Dear NREL team,
I am investigating the loads on the yaw bearing of the 15MW NREL reference turbine for a parked condition (not idling). For simplicity I neglected the floater motions and structural deformations of the wind turbine tower and wind turbine blades.
I am running a simulation in a 52.1 m/s constant uniform wind speed with the blades feathered in the wind (90 degrees) without any yaw misalignment. The Aerodyn15.dat settings are in accordance with the settings recommended in a post from J. Jonkman, i.e. WakeMod = 0, AFAeroMod = 1. As well as the Elastodyn.dat settings (GenDOF = False) and Servodyn.dat settings (PCMode = 0). For this specific case I did not take into account the aerodynamic loads on the wind turbine-tower (TwrAero = False).
When looking to the tower-top / yaw bearing fore-aft shear force (YawBrFxp) in this specific simulation, it is noted that this load is equal to approx. 150 kN while the aerodynamic thrust force (RtAeroFxh) is equal to approx. 75 kN. Since the aerodynamic thrust force is the only load component on the yaw bearing, what can be the cause of this (significant) difference?
As far as I understood, openFast does not take the drag loads on the nacelle and hub into account which might be important when considering a yaw misalignment of the nacelle. Is there an appropriate way to take this loading into account? For example increasing the drag coefficient of the highest segment of the tower?
Thanks in advance.
Peter Veldman
P.S.: For completeness I included the input files for Aerodyn, Elastodyn and Servodyn below:
Aerodyn15.dat
[code]------- AERODYN v15.03.* INPUT FILE ------------------------------------------------
IEA 15 MW Offshore Reference Turbine
“default” DTAero - Time interval for aerodynamic calculations {or “default”} (s)
0 WakeMod - Type of wake/induction model (switch) {0=none, 1=BEMT}
1 AFAeroMod - Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model} [must be 1 when linearizing]
1 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
False TwrShadow - Calculate tower influence on wind based on downstream tower shadow? (flag)
False TwrAero - Calculate tower aerodynamic loads? (flag)
False CavitCheck - Perform cavitation check? (flag) TRUE will turn off unsteady aerodynamics
False CompAA - Flag to compute AeroAcoustics calculation [only used when WakeMod=1 or 2]
“AeroAcousticsInput.dat” AA_InputFile - Aeroacoustics input file
1.225000000000000e+00 AirDens - Air density (kg/m^3)
1.479232653061225e-05 KinVisc - Kinematic air viscosity (m^2/s)
3.350000000000000e+02 SpdSound - Speed of sound (m/s)
1.035000000000000e+05 Patm - Atmospheric pressure ¶ [used only when CavitCheck=True]
1.700000000000000e+03 Pvap - Vapour pressure of fluid ¶ [used only when CavitCheck=True]
5.000000000000000e-01 FluidDepth - Water depth above mid-hub height (m) [used only when CavitCheck=True]
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [used only when WakeMod=1]
“default” SkewModFactor - Constant used in Pitt/Peters skewed wake model {or “default” is 15/32*pi} (-) [used only when SkewMod=2; unused when WakeMod=0]
True TanInd - Include tangential induction in BEMT calculations? (flag) [used only when WakeMod=1]
True AIDrag - Include the drag term in the axial-induction calculation? (flag) [used only when WakeMod=1]
True TIDrag - Include the drag term in the tangential-induction calculation? (flag) [used only when WakeMod=1 and TanInd=TRUE]
“Default” IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or “default”} (-) [used only when WakeMod=1]
500 MaxIter - Maximum number of iteration steps (-) [used only when WakeMod=1]
====== Dynamic Blade-Element/Momentum Theory Options ====================================================== [used only when WakeMod=1]
2 DBEMT_Mod - Type of dynamic BEMT (DBEMT) model {1=constant tau1, 2=time-dependent tau1} (-) [used only when WakeMod=2]
2 tau1_const - Time constant for DBEMT (s) [used only when WakeMod=2 and DBEMT_Mod=1]
====== OLAF – cOnvecting LAgrangian Filaments (Free Vortex Wake) Theory Options ================== [used only when WakeMod=3]
“unused” OLAFInputFileName - Input file for OLAF [used only when WakeMod=3]
3 UAMod Unsteady Aero Model Switch (switch) {1=Baseline model (Original), 2=Gonzalez’s variant (changes in Cn,Cc,Cm), 3=Minemma/Pierce variant (changes in Cc and Cm)} [used only when AFAeroMod=2]
True FLookup Flag to indicate whether a lookup for f’ will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
1 AFTabMod - Interpolation method for multiple airfoil tables {1=1D interpolation on AoA (first table only); 2=2D interpolation on AoA and Re; 3=2D interpolation on AoA and UserProp} (-)
50 NumAFfiles - Number of airfoil files used (-)
