I’ve downloaded the new version of FAST, namely FAST 8.10. I want to use the Simulink Interface, so I read this article https://wind.nrel.gov/nwtc/docs/README_FAST8.pdf. I could run the test cases 1-17, but I couldn’t run 18-25. The error is written below:
Error reported by S-function ‘FAST_SFunc’ in ‘OpenLoop/FAST Nonlinear Wind
Turbine/S-Function’:
FAST_InitializeAll:SrvD_Init:Yaw angle and rate are not commanded from Simulink model.
Pitch angles are not commanded from Simulink model.
Generator torque and power are not commanded from Simulink model.
HSS brake is not commanded from Simulink model.
SrvD_Init:BladedInterface_Init:The dynamic library
…\CertTest\5MW_Baseline/ServoData\DISCON_win32.dll could not be loaded. Check that
the file exists in the specified location and that it is compiled for 64-bit systems.
Besides, the project which I’m going to involve is more like test cases number 18-25, so I need to run these cases.
Please kindly let me know what the problem is.
