I found some particularity linearizing the 5 MW reference on-shore wind turbine (FAST v7). The A matrix of the state space model obtained after linearization at different wind speeds in region 3 (making a pitch trim) differs if the torque characteristic is used as explained in the FAST manual (making VSContrl=1, VS_RtGnSp=1E-9, VS_RtTq=Tn, VS_Rgn2=1E-9, VS_SlPc=1E-9) or leaving as a “standard curve” (i.e. VSContrl=1, VS_RtGnSp= 1173.7, VS_RtTq=Tn, VS_Rgn2= 0.0255764, VS_SlPc=10). The linearization points result the same (torque, rotational speed, pitch angle, etc), but the difference appears to be in two coefficients corresponding to the First derivatives of Variable speed generator DOF (internal DOF index = DOF_GeAz)and Drivetrain rotational-flexibility DOF (internal DOF index = DOF_DrTr) with respect to the state Variable speed generator DOF (internal DOF index = DOF_GeAz (rows 7 and 8, and column 7 in the pictures below).
For example:
---------------------- FEATURE FLAGS ------------------------------
False TeetDOF - Rotor-teeter DOF (flag) [unused for 3
True DrTrDOF - Drivetrain rotational-flexibility DOF
False YawDOF - Yaw DOF (flag)
False TwFADOF2 - Second fore-aft tower bending-mode DOF
True TwSSDOF1 - First side-to-side tower bending-mode DOF
False TwSSDOF2 - Second side-to-side tower bending-mode DOF
Linearization point:
Wind speed= 23.568 m/s,
Gen speed= 1173.7 rpm,
Pitch angle= 21.497 °,
Torque= 44205
For “standard curve” values
For Fast manual values
The difference is for 1: Run FAST and for 3: do both.
Therefore, my question is: do you know what could be the reason and which one is correct?
Bernabé Ibáñez