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_00.dat” AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_01.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_02.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_03.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_04.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_05.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_06.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_07.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_08.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_09.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_10.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_11.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_12.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_13.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_14.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_15.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_16.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_17.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_18.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_19.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_20.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_21.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_22.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_23.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_24.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_25.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_26.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_27.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_28.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_29.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_30.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_31.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_32.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_33.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_34.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_35.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_36.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_37.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_38.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_39.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_40.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_41.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_42.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_43.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_44.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_45.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_46.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_47.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_48.dat”
“Airfoils/IEA-15-240-RWT_AeroDyn15_Polar_49.dat”
“AeroDyn15_blade.dat” ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
“AeroDyn15_blade.dat” ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
“AeroDyn15_blade.dat” ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
====== Tower Influence and Aerodynamics ============================================================= [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
11 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
TwrElev TwrDiam TwrCd
(m) (m) (-)
15. 10. 1.
28. 10. 1.
41. 9.926 1.
54. 9.443 1.
67. 8.833 1.
80. 8.151 1.
93. 7.39 1.
106. 6.909 1.
119. 6.748 1.
132. 6.572 1.
144.495 6.5 1.
True SumPrint - Generate a summary file listing input options and interpolated properties to “.AD.sum”? (flag)
9 NBlOuts - Number of blade node outputs [0 - 9] (-)
1, 6, 11, 20, 30, 38, 43, 47, 50 BlOutNd - Blade nodes whose values will be output (-)
1, 2, 3, 4, 5 TwOutNd - Tower nodes whose values will be output (-)
“RtAeroFxh”
“RtAeroFyh”
“RtAeroFzh”
“RtAeroMxh”
“RtAeroMyh”
“RtAeroMzh”
“RtVAvgxh”
“RtAeroCp”
“RtTSR”
[/code]
Elastodyn.dat
[code]------- ELASTODYN v1.03.* INPUT FILE -------------------------------------------
“default” DT Integration time step (s)
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
90 BlPitch(1) - Blade 1 initial pitch (degrees)
90 BlPitch(2) - Blade 2 initial pitch (degrees)
90 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
0 RotSpeed - Initial or fixed rotor speed (rpm)
120 TipRad - The distance from the rotor apex to the blade tip (meters)
3 HubRad - The distance from the rotor apex to the blade root (meters)
-4 PreCone(1) - Blade 1 cone angle (degrees)
-4 PreCone(2) - Blade 2 cone angle (degrees)
-4 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
-11.075 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
-6 ShftTilt - Rotor shaft tilt angle (degrees)
-4.985 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
4.358 NacCMzn - Vertical distance from the tower-top to the nacelle CM (meters)
-4.985 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
4.358 NcIMUzn - Vertical distance from the tower-top to the nacelle IMU (meters)
4.3478 Twr2Shft - Vertical distance from the tower-top to the rotor shaft (meters)
144.495 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
