I’ve used the same DOF you mentioned in your excel file. which means: All DOFs enabled except GenDOF and DrTrDOF (of course TeetDOF = False).
Regarding the wake, I’ve used the same setting provided by the baseline 5MW files, which means: InfModel = EQUIL & IndModel = SWIRL.
Here are my FAST and Aerodyn files
FAST File for TSR=5, BlPitch = +1 deg, and Wind speed = 8m/s.
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v6.0.
False Echo - Echo input data to "echo.out" (flag)
1 AnalMode - 1 Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
200.0 TMax - Total run time (s)
0.0125 DT - Integration time step (s)
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink} (switch)
0 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink} (switch)
1 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined from Simulink} (switch)
1800 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
8376.58 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
0.002585 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
0.0 NacYawF - Final yaw angle for yaw maneuvers (degrees)
9999.9 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.9 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.9 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
+1.0 BlPitch(1) - Blade 1 initial pitch (degrees)
+1.0 BlPitch(2) - Blade 2 initial pitch (degrees)
+1.0 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
0.0 B1PitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
True YawDOF - Yaw DOF (flag)
6.06882 RotSpeed - (TSR = 5, WndSpd = 8m/s) Initial or fixed rotor speed (rpm) [12.1]
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E3 NacMass - Nacelle mass (kg)
56.78E3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
100.0 GBoxEff - Gearbox efficiency (%)
97.0 GBRatio - Gearbox ratio (-)
28.1162E3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
0 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
"common/NRELOffshrBsline5MW_Tower_Onshore.dat" TwrFile - Name of file containing tower properties (quoted string)
9028.32E6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, Cd*Area (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, Cd*Area (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
"common/NRELOffshrBsline5MW_Blade.dat" BldFile(1) - Name of file containing properties for blade 1 (quoted string)
"common/NRELOffshrBsline5MW_Blade.dat" BldFile(2) - Name of file containing properties for blade 2 (quoted string)
"common/NRELOffshrBsline5MW_Blade.dat" BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
"BL5MW_AeroDyn.ipt" ADFile - Name of file containing AeroDyn input parameters (quoted string)
NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
"common/NRELOffshrBsline5MW_ADAMSSpecific.dat" ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string) [unused when ADAMSPrep=1]
"common/NRELOffshrBsline5MW_Linear.dat" LinFile - Name of file containing FAST linearization parameters (quoted string) [unused when AnalMode=1]
True SumPrint - Print summary data to "<RootName>.fsm" (flag)
True TabDelim - Generate a tab-delimited tabular output file. (flag)
"ES10.3E2" OutFmt - Format used for tabular output except time. Resulting field should be 10 characters. (quoted string) [not checked for validity!]
0.0 TStart - Time to begin tabular output (s)
8 DecFact - Decimation factor for tabular output {1: output every time step} (-)
1.0 SttsTime - Amount of time between screen status messages (sec)
TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
0 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
1,2,5,9,13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
OutList - The next line(s) contains a list of output parameters. See OutList.txt for a listing of available output channels, (-)
"HorWindV" - HorWindV
"RotSpeed" - Rotor Speed
"GenSpeed" - high-speed shaft speeds
"BldPitch1" - Blade 1pitch angle
"TSR" - Tip Speed Ratio
"RotPwr" - Rotor Power
"RotCp" - Rotor Power Factor
"GenPwr" - Generator Power
"GenCp" - Generator Power factor
"RotThrust" - Rotor Thrust
"RotCt" - Rotor Thrust coeffecient
"RotTorq" - Rotor Torque
"RotCq" - Rotor Torque Coeffecient
"NacYaw" - Nacelle Yaw
END of FAST input file (the word "END" must appear in the first 3 columns of this last line).
AeroDyn.ipt file
NREL 5.0 MW offshore baseline aerodynamic input properties; Compatible with AeroDyn v12.58.
