I noticed that in the FAST OutData, for an offshore test, ‘TwrBsFxt’, ‘TwrBsFyt’, ‘TwrBsFxt’, ‘TwrBsMxt’, ‘TwrBsMyt’, ‘TwrBsMzt’ also contain inertial loads, and that moreover they are integral with the tower and not with the inertial reference system. My goal is to have the loads at the base of the tower (actually in the origin of the inertial frame of reference, (0,0,0)) due exclusively to the aerodynamic loads on the blades, excluding the inertial loads.
Since there are no such outputs in the OutData, I wrote the formulations to get them starting from ‘RtAeroFxh’, ‘RtAeroFyh’, ‘RtAeroFzh’, ‘RtAeroMxh’, ‘RtAeroMyh’, ‘RtAeroMzh’.
Please note that my simulations consider rigid bodies, with the following Elastodyn setting:
True Echo - Echo input data to "<RootName>.ech" (flag)
"default" DT - Integration time step (s)
False YawDOF - Yaw DOF (flag)
8.1334 RotSpeed - Initial or fixed rotor speed (rpm)
63 TipRad - The distance from the rotor apex to the blade tip (meters)
0 PreCone(1) - Blade 1 cone angle (degrees)
0 PreCone(2) - Blade 2 cone angle (degrees)
0 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
0 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
0 ShftTilt - Rotor shaft tilt angle (degrees)
0 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
0 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
10 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-89.9155 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
-0 PtfmRefzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
7.46633E+06 PtfmMass - Platform mass (kg)
4.22923E+09 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
4.22923E+09 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
1.6423E+08 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
17 BldNodes - Number of blade nodes (per blade) used for analysis (-)
"NRELOffshrBsline5MW_Blade.dat" BldFile(1) - Name of file containing properties for blade 1 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile(2) - Name of file containing properties for blade 2 (quoted string)
"NRELOffshrBsline5MW_Blade.dat" BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
97 GBRatio - Gearbox ratio (-)
"unused" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
"NRELOffshrBsline5MW_OC3Hywind_ElastoDyn_Tower.dat" TwrFile - Name of file containing tower properties (quoted string)
The loads at the nacelle (i.e. in a reference system integral with the tower with z_nac = z_tow and x_nac = x_rot) are:
Fx_nac=RtAeroFxh;
Fy_nac=RtAeroFyh.cos(Azimuthpi/180)-RtAeroFzh.sin(Azimuthpi/180);
Fz_nac=RtAeroFyh.sin(Azimuthpi/180)+RtAeroFzh.cos(Azimuthpi/180);
Mx_nac=RotAeroMxh;
My_nac=RtAeroMyh.cos(Azimuthpi/180)-RtAeroMzh.sin(Azimuthpi/180);
Mz_nac=RtAeroMzh.cos(Azimuthpi/180)+RtAeroMyh.sin(Azimuthpi/180);
Hence, to obtain the loads in (0,0,0), defined TransMat the Euler matrix containing the angular positions (PtfmRoll, PtfmPitch, PtfmYaw) in the inertial reference frame:
F = TransMat * [Fx_nac,Fy_nac,Fz_nac]
M = TransMat * [Mx_nac,My_nac,Mz_nac] + (TransMat * [0, 0, Hrot]) x F
where Hrot is the vertical distance between inertial reference frame (0,0,0) and nacelle reference frame (0,0,Hrot).
Gravity force and gravity restoring moments are not considered in these formulas as they are taken into account using the center of mass coordinates of the entire system.
In this way, the vector F of the 3 forces and the vector M of the 3 moments in the inertial reference system (0,0,0) due to the turbine loads are obtained.
I wonder if you agree with my procedure.
Lorenzo.
