Dear Dr. Jonkman,
I am now working on control of the NREL 5 MW - OC4-
DeepCwind SemiSubmersible wind turbine. I was wondering whether I can obtain a linearized model for this wind turbine including the semi-submersible platform at different wind speed conditions in FAST. I tried this in FAST v7.02.00d-bjj with the following fst file but failed and got the error message that “TwrNodes must not be less than 1”. However, the “TwrNodes” is set to be 20 in the fst file.
NREL 5.0 MW Baseline Wind Turbine OC4
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v7.0.
False Echo - Echo input data to "echo.out" (flag)
2 AnalMode - Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
500 TMax - Total run time (s)
0.0125 DT - Integration time step (s) 0.0125
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink} (switch)
0 9999.9 TYCOn - Time to enable active yaw control (s) [unused when YCMode=0]
0 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink} (switch)
1 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined from Simulink} (switch)
1.1737e+03 9999.9e-9 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
43093.55 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
9999.9e-9 .0255764 9999.9e-9 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
9999.9e-9 10 9999.9e-9 VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%) [used only when VSContrl=1]
1 GenModel - Generator model {1: simple, 2: Thevenin, 3: user-defined from routine UserGen} (switch) [used only when VSContrl=0]
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
0.0 NacYawF - Final yaw angle for yaw maneuvers (degrees)
9999.9 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.9 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.9 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
-8.1885 15.11 17.638503882818796 14.842799930247352 15.0976 15.1762 18.1936 BlPitch(1) - Blade 1 initial pitch (degrees)
-8.1885 15.11 17.638503882818796 14.842799930247352 15.0976 15.1762 18.1936 BlPitch(2) - Blade 2 initial pitch (degrees)
-8.1885 15.11 17.638503882818796 14.842799930247352 15.0976 15.1762 18.1936 BlPitch(3) - Blade 3 initial pitch (degrees)
0.0 B1PitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
F GenDOF - Generator DOF (flag)
T YawDOF - Yaw DOF (flag)
T CompAero - Compute aerodynamic forces (flag)
F CompNoise - Compute aerodynamic noise (flag)
12.13 RotSpeed - Initial or fixed rotor speed (rpm)
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E3 NacMass - Nacelle mass (kg)
56.78E3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
100.0 GBoxEff - Gearbox efficiency (%)
94 100 94.4 GenEff - Generator efficiency [ignored by the Thevenin and user-defined generator models] (%)
97.0 GBRatio - Gearbox ratio (-)
28.1162E3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
3 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
"OC4Semi_Modeling_PlatformLin.dat" PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
"Added_Damping.dat" PtfmAddFile
0 Kx - Surge stiffness
0 Ky - Sway stiffness
0 Kz - Heave stiffness
0 Kp - Roll stiffness
0 Kq - Pitch stiffness
0 Kr - Yaw stiffness
0 Bx - Surge damping
0 By - Sway damping
0 Bz - Heave damping
0 Bp - Roll damping
0 Bq - Pitch damping
0 Br - Yaw damping
395000 Bx_quad - Quadratic Surge damping
395000 By_quad - Quadratic Sway damping
3880000 Bz_quad - Quadratic Heave damping
37000000000 Bp_quad - Quadratic Roll damping
37000000000 Bq_quad - Quadratic Pitch damping
4080000000 Br_quad - Quadratic Yaw damping
"NRELOffshrBsline5MW_Tower_OC4DeepCwindSemi.dat" TwrFile - Name of file containing tower properties (quoted string)
9028.32E6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, Cd*Area (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, Cd*Area (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
"NRELOffshrBsline5MW_Blade.dat" BldFile1 - Name of file containing properties for blade 1 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile2 - Name of file containing properties for blade 2 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile3 - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
"OC4Semi_Modeling_AerodynLin.ipt" ADFile - Name of file containing AeroDyn input parameters (quoted string)
NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
"NRELOffshrBsline5MW_ADAMSSpecific.dat" ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string) [unused when ADAMSPrep=1]
"OC4Semi_LinearR3.dat" LinFile - Name of file containing FAST linearization parameters (quoted string) [unused when AnalMode=1]
True SumPrint - Print summary data to "<RootName>.fsm" (flag)1
1 OutFileFmt - Format for tabular (time-marching) output file(s) (1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both) (switch)
True TabDelim - Generate a tab-delimited tabular output file. (flag)
"ES10.3E2" OutFmt - Format used for tabular output except time. Resulting field should be 10 characters. (quoted string) [not checked for validity!]
