Hi Jason:
I am seeking clarification on the following that is used to compute the turbulence intensity in IEC:61400:1-2019, which is subsequently used in TurbSim.
For NTM it states that:
sigma 1 = IRef(0.75Vhub+b); where b = 5.6 m/s.
Wind turbine classes are given as A+ to C and for example class A, IRef=0.16, so using equation above sigma1 can be determined and the TI found by:
sigma1/Vhub. 1) Is this understanding correct?
Also, it defines the category as A+ for very high turbulence and C for very low.
2) Is there a turbulence criteria that causes one to know whether they are in the high or low category?
I arbitrarily chose B for two site locations I am investigating to arrive at a different TI for each site but have no basis for why I chose B.
Finally I read some notes that said that TI = standard deviation of wind speed/mean wind speed (mean wind speed at hub height in this case).
3)If I have the wind time series can I find, standard deviation/Vhub, and use the percentage obtained as the TI at each site location in TurbSim instead of using formula above? I am essentially trying to determine an appropriate value for TI for both sites given the data that I have.
4) Also, if TI is entered as percentage in TurbSim for 10% do I just enter 10 instead of A, for example?
Thank you.
AOAW
