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or "default"} (-) [unused when Wake_Mod=0 or 3]
100 MaxIter - Maximum number of iteration steps (-) [unused when Wake_Mod=0]
--- Shear correction
False SectAvg - Use sector averaging (flag)
1 SectAvgWeighting - Weighting function for sector average {1=Uniform, default=1} within a sector centered on the blade (switch) [used only when SectAvg=True]
default SectAvgNPoints - Number of points per sectors (-) {default=5} [used only when SectAvg=True]
default SectAvgPsiBwd - Backward azimuth relative to blade where the sector starts (<=0) {default=-60} (deg) [used only when SectAvg=True]
default SectAvgPsiFwd - Forward azimuth relative to blade where the sector ends (>=0) {default=60} (deg) [used only when SectAvg=True]
--- Dynamic wake/inflow
0 DBEMT_Mod - Type of dynamic BEMT (DBEMT) model {0=No Dynamic Wake, -1=Frozen Wake for linearization, 1:constant tau1, 2=time-dependent tau1, 3=constant tau1 with continuous formulation} (-)
4 tau1_const - Time constant for DBEMT (s) [used only when DBEMT_Mod=1 or 3]
====== OLAF -- cOnvecting LAgrangian Filaments (Free Vortex Wake) Theory Options ================== [used only when Wake_Mod=3]
"unused" OLAFInputFileName - Input file for OLAF [used only when Wake_Mod=3]
====== Unsteady Airfoil Aerodynamics Options ====================================================
True AoA34 - Sample the angle of attack (AoA) at the 3/4 chord or the AC point {default=True} [always used]
2 UA_Mod - Unsteady Aero Model Switch (switch) {0=Quasi-steady (no UA), 2=B-L Gonzalez, 3=B-L Minnema/Pierce, 4=B-L HGM 4-states, 5=B-L HGM+vortex 5 states, 6=Oye, 7=Boeing-Vertol}
True FLookup - Flag to indicate whether a lookup for f' will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when UA_Mod>0]
3 IntegrationMethod - Switch to indicate which integration method UA uses (1=RK4, 2=AB4, 3=ABM4, 4=BDF2)
0 UAStartRad - Starting radius for dynamic stall (fraction of rotor radius [0.0,1.0]) [used only when UA_Mod>0; if line is missing UAStartRad=0]
1 UAEndRad - Ending radius for dynamic stall (fraction of rotor radius [0.0,1.0]) [used only when UA_Mod>0; if line is missing UAEndRad=1]
1 AFTabMod - Interpolation method for multiple airfoil tables {1=1D interpolation on AoA (first table only); 2=2D interpolation on AoA and Re; 3=2D interpolation on AoA and UserProp} (-)
"../5MW_Baseline/Airfoils/Cylinder1.dat" AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
"../5MW_Baseline/Airfoils/Cylinder2.dat"
"../5MW_Baseline/Airfoils/DU40_A17.dat"
"../5MW_Baseline/Airfoils/DU35_A17.dat"
"../5MW_Baseline/Airfoils/DU30_A17.dat"
"../5MW_Baseline/Airfoils/DU25_A17.dat"
"../5MW_Baseline/Airfoils/DU21_A17.dat"
"../5MW_Baseline/Airfoils/NACA64_A17.dat"
"../5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
"../5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
"../5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
====== Tail Fin Aerodynamics =======================================================================
False TFinAero - Calculate tail fin aerodynamics model (flag)
"unused" TFinFile - Input file for tail fin aerodynamics [used only when TFinAero=True]
====== Tower Influence and Aerodynamics ============================================================ [used only when TwrPotent/=0, TwrShadow/=0, TwrAero=True, or Buoyancy=True]
11 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow/=0, TwrAero=True, or Buoyancy=True]
TwrElev TwrDiam TwrCd TwrTI TwrCb ! TwrTI used only when TwrShadow=2; TwrCb used only when Buoyancy=True
(m) (m) (-) (-) (-)
1.0000000E+01 6.5000000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
1.7760000E+01 6.2400000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
3.5520000E+01 5.9700000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
4.3280000E+01 5.7100000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
5.1040000E+01 5.4500000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
4.8800000E+01 5.1800000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
6.6560000E+01 4.9200000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
7.4320000E+01 4.6600000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
8.2080000E+01 4.4000000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
7.9840000E+01 4.1300000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
9.7600000E+01 3.8700000E+00 1.0000000E+00 1.0000000E-01 0.0000000E+00
True SumPrint - Generate a summary file listing input options and interpolated properties to "<rootname>.AD.sum"? (flag)
3 NBlOuts - Number of blade node outputs [0 - 9] (-)
1, 9, 19 BlOutNd - Blade nodes whose values will be output (-)
9 NTwOuts - Number of tower node outputs [0 - 9] (-)
1, 2, 3, 4, 5, 6, 7, 8, 9 TwOutNd - Tower nodes whose values will be output (-)
RtArea
RtAeroCt
RtAeroFxi
RtAeroFyi
RtAeroFzi
NcFdx
NcFdy
NcFdz
TwN1Fdx
TwN2Fdx
TwN3Fdx
TwN4Fdx
TwN5Fdx
TwN6Fdx
TwN7Fdx
TwN8Fdx
TwN9Fdx
TwN1Fdy
TwN2Fdy
TwN3Fdy
TwN4Fdy
TwN5Fdy
TwN6Fdy
TwN7Fdy
TwN8Fdy
TwN9Fdy
END of OutList section (the word "END" must appear in the first 3 columns of the last OutList line)
---------------------- NODE OUTPUTS --------------------------------------------
1 BldNd_BladesOut - Number of blades to output all node information at. Up to number of blades on turbine. (-)
ALL BldNd_BlOutNd - Specify a portion of the nodes to output. {"ALL", "Tip", "Root", or a list of node numbers} (-)
OutList_Nodal - The next line(s) contains a list of output parameters. See OutListParameters.xlsx for a listing of available output channels, (-)
END (the word "END" must appear in the first 3 columns of this last OutList line in the optional nodal output section)
Junius
