Hi all,
First of all I would like to thank you for such a great and well documented project on Wind Turbine simulation.
I was doing a bit of research on Wind Turbine dynamics and control. Unfortunately, I´m not an expert on control issues, so apologize in advance for the obvious questions on that field.
Taking the model NRELOffshrBsline5MW_Onshore, I have performed a linearization at several operating points in region 3 (above rated Wind Speed).
A standard header of one of my linearized solutions:
Order of States in Linearized State Matrices:
Row/column 1 = 1st tower fore-aft bending mode DOF (internal DOF index = DOF_TFA1)
Row/column 2 = 1st tower side-to-side bending mode DOF (internal DOF index = DOF_TSS1)
Row/column 3 = Variable speed generator DOF (internal DOF index = DOF_GeAz)
Row/column 4 = Drivetrain rotational-flexibility DOF (internal DOF index = DOF_DrTr)
Row/column 5 = 1st flapwise bending-mode DOF of blade 1 (internal DOF index = DOF_BF(1,1))
Row/column 6 = 1st flapwise bending-mode DOF of blade 2 (internal DOF index = DOF_BF(2,1))
Row/column 7 = 1st flapwise bending-mode DOF of blade 3 (internal DOF index = DOF_BF(3,1))
Row/column 8 = 1st edgewise bending-mode DOF of blade 1 (internal DOF index = DOF_BE(1,1))
Row/column 9 = 1st edgewise bending-mode DOF of blade 2 (internal DOF index = DOF_BE(2,1))
Row/column 10 = 1st edgewise bending-mode DOF of blade 3 (internal DOF index = DOF_BE(3,1))
Order of Control Inputs in Linearized State Matrices:
Column 1 = electrical generator torque (N·m) 4.30930E+04 op
Column 2 = rotor collective blade pitch (rad) 1.98206E-01 op
Column 3 = individual pitch of blade 1 (rad) 1.98206E-01 op
Column 4 = individual pitch of blade 2 (rad) 1.98206E-01 op
Column 5 = individual pitch of blade 3 (rad) 1.98206E-01 op
Order of Input Wind Disturbances in Linearized State Matrices:
Column 1 = horizontal hub-height wind speed (m/s) 1.60000E+01 op
Column 2 = horizontal wind direction (rad) 0.00000E+00 op
Column 3 = vertical wind speed (m/s) 3.47900E+00 op
Column 4 = horizontal shear parameter (-) 0.00000E+00 op
Column 5 = vertical power law shear exponent (-) 2.00000E-01 op
Column 6 = linear vertical shear parameter (-) 0.00000E+00 op
Column 7 = horizontal hub-height wind gust (m/s) 0.00000E+00 op
Order of Output Measurements in Linearized State Matrices:
Row 1 = GenSpeed (rpm)
Row 2 = GenTq (kN·m)
Row 3 = GenPwr (kW)
Row 4 = RotSpeed (rpm)
Row 5 = RotThrust (kN)
Row 6 = RotTorq (kN·m)
Row 7 = RotPwr (kW)
Row 8 = RootFxc1 (kN)
Row 9 = RootFxc2 (kN)
Row 10 = RootFxc3 (kN)
Row 11 = RootFyc1 (kN)
Row 12 = RootFyc2 (kN)
Row 13 = RootFyc3 (kN)
Row 14 = RootFzc1 (kN)
Row 15 = RootFzc2 (kN)
Row 16 = RootFzc3 (kN)
Row 17 = RootMxc1 (kN·m)
Row 18 = RootMxc2 (kN·m)
Row 19 = RootMxc3 (kN·m)
Row 20 = RootMyc1 (kN·m)
Row 21 = RootMyc2 (kN·m)
Row 22 = RootMyc3 (kN·m)
Row 23 = RootMzc1 (kN·m)
Row 24 = RootMzc2 (kN·m)
Row 25 = RootMzc3 (kN·m)
Row 26 = TipDxc1 (m)
Row 27 = TipDxc2 (m)
Row 28 = TipDxc3 (m)
Row 29 = TipDyc1 (m)
Row 30 = TipDyc2 (m)
Row 31 = TipDyc3 (m)
Row 32 = TipDzc1 (m)
Row 33 = TipDzc2 (m)
Row 34 = TipDzc3 (m)
Row 35 = TwrBsFxt (kN)
Row 36 = TwrBsFyt (kN)
Row 37 = TwrBsFzt (kN)
Row 38 = TwrBsMxt (kN·m)
Row 39 = TwrBsMyt (kN·m)
Row 40 = TwrBsMzt (kN·m)
Row 41 = TTDspFA (m)
Row 42 = TTDspSS (m)
Row 43 = TTDspAx (m)
Row 44 = BlPitch1 (deg)
Row 45 = BlPitch2 (deg)
Row 46 = BlPitch3 (deg)
Row 47 = HorWindV (m/sec)
Row 48 = HorWndDir (deg)
Row 49 = TSR (-)
In order to compare the performance of the linearized model with the nonlinear model, I prepared three basic simulations:
1.- Extreme Operating Wind Gust (max 8 m/s) in Closed Loop Condition.