15 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-14.94 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
190000 HubMass - Hub mass (kg)
1.37347E+06 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
8.00865E+06 GenIner - Generator inertia about HSS (kg m^2)
507275 NacMass - Nacelle mass (kg)
1.96179E+07 NacYIner - Nacelle inertia about yaw axis (kg m^2)
100000 YawBrMass - Yaw bearing mass (kg)
1.7838E+07 PtfmMass - Platform mass (kg)
1.2507E+10 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
1.2507E+10 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
2.3667E+10 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
20 BldNodes - Number of blade nodes (per blade) used for analysis (-)
“ElastoDyn_blade.dat” BldFile1 - Name of file containing properties for blade 1 (quoted string)
“ElastoDyn_blade.dat” BldFile2 - Name of file containing properties for blade 2 (quoted string)
“ElastoDyn_blade.dat” BldFile3 - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
1 GBRatio - Gearbox ratio (-)
8.235E+11 DTTorSpr - Drivetrain torsional spring (N-m/rad)
50 TwrNodes - Number of tower nodes used for analysis (-)
“ElastoDyn_tower.dat” TwrFile - Name of file containing tower properties (quoted string)
0 TStart - Time to begin tabular output (s) (currently unused)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
20 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0] TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0] TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
5, 9, 13 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0] BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0] BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
“Azimuth”
“BldPitch1”
“GenSpeed”
“IPDefl1”
“LSSGagMya”
“LSSGagMza”
“OoPDefl1”
“PtfmSurge”
“PtfmSway”
“PtfmHeave”
“PtfmRoll”
“PtfmPitch”
“PtfmYaw”
“RootFxb1”
“RootFyb1”
“RootFzb1”
“RootMxb1”
“RootMyb1”
“RootMzb1”
“RootFxb2”
“RootFyb2”
“RootFzb2”
“RootMxb2”
“RootMyb2”
“RootMzb2”
“RootFxb3”
“RootFyb3”
“RootFzb3”
“RootMxb3”
“RootMyb3”
“RootMzb3”
“TipDxb1”
“TipDyb1”
“TipDxb2”
“TipDyb2”
“TipDxb3”
“TipDyb3”
“NcIMUTAxs”
“NcIMUTAys”
“NcIMUTAzs”
“YawBrTDxt”
“YawBrTDyt”
“RotSpeed”
“RotTorq”
“RotThrust”
“RotPwr”
“Spn2MLxb1”
“Spn2MLyb1”
“TwrBsFxt”
“TwrBsFyt”
“TwrBsFzt”
“TwrBsMxt”
“TwrBsMyt”
“TwrBsMzt”
“TTDspTwst”
“TwHt1TPxi”
“TwHt1TPyi”
“TwstDefl1”
“YawBrFxp”
“YawBrFyp”
“YawBrFzp”
“YawBrMxp”
“YawBrMyp”
“YawBrMzp”
“TwrBsFzt”
“NacYaw”
[/code]
Servodyn.dat
[code]------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
“default” DT - Communication interval for controllers (s) (or “default”)
0 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
2.0 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2.0 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2.0 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0.0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
0 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
96.55 GenEff - Generator efficiency [ignored by the Thevenin and user-defined generator models] (%)
9999.9 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
0.0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
4.6273E+10 YawSpr - Nacelle-yaw spring constant (N-m/rad)
3.9088E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2.0 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
---------------------- TUNED MASS DAMPER ---------------------------------------
False CompNTMD - Compute nacelle tuned mass damper {true/false} (flag)
“unused” NTMDfile - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
False CompTTMD - Compute tower tuned mass damper {true/false} (flag)
“unused” TTMDfile - Name of the file for tower tuned mass damper (quoted string) [unused when CompTTMD is false]
“DISCON.dll” DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
“DISCON-UMaineSemi.IN” DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
“DISCON” DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
“default” DLL_DT - Communication interval for dynamic library (s) (or “default”) [used only with Bladed Interface]
False DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0.0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0.0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0.0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0.0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0.0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0.0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0.0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0.0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0.0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0.0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to .sum (flag) (currently unused)
30.0 TStart - Time to begin tabular output (s) (currently unused)
“GenPwr”
“GenTq”
END of input file (the word “END” must appear in the first 3 columns of this last Out_List line)
[/code]
