Dear Jason
i got this error before changing uref . I havent run turbSim successfully
should i change the location of turbsim?
this is the last input file i used
thank you
TurbSim Input File. Valid for TurbSim v1.50, 25-Sep-2009
2318573 RandSeed1 - First random seed (-2147483648 to 2147483647)
RANLUX RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False WrADFF - Output full-field time-series data in TurbSim/AeroDyn form? (Generates Rootname.bts)
True WrBLFF - Output full-field time-series data in BLADED/AeroDyn form? (Generates RootName.wnd)
True WrACT - Output coherent turbulence time steps in AeroDyn form? (Generates RootName.cts)
13 NumGrid_Z - Vertical grid-point matrix dimension
13 NumGrid_Y - Horizontal grid-point matrix dimension
600 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
40 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds)
84.2876 HubHt - Hub height [m] (should be > 0.5GridHeight)
80.00 GridHeight - Grid height [m]
80.00 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
“SMOOTH” TurbModel - Turbulence model (“IECKAI”=Kaimal, “IECVKM”=von Karman, “GP_LLJ”, “NWTCUP”, “SMOOTH”, “WF_UPW”, “WF_07D”, “WF_14D”, or “NONE”)
“1-ED3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“A” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP model, not used for other models)
default ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
default WindProfileType - Wind profile type (“JET”,“LOG”=logarithmic,“PL”=power law,“IEC”=PL on rotor disk,LOG elsewhere, or “default”)
84.2876 RefHt - Height of the reference wind speed [m]
24 URef - Mean (total) wind speed at the reference height [m/s] (or “default” for JET wind profile)
default PC_UW - Hub mean u’w’ Reynolds stress (or “default”)
default PC_UV - Hub mean u’v’ Reynolds stress (or “default”)
default PC_VW - Hub mean v’w’ Reynolds stress (or “default”)
default IncDec1 - u-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec2 - v-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec3 - w-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default CohExp - Coherence exponent (or “default”)
“M:\coh_events\eventdata” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1.0 DistScl - Disturbance scale (ratio of wave height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. (Ignored when Randomize = true.)
30.0 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
NOTE: Do not add or remove any lines in this file!
