I want to linearize NREL 5MW, particularly 5MW_ITIBarge_DLL_WTurb_WavesIrr, with enabling only two DOF, PtfmPDOF and GenDOF, in order to design state feedback controller to regulate the generator speed using collective pitch control as a single input. This means the state A matrix should be 4x4 and the input gain B matrix should be 4x1. However, I found the dimension of B matrix does not agree with what I expected. Its dimension is 4x9. Moreover, the corresponding gain regarding the collective pitch control input is zero.
Is there any way to select the input for the linearization or solve this problem ?
The Input file is shown below:
------- OpenFAST example INPUT FILE -------------------------------------------
FAST Certification Test #22: NREL 5.0 MW Baseline Wind Turbine with ITI Barge Configuration, for use in offshore analysis
True Echo - Echo input data to <RootName>.ech (flag)
"FATAL" AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
100 TMax - Total run time (s)
0.0125 DT - Recommended module time step (s)
99999 DT_UJac - Time between calls to get Jacobians (s)
1E+06 UJacSclFact - Scaling factor used in Jacobians (-)
0 CompAero - Compute aerodynamic loads (switch) {0=None; 1=AeroDyn v14; 2=AeroDyn v15}
0 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
0 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
"NRELOffshrBsline5MW_ITIBarge4_ElastoDyn.dat" EDFile - Name of file containing ElastoDyn input parameters (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_InflowWind_Steady8mps.dat" InflowFile - Name of file containing inflow wind input parameters (quoted string)
"NRELOffshrBsline5MW_AeroDyn_Equil_noTwr.dat" AeroFile - Name of file containing aerodynamic input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge4_ServoDyn.dat" ServoFile - Name of file containing control and electrical-drive input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge4_HydroDyn.dat" HydroFile - Name of file containing hydrodynamic input parameters (quoted string)
"unused" SubFile - Name of file containing sub-structural input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge4_MAP.dat" MooringFile - Name of file containing mooring system input parameters (quoted string)
"unused" IceFile - Name of file containing ice input parameters (quoted string)
True SumPrint - Print summary data to "<RootName>.sum" (flag)
10 SttsTime - Amount of time between screen status messages (s)
1000 ChkptTime - Amount of time between creating checkpoint files for potential restart (s)
0.0125 DT_Out - Time step for tabular output (s) (or "default")
0 TStart - Time to begin tabular output (s)
0 OutFileFmt - Format for tabular (time-marching) output file (switch) {1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both}
True TabDelim - Use tab delimiters in text tabular output file? (flag) {uses spaces if false}
"ES10.3E2" OutFmt - Format used for text tabular output, excluding the time channel. Resulting field should be 10 characters. (quoted string)
True Linearize - Linearization analysis (flag)
2 NLinTimes - Number of times to linearize (-) [>=1] [unused if Linearize=False]
1, 60 LinTimes - List of times at which to linearize (s) [1 to NLinTimes] [unused if Linearize=False]
1 LinInputs - Inputs included in linearization (switch) {0=none; 1=standard; 2=all module inputs (debug)} [unused if Linearize=False]
0 LinOutputs - Outputs included in linearization (switch) {0=none; 1=from OutList(s); 2=all module outputs (debug)} [unused if Linearize=False]
False LinOutJac - Include full Jacobians in linearization output (for debug) (flag) [unused if Linearize=False; used only if LinInputs=LinOutputs=2]
False LinOutMod - Write module-level linearization output files in addition to output for full system? (flag) [unused if Linearize=False]
0 WrVTK - VTK visualization data output: (switch) {0=none; 1=initialization data only; 2=animation}
2 VTK_type - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
false VTK_fields - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
15 VTK_fps - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2]
The Elastodyn file is shown below:
[code]------- ELASTODYN v1.03.* INPUT FILE -------------------------------------------
“default” DT - Integration time step (s)
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
1.03 BlPitch(1) - Blade 1 initial pitch (degrees)
1.03 BlPitch(2) - Blade 2 initial pitch (degrees)
1.03 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
12.1 RotSpeed - Initial or fixed rotor speed (rpm)
2 PtfmPitch - Initial or fixed pitch tilt rotational displacement of platform (degrees)
63 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.0191 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5 ShftTilt - Rotor shaft tilt angle (degrees)
0 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-0.281768 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
-0 PtfmRefzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
5.452E+06 PtfmMass - Platform mass (kg)
7.269E+08 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
7.269E+08 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
1.4539E+09 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
17 BldNodes - Number of blade nodes (per blade) used for analysis (-)
“../5MW_Baseline/NRELOffshrBsline5MW_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“../5MW_Baseline/NRELOffshrBsline5MW_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“../5MW_Baseline/NRELOffshrBsline5MW_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
97 GBRatio - Gearbox ratio (-)
“NRELOffshrBsline5MW_ITIBarge4_ElastoDyn_Tower.dat” TwrFile - Name of file containing tower properties (quoted string)
