I am trying to verify the linearization results of FAST v8, considering 2 DOF (generator DOF and shaft DOF) for the NREL 5MW turbine. According to the internal DOF variables defined in FAST, I write the system linear model and compare with the results given by FAST. Some entities in the system matrix do not match (highlighted in red). The results are attached. For example, dTt/dwr should be zero, which is the derivative of aerodynamic torque with respect to generator speed, and also the last two entities in the last row of A matrix. I would really appreciate if you can let me know where is wrong.
Xiao
Hi Jason,
Thanks a lot for your reply.
It is just the two-mass shaft model that I rewrite in terms of the state variables defined in FAST ( DOF_GeAz is the generator angle and DOF_DrTr is the twist angle at the LSS side). I consider only the 2 DOFs for the beginning, and simulate under a steady wind speed condition. In this model, the aerodynamic torque can be linearized as Tt=Tt0+dTt/dwt*(delta_wt)+dTt/dV*(delta_Vwind), so I think (3,3) should be zero from Jg*dwr/dt=Tsh-Te, which should only involve theat_tw and w_tw due to Tsh (shaft torque). I attach a figure on how the system model is obtained.
I did not apply MBC since the states related to blades are not included. I guess the issues might be that all the inputs are included in the linearization process. Should I choose the inputs like in FAST V7?
Xiao
Hi Jason,
Finally, I get what is the problem by reading FAST 7 manual again. I ignore to set the variable-speed control by giving small values for slip, torque constant and rated speed. Now the results match the theoretical derivation.
Thanks a lot for your help!
Xiao
