Hello, everyone
This is the first time I am posting in this forum. I am a Masters student from India and I am a beginner in FAST. So I have been trying to model a DeepCWind with point absorbers configuration around the DeepCWind. While running fast, I encountered this error. Please help me out.
[b]Running FAST (v8.15.00a-bjj, 12-Apr-2016), compiled as a 32-bit application using single
precision
linked with NWTC Subroutine Library (v2.08.00, 5-Apr-2016)
Heading of the FAST input file:
FAST Certification Test #24: NREL 5.0 MW Baseline Wind Turbine with OC3 Hywind Configuration,
for use in offshore analysis
Running ElastoDyn (v1.03.02a-bjj, 8-Apr-2016).
Running AeroDyn (v15.02.03, 12-Apr-2016).
Running AirfoilInfo (v1.01.00a-bjj, 5-Apr-2016).
Running BEM (v1.01.00a, 12-Apr-2016).
Running InflowWind (v3.02.00a-bjj, 11-Apr-2016).
Opening InflowWind input file: .\5MW_Baseline/NRELOffshrBsline5MW_InflowWind.dat
Reading a 20x20 grid (145 m wide, 17.5 m to 162.5 m above ground) with a characteristic wind
speed of 12 m/s. This full-field file was generated by TurbSim (v1.50, 25-Sep-2009) on
01-Jun-2017 at 19:14:57.
Processed 72242 time steps of 20-Hz full-field data (3612.1 seconds).
Running ServoDyn (v1.05.00a-bjj, 11-Mar-2016).
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows,
14-Oct-2015).
Running HydroDyn (v2.05.00, 15-Mar-2016).
Reading in WAMIT output with root name “.\5MW_Baseline/HydroData/dcw_pa_528”.
Running MoorDyn (v1.01.02F, 8-Apr-2016).
Creating mooring system. 3 fairleads, 3 anchors, 0 connects.
Finalizing ICs using dynamic relaxation.
t=16.003 FairTen 1: 9.96023E+05, 1.00412E+06, 1.00178E+06
Fairlead tensions converged to 1% after 16.003 seconds.
Timestep: 0 of 3600 seconds.
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies. Includes modifications for the
Hywind spar.
Timestep: 41 of 3600 seconds. Estimated final completion at 07:26:55.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:InflowWind_CalcOutput:CalcOutput:IfW_TSF
FWind_CalcOutput [position=(6.7564, -80.164, 87.43) in wind-file coordinates]: FF wind array
boundaries violated: Grid too small in Y direction. Y=-80.164; Y boundaries = [-72.5, 72.5]
FAST encountered an error at simulation time 41.113 of 3600 seconds.
Aborting FAST.
[/b]
I have tried changing the grid dimensions in the Turbsim File, but every time I increase the grid dimensions, the position in the wind file coordinates becomes even larger resulting in the FF wind array boundaries violation. And also I face a new error which is:
ED_HD_InputOutputSolve: HydroDyn_CalcOutput: Angles in GetSmllRotAngs() are larger than 0.4 radians
Aborting FAST.
How do I solve this?
Reeti
M.Tech