2.- 2 Deg Pitch Increment in Open Loop Condition.
3.- 4 m/s Wind Speed Increment in Closed Loop Condition.
For the linearized model, I reproduce (as far as I can) the pitch control documented in:
Technical Report NREL/TP-500-38060: Definition of a 5-MW Reference Wind Turbine for Offshore System Development (great document, by the way).
In order to simplify the Variable Speed Control definition, I took the standard VS_CONT model with constant torque in region 3.
My first attempt was to use eigenanalysis.m routine and average out the linearized models obtained for different azimuts,
but then I found the so-clever MBC approach:
User’s Guide to MBC3 (Multi-blade Coordinate Transformation Utility for 3-Bladed Wind Turbines).
So, comparing the results of the FAST simultations with the MBC-Linearized model, following questions arise:
1.- Extreme Operating Wind Gust in Closed Loop Condition.
The linearized model exhibits a good agreement with FAST simulation, but I wonder if is there any way to reproduce the 1p-cyclic effects in the linearized model.
I realize that the cyclic effects are filtered out when performing the linearization, but maybe there exist an alternative way to deal with this effects. Otherwise,
I understand I could simulate the whole nonlinear model of the Wind Turbine in the Simulink environment with the aid of FAST_SFunc.mexw32.
It would be maravillous if one could develop individual pitch control strategies with the aid of the linearized models. Any Ideas?
I have a problem with the linearized model. My thougth is that the problem is related with the evolution of the state variables.
What I expected to obtain was a steady condition in an operating point with a different rotational speed, but the offset error in the DOF_GeAz derivative causes non stationary terms in some output variables.
Mainly those which has a 1p periodic behaviour.
I try to work arround this problem, but no way to do that. I think it could maybe have to do with the procedure used to obtain the averaged matrices, which in this case is a simple average of all the matrices, let say A, B, Bd, C, D and Dd MBC transformed matrices.
From control point of view, this behaviour is related to the presence of integral terms, but I would need more understanding on the problem to filter out this non-desired terms.
This graph represents the evolution of RootFxc1 in this loadcase. As mentioned, it would be nice to obtain a steady value in this output.
In this case, the pitch controller command an increment of the collaborative pitch in order to recover the rated speed (also the rated power).
What I would spect in this case is a steady condition in all the outputs, but I don´t.
If we take a look at a variable as the Rotor Thrust, it´s OK.
If we analyze the evolution of RootFxc1, what we see is that a periodic behaviour arises.
For this variable, the FAST model propose a steady situation with lower mean and higher amplitude so what I would spect for my LTI model was a constant steady value, beter than a periodic one.
On the other hand, it would be nice if the LTI model would be able to reproduce this kind of effects. I suppose this is a kind of MBC transformation of the offset error in one of the state variables.
Any idea about this topic?
Thank you in advance.
Kind Regards,
Javier.