30 TStart - Time to begin tabular output (s) (currently unused)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
10 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
1 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
9 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
“BldPitch1” - Pitch angles for blades 1, 2, and 3
“BldPitch2” - Pitch angles for blades 1, 2, and 3
“BldPitch3” - Pitch angles for blades 1, 2, and 3
“Azimuth” - Blade 1 azimuth angle
“RotSpeed” - Low-speed shaft and high-speed shaft speeds
“GenSpeed” - Low-speed shaft and high-speed shaft speeds
“GenAccel” - Angular acceleration of the high-speed shaft and generator
“PtfmSurge” - Platform translational surge, sway, and heave displacements
“PtfmSway” - Platform translational surge, sway, and heave displacements
“PtfmHeave” - Platform translational surge, sway, and heave displacements
“PtfmRoll” - Platform rotational roll, pitch and yaw displacements
“PtfmPitch” - Platform rotational roll, pitch and yaw displacements
“PtfmYaw” - Platform rotational roll, pitch and yaw displacements
“PtfmRVxi” - Platform roll tilt angular (rotational) velocity
“PtfmRVyi” - Platform pitch tilt angular (rotational) velocity
“PtfmRVzi” - Platform yaw angular (rotational) velocity
“PtfmTAxt” - Platform translation accelerations (absolute) in the tower-base coordinate system
“PtfmTAyt” - Platform translation accelerations (absolute) in the tower-base coordinate system
“PtfmTAzt” - Platform translation accelerations (absolute) in the tower-base coordinate system
[/code]
The servodyn file is shown below:
[code]------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
“default” DT - Communication interval for controllers (s) (or “default”)
0 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
2 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
0 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
9.02832E+09 YawSpr - Nacelle-yaw spring constant (N-m/rad)
1.916E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
0 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
---------------------- TUNED MASS DAMPER ---------------------------------------
False CompNTMD - Compute nacelle tuned mass damper {true/false} (flag)
“unused” NTMDfile - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
False CompTTMD - Compute tower tuned mass damper {true/false} (flag)
“unused” TTMDfile - Name of the file for tower tuned mass damper (quoted string) [unused when CompTTMD is false]
“../5MW_Baseline/ServoData/DISCON_ITIBarge.dll” DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
“DISCON.IN” DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
“DISCON” DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
“default” DLL_DT - Communication interval for dynamic library (s) (or “default”) [used only with Bladed Interface]
false DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to .sum (flag) (currently unused)
“GenPwr” - Electrical generator power and torque
“GenTq” - Electrical generator power and torque
[/code]
The linearization output file is shown below:
Linearized model: Predictions were generated on 26-Jun-2020 at 20:46:04 using OpenFAST, compiled as a 64-bit application using single precision at commit v2.3.0-dirty
linked with NWTC Subroutine Library; ElastoDyn; InflowWind; ServoDyn
Description from the FAST input file: FAST Certification Test #22: NREL 5.0 MW Baseline Wind Turbine with ITI Barge Configuration, for use in offshore analysis
Simulation information:
Simulation time: 1.0000 s
Rotor Speed: 1.2671 rad/s
Azimuth: 1.2671 rad
Number of continuous states: 4
Number of discrete states: 0
Number of constraint states: 0
Number of inputs: 9
Number of outputs: 0
Jacobians included in this file? No
Order of continuous states:
Row/Column Operating Point Rotating Frame? Description
1 3.648E-02 F ED Platform pitch tilt rotation DOF (internal DOF index = DOF_P), rad
2 5.979E+00 F ED Variable speed generator DOF (internal DOF index = DOF_GeAz), rad
3 3.171E-03 F ED First time derivative of Platform pitch tilt rotation DOF (internal DOF index = DOF_P), rad/s
4 1.267E+00 F ED First time derivative of Variable speed generator DOF (internal DOF index = DOF_GeAz), rad/s
Order of continuous state derivatives:
1 3.171E-03 F First time derivative of ED Platform pitch tilt rotation DOF (internal DOF index = DOF_P), rad/s
2 1.267E+00 F First time derivative of ED Variable speed generator DOF (internal DOF index = DOF_GeAz), rad/s
3 3.275E-03 F First time derivative of ED First time derivative of Platform pitch tilt rotation DOF (internal DOF index = DOF_P), rad/s/s
4 -1.568E-05 F First time derivative of ED First time derivative of Variable speed generator DOF (internal DOF index = DOF_GeAz), rad/s/s
Order of inputs:
1 1.800E+01 F IfW Extended input: horizontal wind speed (steady/uniform wind), m/s
2 0.000E+00 F IfW Extended input: vertical power-law shear exponent, -
3 0.000E+00 F IfW Extended input: propagation direction, rad
4 1.798E-02 T ED Blade 1 pitch command, rad
5 1.798E-02 T ED Blade 2 pitch command, rad
6 1.798E-02 T ED Blade 3 pitch command, rad
7 0.000E+00 F ED Yaw moment, Nm
8 7.060E+00 F ED Generator torque, Nm
9 1.798E-02 F ED Extended input: collective blade-pitch command, rad
Linearized state matrices:
A: 4 x 4
0.000E+00 0.000E+00 1.000E+00 0.000E+00
0.000E+00 0.000E+00 0.000E+00 1.000E+00
9.850E-02 -2.129E-14 6.212E-18 1.825E-15
-1.032E-07 -2.434E-07 6.081E-08 1.377E-05
B: 4 x 9
0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 -2.938E-16 0.000E+00
0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 -2.220E-06 0.000E+00
