thank you for your quick reply, I have disabled the generator DOF but the solution does not converge. Maybe I’ve done some mistakes in the input files.
This is the error message of FAST:
The solution does not appear to converge after 3600 seconds!
Try increasing the total run time, TMax, increasing system damping values,
or increasing the convergence tolerances, DispTol and/or VelTol.
The linearized system matrices were not formed.
Aborting FAST.
This is the input file that I’ve used, could you check if there are some mistakes?
Thank you so much. Regards,
Alessandro Giusti
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v6.0.
True Echo - Echo input data to “echo.out” (flag)
2 AnalMode - Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
3600.00 TMax - Total run time (s)
0.0125 DT - Integration time step (s)
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink} (switch)
0 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
0 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined from Simulink} (switch)
True GenTiS-tr - Method to start the generator {T: timed using TimGenOn, F: generator speed using SpdGenOn} (flag)
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
9999.9 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.9 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.9 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
0.0 BlPitch(1) - Blade 1 initial pitch (degrees)
0.0 BlPitch(2) - Blade 2 initial pitch (degrees)
0.0 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
0.0 B1PitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 B1PitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
True YawDOF - Yaw DOF (flag)
10.0 RotSpeed - Initial or fixed rotor speed (rpm)
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E3 NacMass - Nacelle mass (kg)
56.78E3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
100.0 GBoxEff - Gearbox efficiency (%)
97.0 GBRatio - Gearbox ratio (-)
28.1162E3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
2 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
“NRELOffshrBsline5MW_Platform_Monopile_RF.dat” PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
99 TwrNodes - Number of tower nodes used for analysis (-)
“NRELOffshrBsline5MW_Tower_Monopile_RF.dat” TwrFile - Name of file containing tower properties (quoted string)
9028.32E6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, CdArea (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, CdArea (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
“NRELOffshrBsline5MW_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
“NRELOffshrBsline5MW_AeroDyn.ipt” ADFile - Name of file containing AeroDyn input parameters (quoted string)
NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
“NRELOffshrBsline5MW_ADAMSSpecific.dat” ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string) [unused when ADAMSPrep=1]
“NRELOffshrBsline5MW_Linear.dat” LinFile - Name of file containing FAST linearization parameters (quoted string) [unused when AnalMode=1]
(omitted)
