Hi everyone,
I am trying to obtain wind turbine linearized mass, dumping and stiffness matrix in order to create a frequency domain numerical model of an off-shore wind turbine. I found out that is possible to calculate theese marix with FAST. Reading different articles, I understood that is possible to do this dividing the wind turbine in 3 parts:
- Tower + Nacelle (Structural + Aerodynamic loads)
- Floating Platform (Structural + Hydrodynamic loads)
- Mooring lines
In this case I just need the matrix concerning the part 1). The article: link.springer.com/article/10.10 ⌠016-0072-4 (section 2.3) can better explain the model.
In order to perform this evaluation, I am running the Cert Test 24 (FAST Certification Test #24: NREL 5.0 MW Baseline Wind Turbine with OC3 Hywind Configuration) with âRun_OpenLoop.mâ . I modified the imput file Test24 in CertTest disabling CompHydro and CompMoorin and I enabled Linearization. Of course I also modified the related imput files AeroDyn, ServoDyn, InflowWind (following Matlab warining instruction). Nonethless, I obtained this error warning:
Error reported by S-function 'FAST_SFunc' in 'OpenLoop/FAST Nonlinear Wind Turbine/S-Function':
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:InflowWind_CalcOutput:CalcOutput:IfW_UniformWind_CalcOutput:GetWindSpeed:Height
must not be negative.
IfW_UniformWind_CalcOutput: Error calculating the wind speed at position (0.48055, -6.10150E-04,
-0.13752) in the wind-file coordinates"
I donât understand what I am doing wrong. I attached also my imput files. Could you help me to understand my errors?
------- FAST v8.16.* INPUT FILE ------------------------------------------------
FAST Certification Test #24: NREL 5.0 MW Baseline Wind Turbine with OC3 Hywind Configuration, for use in offshore analysis
False Echo - Echo input data to <RootName>.ech (flag)
"FATAL" AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
60 TMax - Total run time (s)
0.0125 DT - Recommended module time step (s)
1 InterpOrder - Interpolation order for input/output time history (-) {1=linear, 2=quadratic}
1.5 DT_UJac - Time between calls to get Jacobians (s)
1E+06 UJacSclFact - Scaling factor used in Jacobians (-)
0 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn}
0 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
"5MW_Baseline/NRELOffshrBsline5MW_OC3Hywind_ElastoDyn.dat" EDFile - Name of file containing ElastoDyn input parameters (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_InflowWind_12mps.dat" InflowFile - Name of file containing inflow wind input parameters (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_OC3Hywind_AeroDyn15.dat" AeroFile - Name of file containing aerodynamic input parameters (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_OC3Hywind_ServoDyn.dat" ServoFile - Name of file containing control and electrical-drive input parameters (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_OC3Hywind_HydroDyn.dat" HydroFile - Name of file containing hydrodynamic input parameters (quoted string)
"unused" SubFile - Name of file containing sub-structural input parameters (quoted string)
"5MW_Baseline/NRELOffshrBsline5MW_OC3Hywind_MAP.dat" MooringFile - Name of file containing mooring system input parameters (quoted string)
"unused" IceFile - Name of file containing ice input parameters (quoted string)
True SumPrint - Print summary data to "<RootName>.sum" (flag)
1 SttsTime - Amount of time between screen status messages (s)
99999 ChkptTime - Amount of time between creating checkpoint files for potential restart (s)
0.0125 DT_Out - Time step for tabular output (s) (or "default")
0 TStart - Time to begin tabular output (s)
2 OutFileFmt - Format for tabular (time-marching) output file (switch) {1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both}
True TabDelim - Use tab delimiters in text tabular output file? (flag) {uses spaces if false}
"ES10.3E2" OutFmt - Format used for text tabular output, excluding the time channel. Resulting field should be 10 characters. (quoted string)
True Linearize - Linearization analysis (flag)
2 NLinTimes - Number of times to linearize (-) [>=1] [unused if Linearize=False]
30, 60 LinTimes - List of times at which to linearize (s) [1 to NLinTimes] [unused if Linearize=False]
1 LinInputs - Inputs included in linearization (switch) {0=none; 1=standard; 2=all module inputs (debug)} [unused if Linearize=False]
1 LinOutputs - Outputs included in linearization (switch) {0=none; 1=from OutList(s); 2=all module outputs (debug)} [unused if Linearize=False]
False LinOutJac - Include full Jacobians in linearization output (for debug) (flag) [unused if Linearize=False; used only if LinInputs=LinOutputs=2]
