I’ve tried a new approach to run FAST Simulink models.
Instead of running Run_OpenLoop.m (OpenLoop.mdl) I tried to run Energies.mdl, which I’m sending a picture below:
[url]https://drive.google.com/file/d/1jchpIiEzmUG2-qsOmGkuu-xr91SBnbTq/view[/url]
Although I run this model for Test18.fst and it was working fine for Run_OpenLoop.m (OpenLoop.mdl) , when I tried to run on Energies.mdl it resulted some errors. Please, can you help to identify and fix these erros?
[code]>> RunEnergies
FAST_SFunc certification test for Test18
Error using RunEnergies (line 19)
Error due to multiple causes.
Caused by:
Invalid setting in ‘Energies/FAST Nonlinear Wind Turbine/Demux’ for
parameter ‘Outputs’.
Error evaluating parameter ‘Outputs’ in ‘Energies/FAST Nonlinear
Wind Turbine/Demux’
Undefined function or variable ‘NDOF’.
Error in S-function ‘Energies/Soft Real Time’: S-Function ‘sfun_time’
does not exist[/code]
Best wishes,
Jonathan
Dear Jonathan,
I’m not familiar with RunEnergies.mdl; this doesn’t appear to be a model provided by NREL. Regardless, from the error message, it appears that you must set the NDOF variable before running the RunEnergies.mdl.
Thank you for the fast reply Professor Jonkman,
RunEnergies,mdl it’s not a model provided by NREL. It was created to simulate some turbine controls, as these ones:
[code]if px==1
% Optimal control
Num = 2*r{i}*(u - 2.14*omega_g^2)*(-2*2.14*omega_g) ...
+2*q{i}*(Pref - u*omega_g)*(-u);
DerivCp=geraDerivadaCp(Cp,wind,Pitch,omega_g);
Parte1=r{i}*(u - 2.14*omega_g^2)^2;
Parte2=q{i}*(Pref - u*omega_g)^2;
Au2=b2*q{i}*omega_g/DerivCp;
Bu2= -2*b2*r{i}*2.14*omega_g/DerivCp - b2*q{i}*Pref/DerivCp + r{i} + q{i}*omega_g^2;
Cu2= -( -2*b2*r{i}*2.14^2*omega_g^3/DerivCp + r{i}*2.14*omega_g^2 + q{i}*Pref*omega_g );
raizes = roots([Au2 Bu2 Cu2]);
raizMin = min(raizes);
raizMax = max(raizes);
if raizMin>0
ut3=raizMin;
else
ut3=raizMax;
end
u=ut3;
flag=['markov'];
if u<0
disp('socorro. u negativo')
end
flag = ['markov'];
end
if px==2
% Jockerman interpretado Yolanda
if (leer<1129)
u = 2.14*omega_g^2;
elseif (leer>1165)
u = Pref/omega_g;
else
alpha = -leer/36 + 1165/36;
u = alpha*2.14*omega_g^2 + (1-alpha)*Pref/omega_g;
end
flag=['jocker'];
end
if px==3
% Regra chaveado Chino
if (wind<11.4)
u = 2.14*omega_g^2;
else
u = Pref/omega_g;
end
flag=['chino'];
end[/code]
Despite I have set NDOF variable, another variables needed to be set, and when I set all of them the script run out in another error. I think that’s not a way I can test these controls. Is there any model provided by NREL that I could test these controls?
With gratitude,
Jonathan
Dear Jonathan,
I’m not sure what you mean when you say, “is there any model provided by NREL that I could test these controls?” What controls do you want to test?
