Hello everyone,
I am a PhD. student in Spain, and I am starting to work with FAST. I am trying to make a linearization analysis and after setting the primary.fst and NRELOffshrBsline5MW_Linear.dat files, according to the indications of FAST User’s Guide pages 56-61, using a constant wind Hub-Height Wind Data File of 10 m/s wind speed.
The following error appears when executing FAST in Linearization Mode.
"C:\FDI FTC Benchmark FAST\FAST code>FAST primary.fst
Running NWTC Subroutine Library (v1.07.00b-mlb, 10-Jan-2013).
Running FAST (v7.02.00d-bjj, 20-Feb-2013).
Heading of the FAST input file: NREL 5.0 MW Baseline Wind Turbine for Use in Offshore Analysis.
Invalid numeric input. “True” found when trying to read the number, OutFileFmt.
Aborting FAST."
I don’t find information about this error or the parameter involved with it. OutFileFMT is the same as OutFMT in the .fst file?. In that case I don’t have a “True” value assigned to this parameter.
I would appreciate any suggestion.
Hector Sanchez
PhD. Student
Universitat Politècnica de Catalunya
Terrassa, Spain