0.0 TStart - Time to begin tabular output (s)
1 DecFact - Decimation factor for tabular output {1: output every time step} (-)
1.0 SttsTime - Amount of time between screen status messages (sec)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
10 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
1 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
9 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
OutList - The next line(s) contains a list of output parameters. See OutList.txt for a listing of available output channels, (-)
"WindVxi , WindVyi , WindVzi" - Longitudinal, lateral, and vertical wind speeds
"WaveElev"
"Wave1Vxi , Wave1Vyi , Wave1Vzi"
"Wave2Vxi , Wave2Vyi , Wave2Vzi"
"Wave3Vxi , Wave3Vyi , Wave3Vzi"
"Wave4Vxi , Wave4Vyi , Wave4Vzi"
"LSShftFxa,LSShftFys,LSShftFzs"
"GenPwr , GenTq" - Electrical generator power and torque
"Azimuth" - Blade 1 azimuth angle
"RotSpeed , GenSpeed" - Low-speed shaft and high-speed shaft speeds
"OoPDefl1 , IPDefl1 , TwstDefl1" - Blade 1 out-of-plane and in-plane deflections and tip twist
"BldPitch1" - Pitch angles for blade 1
"TTDspFA , TTDspSS , TTDspTwst" - Tower fore-aft and side-to-side displacements and top twist
"PtfmSurge, PtfmSway , PtfmHeave" - Platform translational surge, sway, and heave displacements
"PtfmTVxi , PtfmTVyi , PtfmTVzi" - Platform translational surge, sway, and heave velocity (m/s)
"PtfmRoll , PtfmPitch, PtfmYaw" - Platform rotational roll, pitch and yaw displacements
"PtfmRVxi , PtfmRVyi, PtfmRVzi"
"PtfmRAxi , PtfmRAyi , PtfmRAzi"
"RootFxc1 , RootFyc1 , RootFzc1" - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 1
"RootMxc1 , RootMyc1 , RootMzc1" - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 1
"RootMEdg1, RootMFlp1" - Edgewise and flapwise bending moments at the root of blade 1
"RotTorq , LSSGagMya, LSSGagMza" - Rotor torque and low-speed shaft 0- and 90-rotating bending moments at the main bearing
"YawBrFxp , YawBrFyp , YawBrFzp" - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
"YawBrMxp , YawBrMyp , YawBrMzp" - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
"TwrBsFxt , TwrBsFyt , TwrBsFzt" - Fore-aft shear, side-to-side shear, and vertical forces at the base of the tower (platform)
"TwrBsMxt , TwrBsMyt , TwrBsMzt" - Side-to-side bending, fore-aft bending, and yaw moments at the base of the tower (platform)
"RotFurlP , RotFurlP , RotFurlP" - Platform forces sensors 45-47
"RotFurlP , RotFurlP , RotFurlP" - Platform forces sensors 48-50
"Fair1Ten , Fair2Ten , Fair3Ten" - Lines 1-3 fairlead tensions
"Fair1Ang , Fair2Ang , Fair3Ang" - Lines 1-3 fairlead angles
"Anch1Ten , Anch2Ten , Anch3Ten" - Lines 1-3 anchor tensions
"Anch1Ang , Anch2Ang , Anch3Ang" - Lines 1-3 anchor angles
"TipDxb1 , TipDyb1"
"TwHt1TDxt"
"PtfmFxt , PtfmFyt , PtfmFxi , PtfmFyi"
"RotCt , RotCp , RotCq"
"Q_Sg,Q_Sw,Q_Hv,Q_R,Q_P,Q_Y,Q_TFA1,Q_TSS1,Q_TFA2,Q_TSS2,Q_Yaw,Q_GeAz,Q_DrTr"
"Q_B1F1,Q_B2F1,Q_B3F1,Q_B1E1,Q_B2E1,Q_B3E1,Q_B1F2,Q_B2F2,Q_B3F2"
"QD_Sg,QD_Sw,QD_Hv,QD_R,QD_P,QD_Y,QD_TFA1,QD_TSS1,QD_TFA2,QD_TSS2,QD_Yaw,QD_GeAz,QD_DrTr"
"QD_B1F1,QD_B2F1,QD_B3F1,QD_B1E1,QD_B2E1,QD_B3E1,QD_B1F2,QD_B2F2,QD_B3F2"
"QD2_R,QD2_P,QD2_DrTr,HSShftPwr"
"LSSTipPxa,LSSTipVxa,LSSTipAxa"
"LSSGagPxa,LSSGagVxa,LSSGagAxa"
"HSShftV,HSShftA"
"OoPDefl2 , IPDefl2 , TwstDefl2"
"OoPDefl3 , IPDefl3 , TwstDefl3"
"RotPwr, NacYaw"
"YawPzn"
END of FAST input file (the word "END" must appear in the first 3 columns of this last line).
Thank you in advance.
Best,
Boran
