Dear sir
I have a question about how to compile FAST_RT_DLL.dll.
I meet an error: “LINK: fatal error LNK1104: cannot open file ‘LIBC.lib’.”
Could you tell me how to resolve it?
[code]@ECHO OFF
REM The calling syntax for this script is
REM Compile_FASTforLabview
REM
REM ----------------------------------------------------------------------------
REM set compiler internal variables
REM You can run this bat file from the IVF compiler’s command prompt (and not
REM do anything in this section). If you choose not to run from the IVF command
REM prompt, you must call the compiler’s script to set internal variables.
REM TIP: Right click on the IVF Compiler’s Command Prompt shortcut, click
REM properties, and copy the target (without cmd.exe and/or its switches) here:
REM: PLEASE NOTE: newer versions of the IVF compiler are not yet supported.
IF “%INTEL_SHARED%”=="" CALL “C:\Program Files (x86)\Intel\Compiler\11.1\038\bin\ifortvars.bat” ia32 vs2008
REM -------------------- LOCAL VARIABLES ---------------------------------------
SET ROOT_NAME=…\FAST_RT_DLL
REM bjj: DO NOT USE /threads. It causes a memory leak when the DLL runs in LabVIEW.
SET CompOpts= /O2 /inline:speed /Qzero /Qsave /real_size:32 /assume:byterecl /libs:static /nothreads /vms /check:none /NODEFAULTLIB:libc
rem /nologo /Qopenmp_report:0 /Qpar_report:0 /Qvec_report:0 /warn:none /libdir:nouser /c
rem SET LINKOPTS=/link /stack:64000000
SET LinkOpts=/DELAYLOAD:“imagehlp.dll” /DLL delayimp.lib
rem /INCREMENTAL /NOLOGO /ASSEMBLYDEBUG:DISABLE /OPT:NOREF
REM ------------------------- LOCAL PATHS --------------------------------------
REM – USERS WILL NEED TO EDIT THESE PATHS TO POINT TO FOLDERS ON THEIR LOCAL –
REM – MACHINES. NOTE: do not use quotation marks around the path names!!! —
REM NWTC_Lib_Loc is the location of the NWTC subroutine library files
REM AeroDyn_Loc is the location of the AeroDyn source files
REM Wind_Loc is the location of the AeroDyn wind inflow source files
REM FAST_LOC is the location of the FAST source files
rem SET NWTC_Lib_Loc=C:\Users\bjonkman\Data\DesignCodes\NWTC Library\source
rem SET AeroDyn_Loc=C:\Users\bjonkman\Data\DesignCodes\AeroDyn\Source
rem SET Wind_Loc=C:\Users\bjonkman\Data\DesignCodes\AeroDyn\Source\InflowWind\Source
rem SET FAST_Loc=C:\Users\bjonkman\Data\DesignCodes\FAST\Source
SET NWTC_Lib_Loc=C:\Users\jason2\Desktop\FAST_LAVIEW compile\Source_NWTC_Lib2
SET AeroDyn_Loc=C:\Users\jason2\Desktop\FAST_LAVIEW compile\Source_AeroDyn2
SET Wind_Loc=C:\Users\jason2\Desktop\FAST_LAVIEW compile\Source_InflowWind2
SET FAST_Loc=C:\Users\jason2\Desktop\FAST_LAVIEW compile\Source_FAST2
SET Labview_Loc=C:\Users\jason2\Desktop\FAST_LAVIEW compile\Source_Labview_Lib2
SET NWTC_Files=
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\SingPrec.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\SysIVF_Labview.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_IO.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_Num.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_Aero.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\ModMesh.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_Library.f90”
SET Wind_Files=
SET Wind_Files=%Wind_Files% “%Wind_Loc%\SharedInflowDefs.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\HHWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\FFWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\HAWCWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\FDWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\CTWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\UserWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\InflowWindMod.f90”
SET AeroDyn_Files=
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\SharedTypes.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\AeroMods.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\GenSubs.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\AeroSubs.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\AeroDyn.f90”
SET FAST_Files=
SET FAST_Files=%FAST_Files% “%FAST_LOC%\fftpack.f”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FFTMod.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\HydroCalc.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_Mods.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\Noise.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_IO.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_Lin.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST2ADAMS.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\PitchCntrl_ACH.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\UserSubs.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\UserVSCont_KP.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\AeroCalc.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\SetVersion.f90”
SET FAST_Files=%FAST_Files% “%Labview_Loc%\FAST_RT_DLL.f90”
:ivf
REM ---------------- COMPILE WITH INTEL VISUAL FORTRAN -------------------------
REM compile
ECHO.
ECHO Compiling FAST, AeroDyn, InflowWind, and NWTC_Library routines to create %ROOT_NAME%.dll:
ifort /dll %CompOpts% /exe:%ROOT_NAME%.dll %NWTC_Files% %Wind_Files% %AeroDyn_Files% %FAST_Files% /link %LinkOpts%
:end
REM ------------------------- CLEAR MEMORY -------------------------------------
REM ------------- and delete all .mod and .obj files ---------------------------
ECHO a
DEL *.mod
DEL *.obj
SET ROOT_NAME=
SET NWTC_Files=
SET Wind_Files=
SET AeroDyn_Files=
SET FAST_Files=
SET A2AD_Files=
SET Fixed_Files=
SET NWTC_Lib_Loc=
SET Wind_Loc=
SET AeroDyn_Loc=
SET A2AD_Loc=
SET FAST_Loc=
SET Labview_Loc=
SET COMPOPTS=
SET LINKOPTS=
[/code]
Thanks for your help.
Jason. Lai