SI SysUnits - System of units for used for input and output [must be SI for FAST] (unquoted string)
STEADY StallMod - BEDDOES Dynamic stall included [BEDDOES or STEADY] (unquoted string)
USE_CM UseCm - Use aerodynamic pitching moment model? [USE_CM or NO_CM] (unquoted string)
EQUIL InfModel - Inflow model [DYNIN or EQUIL] (unquoted string)
SWIRL IndModel - Induction-factor model [NONE or WAKE or SWIRL] (unquoted string)
0.005 AToler - Induction-factor tolerance (convergence criteria) (-)
PRANDtl TLModel - Tip-loss model (EQUIL only) [PRANDtl, GTECH, or NONE] (unquoted string)
PRANDtl HLModel - Hub-loss model (EQUIL only) [PRANdtl or NONE] (unquoted string)
"WindData\BL5MW_Cp_8mps.hh" WindFile - Name of file containing wind data (quoted string) BL_5MW_OnShore-18_2mps
90.0 HH - Wind reference (hub) height [TowerHt+Twr2Shft+OverHang*SIN(ShftTilt)] (m)
0.0 TwrShad - Tower-shadow velocity deficit (-)
9999.9 ShadHWid - Tower-shadow half width (m)
9999.9 T_Shad_Refpt- Tower-shadow reference point (m)
1.464E-5 KinVisc - Kinematic air viscosity [CURRENTLY IGNORED] (m^2/sec)
0.02479 DTAero - Time interval for aerodynamic calculations (sec)
8 NumFoil - Number of airfoil files (-)
"AeroData\Cylinder1.dat" FoilNm - Names of the airfoil files [NumFoil lines] (quoted strings)
"AeroData\Cylinder2.dat"
"AeroData\DU40_A17.dat"
"AeroData\DU35_A17.dat"
"AeroData\DU30_A17.dat"
"AeroData\DU25_A17.dat"
"AeroData\DU21_A17.dat"
"AeroData\NACA64_A17.dat"
17 BldNodes - Number of blade nodes used for analysis (-)
RNodes AeroTwst DRNodes Chord NFoil PrnElm
2.8667 13.308 2.7333 3.542 1 NOPRINT
5.6000 13.308 2.7333 3.854 1 NOPRINT
8.3333 13.308 2.7333 4.167 2 NOPRINT
11.7500 13.308 4.1000 4.557 3 NOPRINT
15.8500 11.480 4.1000 4.652 4 NOPRINT
19.9500 10.162 4.1000 4.458 4 NOPRINT
24.0500 9.011 4.1000 4.249 5 NOPRINT
28.1500 7.795 4.1000 4.007 6 NOPRINT
32.2500 6.544 4.1000 3.748 6 NOPRINT
36.3500 5.361 4.1000 3.502 7 NOPRINT
40.4500 4.188 4.1000 3.256 7 NOPRINT
44.5500 3.125 4.1000 3.010 8 NOPRINT
48.6500 2.319 4.1000 2.764 8 NOPRINT
52.7500 1.526 4.1000 2.518 8 NOPRINT
56.1667 0.863 2.7333 2.313 8 NOPRINT
58.9000 0.370 2.7333 2.086 8 NOPRINT
61.6333 0.106 2.7333 1.419 8 NOPRINT
However, I’ve a question regarding the provided settings for the Simple VS (VSContrl = 1), this will make use of the following 4 parameters (VS_RtGnSp, VS_RtTq, VS_Rgn2K, VS_SlPc). I think these given data are for the 1.5MW, and they should be changed to
VS_RtGnSp = 12.1 [rpm, rated rotor speed] * 97 (gearbox ratio) *0.99 (99% of rated HSS speed) = 1162 rpm
VS_RtTq = 43093.55 [N.m]
VS_Rgn2K = 0.018 (see note later)
VS_SlPc = 11.4807 (see note later)
The calculations of these parameters are made in analogous way to what is done in http://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&sqi=2&ved=0CEMQFjAA&url=http%3A%2F%2Fwww.nrel.gov%2Fdocs%2Ffy08osti%2F42437.pdf&ei=UNBhT9OhKIOJ4gTC2rj0Bw&usg=AFQjCNGQL7BdILolfTKVrF5YHHpr-NGnKg pages 22-25.
Of course, these values will not affect the results obtained from FAST (as GenDOF = False).
Rannam Chaaban.