False LinOutMod - Write module-level linearization output files in addition to output for full system? (flag) [unused if Linearize=False]
0 WrVTK - VTK visualization data output: (switch) {0=none; 1=initialization data only; 2=animation}
2 VTK_type - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
false VTK_fields - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
15 VTK_fps - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2]
[code]------- AERODYN v15.03.* INPUT FILE ------------------------------------------------
False Echo - Echo the input to â.AD.echâ? (flag)
âdefaultâ DTAero - Time interval for aerodynamic calculations {or âdefaultâ} (s)
1 WakeMod - Type of wake/induction model (switch) {0=none, 1=BEMT}
1 AFAeroMod - Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model}
1 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
False TwrShadow â Calculate tower influence on wind based on downstream tower shadow? (flag)
True TwrAero - Calculate tower aerodynamic loads? (flag)
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [used only when WakeMod=1]
true TanInd - Include tangential induction in BEMT calculations? (flag) [used only when WakeMod=1]
False AIDrag - Include the drag term in the axial-induction calculation? (flag) [used only when WakeMod=1]
False TIDrag - Include the drag term in the tangential-induction calculation? (flag) [used only when WakeMod=1 and TanInd=TRUE]
âDefaultâ IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or âdefaultâ} (-) [used only when WakeMod=1]
100 MaxIter - Maximum number of iteration steps (-) [used only when WakeMod=1]
3 UAMod - Unsteady Aero Model Switch (switch) {1=Baseline model (Original), 2=Gonzalezâs variant (changes in Cn,Cc,Cm), 3=Minemma/Pierce variant (changes in Cc and Cm)} [used only when AFAeroMod=2]
True FLookup - Flag to indicate whether a lookup for fâ will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
âAirfoils/Cylinder1.datâ AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
âAirfoils/Cylinder2.datâ
âAirfoils/DU40_A17.datâ
âAirfoils/DU35_A17.datâ
âAirfoils/DU30_A17.datâ
âAirfoils/DU25_A17.datâ
âAirfoils/DU21_A17.datâ
âAirfoils/NACA64_A17.datâ
âNRELOffshrBsline5MW_AeroDyn_blade.datâ ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
âNRELOffshrBsline5MW_AeroDyn_blade.datâ ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
âNRELOffshrBsline5MW_AeroDyn_blade.datâ ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
====== Tower Influence and Aerodynamics ============================================================= [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
11 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
TwrElev TwrDiam TwrCd
(m) (m) (-)
1.0000000E+01 6.5000000E+00 1.0000000E+00
1.7760000E+01 6.2400000E+00 1.0000000E+00
2.5520000E+01 5.9700000E+00 1.0000000E+00
3.3280000E+01 5.7100000E+00 1.0000000E+00
4.1040000E+01 5.4500000E+00 1.0000000E+00
4.8800000E+01 5.1800000E+00 1.0000000E+00
5.6560000E+01 4.9200000E+00 1.0000000E+00
6.4320000E+01 4.6600000E+00 1.0000000E+00
7.2080000E+01 4.4000000E+00 1.0000000E+00
7.9840000E+01 4.1300000E+00 1.0000000E+00
8.7600000E+01 3.8700000E+00 1.0000000E+00
True SumPrint - Generate a summary file listing input options and interpolated properties to â.AD.sumâ? (flag)
3 NBlOuts - Number of blade node outputs [0 - 9] (-)
1, 9, 19 BlOutNd - Blade nodes whose values will be output (-)
1, 2, 6 TwOutNd - Tower nodes whose values will be output (-)
âRtAreaâ
âB1N3Clrnc, B2N3Clrnc, B3N3Clrncâ
END of input file (the word âENDâ must appear in the first 3 columns of this last OutList line)
[/code]
[code]------- InflowWind v3.01.* INPUT FILE -------------------------------------------------------------------------
12 m/s turbulent winds on 31x31 FF grid and tower for FAST CertTests #18, #19, #21, #22, #23, and #24
1 WindType - switch for wind file type (1=steady; 2=uniform; 3=binary TurbSim FF; 4=binary Bladed-style FF; 5=HAWC format; 6=User defined)
0 PropagationDir - Direction of wind propagation (meteoroligical rotation from aligned with X (positive rotates towards -Y) â degrees)
1 NWindVel - Number of points to output the wind velocity (0 to 9)
0 WindVxiList - List of coordinates in the inertial X direction (m)
0 WindVyiList - List of coordinates in the inertial Y direction (m)
90 WindVziList - List of coordinates in the inertial Z direction (m)
================== Parameters for Steady Wind Conditions [used only for WindType = 1] =========================
12 HWindSpeed - Horizontal windspeed (m/s)
90 RefHt - Reference height for horizontal wind speed (m)
0.2 PLexp - Power law exponent (-)
================== Parameters for Uniform wind file [used only for WindType = 2] ============================
