Dear Forum Members,
First, I would like to thank the NREL team for their hard work in the development of these Software Tools.
Following, I will post the problem that I have with the linearisation.
I intend to linearise the NREL 5MW turbine model in region 3 of operation, in order to design control strategies. I set up the linearisation with all the changes as describe in NREL user manual pages 39-44.
For the liniarisation, I use a wind profile hitting the turbine from front with a wind velocity of 14 m/s.
The fst file for linearisation is as follows
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v7.02.
False Echo - Echo input data to "echo.out" (flag)
2 AnalMode - Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
999.0 TMax - Total run time (s)
0.0125 DT - Integration time step (s)
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink/Labview} (switch)
0 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink/Labview} (switch)
1 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined
9999.9E-9 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
43093.6 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m)
9999.9e-9 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2)
9999.9e-9 VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%)
1 GenModel - Generator model {1: simple, 2: Thevenin, 3: user-defined from routine UserGen} (switch) [used only when VSContrl=0]
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr, 3: user-defined from Labview} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
0.0 NacYawF - Final yaw angle for yaw maneuvers (degrees)
9999.9 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.9 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.9 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
8.70 BlPitch(1) - Blade 1 initial pitch (degrees)
8.70 BlPitch(2) - Blade 2 initial pitch (degrees)
8.70 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
8.70 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
8.70 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
8.70 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
False YawDOF - Yaw DOF (flag)
12.1 RotSpeed - Initial or fixed rotor speed (rpm)
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
1 PSpnElN - Number of the innermost blade element which is still part of the pitchable portion of the blade for partial-span pitch control
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E3 NacMass - Nacelle mass (kg)
56.78E3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
100.0 GBoxEff - Gearbox efficiency (%)
97.0 GBRatio - Gearbox ratio (-)
28.1162E3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
"Dummy" DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
0 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
"Dummy" PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
"NRELOffshrBsline5MW_Tower_Onshore.dat" TwrFile - Name of file containing tower properties (quoted string)
9028.32E6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
"Dummy" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, Cd*Area (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, Cd*Area (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
"NRELOffshrBsline5MW_Blade.dat" BldFile(1) - Name of file containing properties for blade 1 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile(2) - Name of file containing properties for blade 2 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
"NRELOffshrBsline5MW_AeroDyn.ipt" ADFile - Name of file containing AeroDyn input parameters (quoted string)
"Dummy" NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
"NRELOffshrBsline5MW_ADAMSSpecific.dat" ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string)
"NRELOffshrBsline5MW_Linear.dat" LinFile - Name of file containing FAST linearization parameters (quoted string)
True SumPrint - Print summary data to "<RootName>.fsm" (flag)
3 OutFileFmt - Format for tabular (time-marching) output file(s) (1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both)
True TabDelim - Use tab delimiters in text tabular output file? (flag)
"ES10.3E2" OutFmt - Format used for text tabular output (except time). Resulting field should be 10 characters. (quoted string)
0.0 TStart - Time to begin tabular output (s)
1 DecFact - Decimation factor for tabular output {1: output every time step} (-)
1.0 SttsTime - Amount of time between screen status messages (sec)
TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
5,9,13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
OutList - The next line(s) contains a list of output parameters. See OutList.txt for a listing of available output channels, (-)
"WindVxi" - Longitudinal, lateral, and vertical wind speeds
"GenPwr , GenTq" - Electrical generator power and torque
"BldPitch1" - Blade 1 pitch angle
"Azimuth" - Blade 1 azimuth angle
"RotSpeed , GenSpeed" - Low-speed shaft and high-speed shaft speeds
"OoPDefl1 , IPDefl1 , TwstDefl1" - Blade 1 out-of-plane and in-plane deflections and tip twist
"TTDspFA , TTDspSS , TTDspTwst" - Tower fore-aft and side-to-side displacments and top twist
END of FAST input file (the word "END" must appear in the first 3 columns of this last line).
Linearisation file .dat
---------------------- FAST LINEARIZATION CONTROL FILE -------------------------
NREL 5.0 MW offshore baseline linearization input properties.
---------------------- PERIODIC STEADY STATE SOLUTION --------------------------
True CalcStdy - Calculate periodic steady state condition {False: linearize about initial conditions} (flag)
3 TrimCase - Trim case {1: find nacelle yaw, 2: find generator torque, 3: find collective blade pitch} (switch)
0.0001 DispTol - Convergence tolerance for the 2-norm of displacements in the periodic steady state calculation (rad )
0.0001 VelTol - Convergence tolerance for the 2-norm of velocities in the periodic steady state calculation (rad/s)
---------------------- MODEL LINEARIZATION -------------------------------------
36 NAzimStep - Number of equally-spaced azimuth steps in periodic linearized model (-)
1 MdlOrder - Order of output linearized model {1: 1st order A, B, Bd, C, D, Dd; 2: 2nd order M, C, K, F, Fd, VelC, DspC, D, Dd} (switch)
---------------------- INPUTS AND DISTURBANCES ---------------------------------
2 NInputs - Number of control inputs [0 (none) or 1 to 4+NumBl] (-)
3,4 CntrlInpt - List of control inputs [1 to NInputs] { 3: generator torque, 4: collective blade pitch }
1 NDisturbs - Number of wind disturbances [0 (none) or 1 to 7] (-)
1 Disturbnc - List of input wind disturbances [1 to NDisturbs] {1: horizontal hub-height wind speed} (-)
The linearisation goes well, it finds steady state solution in 50 steps. The result is as follows:
This linearized model file was generated by FAST (v7.02.00d-bjj, 20-Feb-2013) on 05-Feb-2015 at 08:53:18.
