I built my model for an onshore turbine, checking my results with FAST’s OutData. Now I’m moving on to the offshore case, and I’m starting to analyze the aerodynamic differences compared to the onshore case.
Observing the simulations carried out with FAST, I noticed two things that I cannot explain:
- ‘RotThrust’, which in the onshore case was equal to ‘TwrBsFxt’, in the offshore case it is greater than ‘RotThrust’. I can’t understand what other contribution is involved in the offshore case (below is the input file where I set the simulation, starting from test 24)
AeroDyn:
------- AERODYN v15.03.* INPUT FILE ------------------------------------------------
False Echo - Echo the input to "<rootname>.AD.ech"? (flag)
"default" DTAero - Time interval for aerodynamic calculations {or "default"} (s)
1 WakeMod - Type of wake/induction model (switch) {0=none, 1=BEMT}
1 AFAeroMod - Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model}
0 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
False TwrShadow – Calculate tower influence on wind based on downstream tower shadow? (flag)
False TwrAero - Calculate tower aerodynamic loads? (flag)
1.2 AirDens - Air density (kg/m^3)
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [used only when WakeMod=1]
False TanInd - Include tangential induction in BEMT calculations? (flag) [used only when WakeMod=1]
False AIDrag - Include the drag term in the axial-induction calculation? (flag) [used only when WakeMod=1]
False TIDrag - Include the drag term in the tangential-induction calculation? (flag) [used only when WakeMod=1 and TanInd=TRUE]
"Default" IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or "default"} (-) [used only when WakeMod=1]
100 MaxIter - Maximum number of iteration steps (-) [used only when WakeMod=1]
3 UAMod - Unsteady Aero Model Switch (switch) {1=Baseline model (Original), 2=Gonzalez’s variant (changes in Cn,Cc,Cm), 3=Minemma/Pierce variant (changes in Cc and Cm)} [used only when AFAeroMod=2]
True FLookup - Flag to indicate whether a lookup for f' will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
"Airfoils/Cylinder1.dat" AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
"Airfoils/Cylinder2.dat"
"Airfoils/DU40_A17.dat"
"Airfoils/DU35_A17.dat"
"Airfoils/DU30_A17.dat"
"Airfoils/DU25_A17.dat"
"Airfoils/DU21_A17.dat"
"Airfoils/NACA64_A17.dat"
"NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
"NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
"NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
====== Tower Influence and Aerodynamics ============================================================= [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
11 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
TwrElev TwrDiam TwrCd
(m) (m) (-)
1.0000000E+01 6.5000000E+00 1.0000000E+00
1.7760000E+01 6.2400000E+00 1.0000000E+00
2.5520000E+01 5.9700000E+00 1.0000000E+00
3.3280000E+01 5.7100000E+00 1.0000000E+00
4.1040000E+01 5.4500000E+00 1.0000000E+00
4.8800000E+01 5.1800000E+00 1.0000000E+00
5.6560000E+01 4.9200000E+00 1.0000000E+00
6.4320000E+01 4.6600000E+00 1.0000000E+00
7.2080000E+01 4.4000000E+00 1.0000000E+00
7.9840000E+01 4.1300000E+00 1.0000000E+00
8.7600000E+01 3.8700000E+00 1.0000000E+00
ElastoDyn:
False Echo - Echo input data to "<RootName>.ech" (flag)
"default" DT - Integration time step (s)
False YawDOF - Yaw DOF (flag)
8.1344 RotSpeed - Initial or fixed rotor speed (rpm)
63 TipRad - The distance from the rotor apex to the blade tip (meters)
0 PreCone(1) - Blade 1 cone angle (degrees)
0 PreCone(2) - Blade 2 cone angle (degrees)
0 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
0 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
0 ShftTilt - Rotor shaft tilt angle (degrees)
0 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
0 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
2 Twr2Shft - Vertical distance from the tower-top to the rotor shaft (meters)
10 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-89.9155 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
-0 PtfmRefzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
7.46633E+06 PtfmMass - Platform mass (kg)
4.22923E+09 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
4.22923E+09 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
1.6423E+08 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
17 BldNodes - Number of blade nodes (per blade) used for analysis (-)
"NRELOffshrBsline5MW_Blade.dat" BldFile(1) - Name of file containing properties for blade 1 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile(2) - Name of file containing properties for blade 2 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
97 GBRatio - Gearbox ratio (-)
"unused" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
"NRELOffshrBsline5MW_OC3Hywind_ElastoDyn_Tower.dat" TwrFile - Name of file containing tower properties (quoted string)
- Since the wind has a spatial and temporal arrangement, I used Turbsim to create a wind file for use in my model. Turbsim creates a 2D wind grid in y and z direction, however from some tests I have noticed that ‘RotThrust’ also depends on x, and therefore somehow FAST takes into account how the wind changes as x changes (despite the Turbsim grid is only in the y and z direction). How can I also take into account the variation of the wind even in position x?
[I noticed the difference because setting Surge = False in ElastoDyn changes the ‘RotThrust’ trend].
Thanks for your help, best regards.
Riccardo.
