Hi, Peter.
Given your other two posts over the weekend, I assume you managed to figure out the problem. However, the error means that FAST couldn’t find the DISCON_ITI_Barge_win32.dll file. So it (1) doesn’t exist, (2) is spelled incorrectly, (3) has an incorrect path specifying where it’s located, (4) is compiled for the wrong architecture, or (5) is corrupted.
All the files in for CertTest 24 should be set up properly, and as far as I know, all the files are there. If you moved files around, you may have to modify the text in input files where other input files (and the Bladed DLL) are specified. All input files (and Bladed DLL) locations should be specified relative to the file they are listed in (e.g., the Bladed DLL is specified inside the ServoDyn input file, so the location of the Bladed DLL is specified relative to the location of the ServoDyn input file).
If you haven’t moved files around, it should work as is.