The aerodynamic calculations were made by AeroDyn (v13.00.02a-bjj, 20-Feb-2013).
Some Useful Information:
Type of steady state solution found Trimmed collective blade pitch (TrimCase = 3)
Azimuth-average rotor speed, RotSpeed (rad/s) 1.26711E+00
Period of steady state solution (sec) 4.95868E+00
Iterations needed to find steady state solution 60
Displacement 2-norm of steady state solution (rad) 6.29953E-05
Velocity 2-norm of steady state solution (rad/s) 4.66512E-05
Number of equally-speced azimuth steps, NAzimStep 36
Order of linearized model, MdlOrder 1
Number of active (enabled) DOFs 12 (24 states)
Number of control inputs, NInputs 2
Number of input wind disturbances, NDisturbs 1
Number of output measurements 13
Order of States in Linearized State Matrices:
Row/column 1 = 1st tower fore-aft bending mode DOF (internal DOF index = DOF_TFA1)
Row/column 2 = 1st tower side-to-side bending mode DOF (internal DOF index = DOF_TSS1)
Row/column 3 = 2nd tower fore-aft bending mode DOF (internal DOF index = DOF_TFA2)
Row/column 4 = 2nd tower side-to-side bending mode DOF (internal DOF index = DOF_TSS2)
Row/column 5 = Variable speed generator DOF (internal DOF index = DOF_GeAz)
Row/column 6 = Drivetrain rotational-flexibility DOF (internal DOF index = DOF_DrTr)
Row/column 7 = 1st flapwise bending-mode DOF of blade 1 (internal DOF index = DOF_BF(1,1))
Row/column 8 = 1st flapwise bending-mode DOF of blade 2 (internal DOF index = DOF_BF(2,1))
Row/column 9 = 1st flapwise bending-mode DOF of blade 3 (internal DOF index = DOF_BF(3,1))
Row/column 10 = 1st edgewise bending-mode DOF of blade 1 (internal DOF index = DOF_BE(1,1))
Row/column 11 = 1st edgewise bending-mode DOF of blade 2 (internal DOF index = DOF_BE(2,1))
Row/column 12 = 1st edgewise bending-mode DOF of blade 3 (internal DOF index = DOF_BE(3,1))
Row/column 13 to 24 = First derivatives of row/column 1 to 12.
Order of Control Inputs in Linearized State Matrices:
Column 1 = electrical generator torque (N·m) 4.30936E+04 op
Column 2 = rotor collective blade pitch (rad) 1.51366E-01 op
Order of Input Wind Disturbances in Linearized State Matrices:
Column 1 = horizontal hub-height wind speed (m/s) : See selected wind file for op
Order of Output Measurements in Linearized State Matrices:
Row 1 = WindVxi (m/s)
Row 2 = GenPwr (kW)
Row 3 = GenTq (kN·m)
Row 4 = BldPitch1 (deg)
Row 5 = Azimuth (deg)
Row 6 = RotSpeed (rpm)
Row 7 = GenSpeed (rpm)
Row 8 = OoPDefl1 (m)
Row 9 = IPDefl1 (m)
Row 10 = TwstDefl1 (deg)
Row 11 = TTDspFA (m)
Row 12 = TTDspSS (m)
Row 13 = TTDspTwst (deg)
In order to compare the results to the nonlinear model I have a second wind profile in which I set a step in the velocity from 14 m/s to 15m/s.
In Matlab, I simulate the averaged state space matrixes for the linearised model. In order to compare the results I use a wind step of one (corresponding to the 14m/s to 15m/s in the nonlinear case).
And I get the following result
[attachment=0]results_nonln_vs_lin.jpg[/attachment]
In the figures, with black is represented nonlinear model output, and with blue the liniarised model output . Moreover, in the case of the liniarised model, the GenPwr and RotSpeed decrease, instead of getting to the same steady state as in the case of the nonlinear model. This effect is present when I set the FLAPDOF1 and EDGEDOF to be TRUE.
I cannot make any sense of this behavior, and I have tried several things, but ran out of ideas.
I hope that you can help me with a suggestion, on why is it happening, as maybe I am doing something wrong in the linearisation setup, or when I compare the nonlinear model to the liniarised model.
Thank you in advance!