âWind/90m_12mps_twr.btsâ Filename - Filename of time series data for uniform wind field. (-)
125.88 RefLength - Reference length for linear horizontal and vertical sheer (-)
================== Parameters for Binary TurbSim Full-Field files [used only for WindType = 3] ==============
âWind/90m_12mps_twr.btsâ Filename - Name of the Full field wind file to use (.bts)
================== Parameters for Binary Bladed-style Full-Field files [used only for WindType = 4] =========
âWind/90m_12mps_twrâ FilenameRoot - Rootname of the full-field wind file to use (.wnd, .sum)
False TowerFile - Have tower file (.twr) (flag)
================== Parameters for HAWC-format binary files [Only used with WindType = 5] =====================
âwasp\Output\basic_5u.binâ FileName_u - name of the file containing the u-component fluctuating wind (.bin)
âwasp\Output\basic_5v.binâ FileName_v - name of the file containing the v-component fluctuating wind (.bin)
âwasp\Output\basic_5w.binâ FileName_w - name of the file containing the w-component fluctuating wind (.bin)
64 nx - number of grids in the x direction (in the 3 files above) (-)
32 ny - number of grids in the y direction (in the 3 files above) (-)
32 nz - number of grids in the z direction (in the 3 files above) (-)
16 dx - distance (in meters) between points in the x direction (m)
3 dy - distance (in meters) between points in the y direction (m)
3 dz - distance (in meters) between points in the z direction (m)
90 RefHt - reference height; the height (in meters) of the vertical center of the grid (m)
------------- Scaling parameters for turbulence ---------------------------------------------------------
1 ScaleMethod - Turbulence scaling method [0 = none, 1 = direct scaling, 2 = calculate scaling factor based on a desired standard deviation]
1 SFx - Turbulence scaling factor for the x direction (-) [ScaleMethod=1]
1 SFy - Turbulence scaling factor for the y direction (-) [ScaleMethod=1]
1 SFz - Turbulence scaling factor for the z direction (-) [ScaleMethod=1]
12 SigmaFx - Turbulence standard deviation to calculate scaling from in x direction (m/s) [ScaleMethod=2]
8 SigmaFy - Turbulence standard deviation to calculate scaling from in y direction (m/s) [ScaleMethod=2]
2 SigmaFz - Turbulence standard deviation to calculate scaling from in z direction (m/s) [ScaleMethod=2]
------------- Mean wind profile parameters (added to HAWC-format files) ---------------------------------
5 URef - Mean u-component wind speed at the reference height (m/s)
2 WindProfile - Wind profile type (0=constant;1=logarithmic,2=power law)
0.2 PLExp - Power law exponent (-) (used for PL wind profile type only)
0.03 Z0 - Surface roughness length (m) (used for LG wind profile type only)
====================== OUTPUT ==================================================
False SumPrint - Print summary data to .IfW.sum (flag)
âWind1VelXâ X-direction wind velocity at point WindList(1)
âWind1VelYâ Y-direction wind velocity at point WindList(1)
âWind1VelZâ Z-direction wind velocity at point WindList(1)
[/code]
[code]------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
âdefaultâ DT - Communication interval for controllers (s) (or âdefaultâ)
0 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
2 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
0 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
0 YawNeut - Neutral yaw positionâyaw spring force is zero at this yaw (degrees)
9.02832E+09 YawSpr - Nacelle-yaw spring constant (N-m/rad)
1.916E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
0 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
---------------------- TUNED MASS DAMPER ---------------------------------------
False CompNTMD - Compute nacelle tuned mass damper {true/false} (flag)
âunusedâ NTMDfile - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
False CompTTMD - Compute tower tuned mass damper {true/false} (flag)
âunusedâ TTMDfile - Name of the file for tower tuned mass damper (quoted string) [unused when CompTTMD is false]
âServoData/DISCON_OC3Hywind_x64.dllâ DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
âDISCON.INâ DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
âDISCONâ DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
âdefaultâ DLL_DT - Communication interval for dynamic library (s) (or âdefaultâ) [used only with Bladed Interface]
false DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to .sum (flag) (currently unused)
âES10.3E2â OutFmt - Format used for text tabular output (except time). Resulting field should be 10 characters. (quoted string) (currently unused)
30 TStart - Time to begin tabular output (s) (currently unused)
âGenPwrâ - Electrical generator power and torque
âGenTqâ - Electrical generator power and torque
[/code]
