I have a few questions regarding DELs calculated with MCrunch:
- Are the DEL results in the Html window displayed as load ranges or as one-sided amplitudes? Because in MLife you can choose between those two types.
- Furthermore in MLife you can choose the equivalent frequency for the DELs. But at which cycle frequency do the DELs in MCrunch oscillate?
- If I understand this correctly, the DELs oscillate about the manually defined LMF value. So e.g. if TypeLMF is 100 and my DEL is 50, and assuming the DEL is a one-sided amplitude (question #1), the DEL oscillates between 50 and 150 units. Is my understanding of DELs correct?
Thank you very much in advance!
Randi
