Dear NREL team,
I am running openFAST simulations for the 15-MW reference wind turbine including wind turbine control (for floating applications) with a fully constrained floater and ignoring structural deformations of the wind turbine tower and wind turbine blades. Also, the tower drag loads are not taken into account. Now, for verification purposes, I am interested in the loads at the tower base of the turbine (located at the water line). Therefore, I changed the value of TowerBsHt from 15.0m to 0.0m in the “Turbine configuration” menu of ElastoDyn.dat, such that the height of the tower base is located at the waterline. This results in a distance equal to the hub height of 150.0 meter from MSL. The ElastoDyn.dat-file is shown below:
[code]------- ELASTODYN v1.03.* INPUT FILE -------------------------------------------
“default” DT Integration time step (s)
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
1. BlPitch(1) - Blade 1 initial pitch (degrees)
1. BlPitch(2) - Blade 2 initial pitch (degrees)
1. BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
7.56 RotSpeed - Initial or fixed rotor speed (rpm)
120 TipRad - The distance from the rotor apex to the blade tip (meters)
3 HubRad - The distance from the rotor apex to the blade root (meters)
-4 PreCone(1) - Blade 1 cone angle (degrees)
-4 PreCone(2) - Blade 2 cone angle (degrees)
-4 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
-11.075 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
-6 ShftTilt - Rotor shaft tilt angle (degrees)
-4.985 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
4.358 NacCMzn - Vertical distance from the tower-top to the nacelle CM (meters)
-4.985 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
4.358 NcIMUzn - Vertical distance from the tower-top to the nacelle IMU (meters)
4.3478 Twr2Shft - Vertical distance from the tower-top to the rotor shaft (meters)
144.495 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
0 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-14.94 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
190000 HubMass - Hub mass (kg)
1.37347E+06 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
8.00865E+06 GenIner - Generator inertia about HSS (kg m^2)
507275 NacMass - Nacelle mass (kg)
1.96179E+07 NacYIner - Nacelle inertia about yaw axis (kg m^2)
100000 YawBrMass - Yaw bearing mass (kg)
1.7838E+07 PtfmMass - Platform mass (kg)
1.2507E+10 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
1.2507E+10 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
2.3667E+10 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
20 BldNodes - Number of blade nodes (per blade) used for analysis (-)
“ElastoDyn_blade.dat” BldFile1 - Name of file containing properties for blade 1 (quoted string)
“ElastoDyn_blade.dat” BldFile2 - Name of file containing properties for blade 2 (quoted string)
“ElastoDyn_blade.dat” BldFile3 - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
1 GBRatio - Gearbox ratio (-)
8.235E+11 DTTorSpr - Drivetrain torsional spring (N-m/rad)
50 TwrNodes - Number of tower nodes used for analysis (-)
“ElastoDyn_tower.dat” TwrFile - Name of file containing tower properties (quoted string)
0 TStart - Time to begin tabular output (s) (currently unused)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
20 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0] TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0] TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
5, 9, 13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0] BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0] BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
“Azimuth”
“BldPitch1”
“GenSpeed”
“IPDefl1”
“LSSGagMya”
“LSSGagMza”
“OoPDefl1”
“PtfmSurge”
“PtfmSway”
“PtfmHeave”
“PtfmRoll”
“PtfmPitch”
“PtfmYaw”
“RootFxb1”
“RootFyb1”
“RootFzb1”
“RootMxb1”
“RootMyb1”
“RootMzb1”
“RootFxb2”
“RootFyb2”
“RootFzb2”
“RootMxb2”
“RootMyb2”
“RootMzb2”
“RootFxb3”
“RootFyb3”
“RootFzb3”
“RootMxb3”
“RootMyb3”
“RootMzb3”
“TipDxb1”
“TipDyb1”
“TipDxb2”
“TipDyb2”
“TipDxb3”
“TipDyb3”
“NcIMUTAxs”
“NcIMUTAys”
“NcIMUTAzs”
“YawBrTDxt”
“YawBrTDyt”
“RotSpeed”
“RotTorq”
“RotThrust”
“RotPwr”
“Spn2MLxb1”
“Spn2MLyb1”
“TwrBsFxt”
“TwrBsFyt”
“TwrBsFzt”
“TwrBsMxt”
“TwrBsMyt”
“TwrBsMzt”
“TTDspTwst”
“TwHt1TPxi”
“TwHt1TPyi”
“TwstDefl1”
“YawBrFxp”
“YawBrFyp”
“YawBrFzp”
“YawBrMxp”
“YawBrMyp”
“YawBrMzp”
“TwrBsFzt”
“NacYaw”
[/code]
After extracting the output parameters of the Tower Base Loads, the tower base pitching moment (TwrBsMyt) shows to deviate (significantly) from the pitching moment calculated by the aerodynamic thrust (RtAeroFxh) times the hub height of 150.0 meter (see figure, including another aerodynamic software). It seems that there is a fixed offset between the TwrBsMyt and the pitching moment calculated by RtAeroFxh times HubHt, resulting from a difference in the length of the reference points.
What could explain this (constant) difference in the TwrBsMyt?
Peter Veldman
