Dear @Jason.Jonkman ,
I apologize for not providing sufficient information.
I obtained TurbSim input file from here. (GitHub - OpenFAST/openfast_toolbox: Miscellaneous Python tools for OpenFAST)
The files I used are saved in this path.
./openfast_toolbox/fastfarm/examples/SampleFiles
The TurbSim input file I used for low is
--------TurbSim v2.00.* Input File------------------------
for Certification - Test #1 (Kaimal Spectrum, formatted FF files).
False Echo - Echo input data to <RootName>.ech (flag)
2318573 RandSeed1 - First random seed (-2147483648 to 2147483647)
RanLux RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: "RanLux" or "RNSNLW"
True WrFMTFF - Output full-field time-series data in formatted (readable) form? (Generates RootName.u, RootName.v, RootName.w)
27 NumGrid_Z - Vertical grid-point matrix dimension
61 NumGrid_Y - Horizontal grid-point matrix dimension
4.8 TimeStep - Time step [seconds]
4504.8 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
"ALL" UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds unless UsableTime is "ALL")
313.0 HubHt - Hub height [m] (should be > 0.5*GridHeight)
624.0 GridHeight - Grid height [m]
1440.0 GridWidth - Grid width [m] (should be >= 2*(RotorRadius+ShaftLength))
"IECKAI" TurbModel - Turbulence model ("IECKAI","IECVKM","GP_LLJ","NWTCUP","SMOOTH","WF_UPW","WF_07D","WF_14D","TIDAL","API","IECKAI","TIMESR", or "NONE")
"unused" UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for "IECKAI" and "TIMESR" models)
1 IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. "1-Ed2") )
"6.100 " IECturbc - IEC turbulence characteristic ("A", "B", "C" or the turbulence intensity in percent) ("KHTEST" option with NWTCUP model, not used for other models)
"NTM" IEC_WindType - IEC turbulence type ("NTM"=normal, "xETM"=extreme turbulence, "xEWM1"=extreme 1-year wind, "xEWM50"=extreme 50-year wind, where x=wind turbine class 1, 2, or 3)
"default" ETMc - IEC Extreme Turbulence Model "c" parameter [m/s]
"PL" WindProfileType - Velocity profile type ("LOG";"PL"=power law;"JET";"H2L"=Log law for TIDAL model;"API";"PL";"TS";"IEC"=PL on rotor disk, LOG elsewhere; or "default")
"unused" ProfileFile - Name of the file that contains input profiles for WindProfileType="USR" and/or TurbModel="USRVKM" [-]
150.0 RefHt - Height of the reference velocity (URef) [m]
9.0 URef - Mean (total) velocity at the reference height [m/s] (or "default" for JET velocity profile) [must be 1-hr mean for API model; otherwise is the mean over AnalysisTime seconds]
350 ZJetMax - Jet height [m] (used only for JET velocity profile, valid 70-490 m)
0.08 PLExp - Power law exponent [-] (or "default")
"default" Z0 - Surface roughness length [m] (or "default")
"default" Latitude - Site latitude [degrees] (or "default")
0.05 RICH_NO - Gradient Richardson number [-]
"default" UStar - Friction or shear velocity [m/s] (or "default")
"default" ZI - Mixing layer depth [m] (or "default")
"default" PC_UW - Hub mean u'w' Reynolds stress [m^2/s^2] (or "default" or "none")
"default" PC_UV - Hub mean u'v' Reynolds stress [m^2/s^2] (or "default" or "none")
"default" PC_VW - Hub mean v'w' Reynolds stress [m^2/s^2] (or "default" or "none")
"IEC" SCMod1 - u-component coherence model ("GENERAL","IEC","API","NONE", or "default")
"IEC" SCMod2 - v-component coherence model ("GENERAL","IEC","NONE", or "default")
"IEC" SCMod3 - w-component coherence model ("GENERAL","IEC","NONE", or "default")
"12 0.00035273" InCDec1 - u-component coherence parameters for general or IEC models [-, m^-1] (e.g. "10.0 0.3e-3" in quotes) (or "default")
"12 0.00035273" InCDec2 - v-component coherence parameters for general or IEC models [-, m^-1] (e.g. "10.0 0.3e-3" in quotes) (or "default")
"12 0.00035273" InCDec3 - w-component coherence parameters for general or IEC models [-, m^-1] (e.g. "10.0 0.3e-3" in quotes) (or "default")
"0.0" CohExp - Coherence exponent for general model [-] (or "default")
".\EventData" CTEventPath - Name of the path where event data files are located
"random" CTEventFile - Type of event files ("LES", "DNS", or "RANDOM")
True Randomize - Randomize the disturbance scale and locations? (true/false)
1 DistScl - Disturbance scale [-] (ratio of event dataset height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right [-] (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. [-] (Ignored when Randomize = true.)
30 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
! NOTE: Do not add or remove any lines in this file!
for high-resolution input file is
51 NumGrid_Z - Vertical grid-point matrix dimension
49 NumGrid_Y - Horizontal grid-point matrix dimension
0.3 TimeStep - Time step [seconds]
4555.5 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
157.0 HubHt - Hub height [m] (should be > 0.5*GridHeight)
300.0 GridHeight - Grid height [m]
288.0 GridWidth - Grid width [m] (should be >= 2*(RotorRadius+ShaftLength))
"TIMESR" TurbModel - Turbulence model ("IECKAI","IECVKM","GP_LLJ","NWTCUP","SMOOTH","WF_UPW","WF_07D","WF_14D","TIDAL","API","USRINP","TIMESR", or "NONE")
"USRTimeSeries_T1.txt" UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for "IECKAI" and "TIMESR" models)
150 RefHt - Height of the reference velocity (URef) [m]
This verification was conducted under wind conditions where u, v, and w files could not be generated, so no u, v, or w files exist. However, I have saved the wind condition files and results I created using the OpenFAST-toolbox at the following URL.
Thank you for your kind consideration.
Best,
